Hi, in a few days I get a WLE900VX card to replace the WLE200N2 on Omnia. Do I have to make any particular arrangements? Like antennas, pigtails, drivers? Or do I just replace the board and put all the pigtails on like the WLE200N2? Thanks.
Also I would like to know how to use reForis installable Candela drivers. After installing them, what should I do?
I’m assuming you are using the new WLE900VX for 2.4GHz.
The WLE200N2 card has 2 pigtails connected to signal combiners.
You can connect those 2 directly into the new card.
However you need a new antenna or a new signal combiner to connect to the third one, and a pigtail.
