For me this is 100% reproducible. I tried it with linux/firefox and macos/safari browser
Foris, where I can login says:
|Turris OS version |5.2.3|
|Turris OS branch |hbs|
My linux browser is configured to delete all cookies and website data when I close it, so I guess this prevents old data being used. I do not know howto proceed from here, could you please help?
Unfortunately this issue keeps appearing from time to time
Could you please provide exact version of Firefox and Safari browser you used, so we could try to reproduce it?
Also which Linux distribution and Mac OS version?
Have you tried other chromium-based browsers?
Tried a new anonymous window in Firefox? So all extensions should be disabled. Maybe an extension prevents the correct creation of the cookie. I am with Firefox 90.0 on Arch Linux and I can log in without any problem.
Private window in firefox still uses your current browser profile (history, configuration, extensions, etc.).
To check if reforis works with the usual firefox configuration or does not work regardless of configuration, you would have to create brand-new profile.
I tried both Firefox 86.0 on Ubuntu Focal and 78.12.0.esr on Debian 11 and with basic configuration (i.e. default profile) and cookie is set fine, thus I can successfully log in and use reForis.
Although I tried both as virtual machines, not on real HW. Perhaps this might be HW related.
Extensions and additional configuration related to cookies might interfere with CSRF protection, but with default profile it should work fine.
So I would suggest upgrading to latest Firefox (78.12.0 esr in case of Debian Linux) and see if that helps.
We have encountered few issues with Firefox and reforis before. Most of the time it was caused by the specific Firefox versions and was fixed in later releases.
I updated and tried it with firefox-esr 78.12.0esr-1 and cannot login into reforis.
Would a pcap File of a connection attempt help?
I have no idea what I do here - and please tell me if I should change my router password now- fuzzy name matching and clicking brings me to this screen:
Ah and I see that I installed ublock origin as debian package, so it is always there… Might this be the problem? After deinstalling ublock still the same:
