Hello Guys,
if I want to re-falsh my omnia wit the latest medkit file from here https://repo.turris.cz/omnia/medkit/omnia-medkit-latest.tar.gz
Now i get the following error from serial and have no idea what i should do now.
Searching for /srcmnt/omnia-medkit*.tar.gz on sda1
Found medkit file /srcmnt/omnia-medkit-latest.tar.gz on device sda1
1+0 records in
1+0 records out
512 bytes (512B) copied, 0.001518 seconds, 329.4KB/s
Welcome to fdisk (util-linux 2.29.2).
Changes will remain in memory only, until you decide to write them.
Be carefu[ 9.658837] mmcblk0: p1
l before using the write command[ 9.664399] mmcblk0: p1
Command (m for help): All space for primary partitions is in use.
Command (m for help): Disk /dev/mmcblk0: 7.3 GiB, 7818182656 bytes, 15269888 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x665e5ce8
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 15269887 15267840 7.3G 83 Linux
Command (m for help): 1: unknown command
Disklabel type: dos
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
btrfs-progs v4.11
See http://btrfs.wiki.kernel.org for more information.
Performing full device TRIM /dev/mmcblk0p1 (7.28GiB) ...
[ 13.310978] random: nonblocking pool is initialized
Label: (null)
UUID: 1d67ed74-25e8-4473-ad80-c7084bce1cce
Node size: 4096
Sector size: 4096
Filesystem size: 7.28GiB
Block group profiles:
Data+Metadata: single 8.00MiB
System: single 4.00MiB
SSD detected: yes
Incompat features: mixed-bg, extref, skinny-metadata
Number of devices: 1
Devices:
ID SIZE PATH
1 7.28GiB /dev/mmcblk0p1
ERROR: device scan failed on '/dev/mmcblk0p1': Invalid argument
mount_fs /dev/mmcblk0p[ 42.092819] [EXFAT] trying to mount...
1 /mnt
mount: mounting /dev/mmcblk0p1 on /mnt failed: Invalid argument
Error: Mount /dev/mmcblk0p1 on /mnt failed.
ERROR: not a btrfs filesystem: /mnt
Rootdir is /mnt/@
/bin/rescue.sh: cd: line 262: can't cd to /mnt/@
mdev: applet not found
ERROR: Could not statfs: No such file or directory
umount_fs /mnt
umount: can't unmount /mnt: Invalid argument
umount_fs /srcmnt
Current time Mon May 20 16:07:22 GMT 2019 seems to be OK. Keeping it.
Reflash succeeded.
Doing sysrq rebo[ 46.917566] sysrq: SysRq : ot as busybox onChanging Loglevel
e doesn't work
[ 46.924292] sysrq: Loglevel set to 0
[ 46.929315] sysrq: SysRq : Resetting
U-Boot SPL 2015.10-rc2 (Apr 11 2019 - 17:00:15)
High speed PHY - Version: 2.0
SERDES0 card detect: PEX
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 5 | PCIe0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
poll_op_execute: TIMEOUT
:** Link is Gen1, check the EP capability
PCIe, Idx 0: remains Gen1
PCIe, Idx 1: remains Gen1
PCIe, Idx 2: detected no link
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x01
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2015.10-rc2 (Apr 11 2019 - 17:00:15 +0200), Build: jenkins-omnia-stable-377
SoC: MV88F6820-A0
Watchdog enabled
I2C: ready
SPI: ready
DRAM: 1 GiB (ECC not enabled)
Enabling Armada 385 watchdog.
Disabling MCU startup watchdog.
Regdomain set to **
MMC: mv_sdh: 0
SF: Detected S25FL164K with page size 256 Bytes, erase size 64 KiB, total 8 MiB
PCI:
00:01.0 - 168c:002e - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory controller
01:01.0 - 168c:003c - Network controller
Model: Marvell Armada 385 GP
Board: Turris Omnia SN: 0000000B00011BB9
Regdomain set to **
SCSI: MVEBU SATA INIT
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net: neta2
Hit any key to stop autoboot: 0
Setting bus to 1
BOOT eMMC FS
btrfs probe failed
** Unrecognized filesystem type **
btrfs probe failed
Kernel image @ 0x1000000 [ 0x000000 - 0x6ef1e0 ]
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
Thanks for your help
Stefan
