I just upgraded my Omnia from 3.11.9 to 5.1.0. All good (except I had to change from SFP to PHY myself after the upgrade), but
Reforis doesn’t wok for me. The immediately visible behavior is that the page constantly reloads; I’ve been able to capture exactly one JS error, specifically “WebSocket connection to ‘ws://router/foris-ws’ failed: Unexpected response code: 404” in app.min.js:2
Now, I happen to run lighthttpd on port 8080 (instead of the default 80), and I expect that ws://router/foris-ws is the same as ws://router:80/foris-ws (since WS is based AFAIK on sending a connection upgrade header over standard HTTP).
And before you ask, I’ve already confirmed that moving lighttpd to port 80 fixes it
Do you gents think you can create the websockets connection on the same port as the page was fetched from?
We know that the fix isn’t included in the stable branch of our distribution. Right now, this is fixed in the latest development versions of reForis, which you can find in HBL branch. In this branch, you can test new features, which we are preparing.
We told that it is going to be available in further updates, which is true. Stay tuned for updates.
