Random error ethernet eth0 "max frame length error"
In today’s log I found a random error “bad rx status 0f850000 (max frame length error), size=1536”
I have connected the part filtered log and part contiguous portion of a log for the continuity of the binding.
What the problem with this is it ?
root@turris:~# cat /var/log/messages |grep frame
2017-02-12T11:07:09+01:00 err kernel[]: [409705.694322] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T11:07:09+01:00 err kernel[]: [409706.191680] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T11:07:10+01:00 err kernel[]: [409706.795710] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:57:32+01:00 err kernel[]: [419928.746366] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:57:33+01:00 err kernel[]: [419929.050059] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:57:33+01:00 err kernel[]: [419929.652081] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:57:41+01:00 err kernel[]: [419937.865338] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:57:42+01:00 err kernel[]: [419938.347172] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:57:43+01:00 err kernel[]: [419939.327169] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:59:21+01:00 err kernel[]: [420037.715819] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:59:22+01:00 err kernel[]: [420038.021927] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:59:22+01:00 err kernel[]: [420038.621908] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:59:44+01:00 err kernel[]: [420060.871473] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:59:45+01:00 err kernel[]: [420061.258086] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T13:59:45+01:00 err kernel[]: [420061.858077] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T14:00:12+01:00 err kernel[]: [420088.294369] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T14:00:12+01:00 err kernel[]: [420088.656276] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T14:00:13+01:00 err kernel[]: [420089.256308] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T14:00:50+01:00 err kernel[]: [420126.150516] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T14:00:50+01:00 err kernel[]: [420126.451624] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
2017-02-12T14:00:51+01:00 err kernel[]: [420127.051573] mvneta f1030000.ethernet eth0: bad rx status 0f850000 (max frame length error), size=1536
root@turris:~#
2017-02-12T12:50:06+01:00 info ucollect[27232]: Sending 2 IPv4 refused connections and 0 IPv6 ones
2017-02-12T12:50:10+01:00 warning odhcpd[2149]: DHCPV6 REBIND IA_NA from 000300010011320d2cfc on br-lan: ok
2017-02-12T12:51:01+01:00 info /usr/sbin/cron[13573]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:52:01+01:00 info /usr/sbin/cron[13614]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:52:01+01:00 info /usr/sbin/cron[13615]: (root) CMD (nethist_stats.lua)
2017-02-12T12:52:01+01:00 info /usr/sbin/cron[13616]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2017-02-12T12:53:01+01:00 info /usr/sbin/cron[13703]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:54:01+01:00 info /usr/sbin/cron[13754]: (root) CMD (nethist_stats.lua)
2017-02-12T12:54:01+01:00 info /usr/sbin/cron[13755]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:54:01+01:00 info /usr/sbin/cron[13758]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2017-02-12T12:55:01+01:00 info /usr/sbin/cron[13835]: (root) CMD (/usr/bin/watchdog.sh)
2017-02-12T12:55:01+01:00 info /usr/sbin/cron[13837]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:55:01+01:00 info /usr/sbin/cron[13838]: (root) CMD (majordomo_db.sh downsize)
2017-02-12T12:55:01+01:00 info /usr/sbin/cron[13839]: (root) CMD (   /usr/bin/notifier)
2017-02-12T12:55:02+01:00 warning watchdog[]: Restarted nethist
2017-02-12T12:56:01+01:00 info /usr/sbin/cron[13979]: (root) CMD (nethist_stats.lua)
2017-02-12T12:56:01+01:00 info /usr/sbin/cron[13981]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2017-02-12T12:56:01+01:00 info /usr/sbin/cron[13980]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:56:52+01:00 info sshd[10335]: Received disconnect from 192.168.2.120 port 52844:11: FlowSshClientSession: disconnected on user's request
2017-02-12T12:56:52+01:00 info sshd[10335]: Disconnected from 192.168.2.120 port 52844
2017-02-12T12:57:01+01:00 info /usr/sbin/cron[14058]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:58:01+01:00 info /usr/sbin/cron[14097]: (root) CMD (nethist_stats.lua)
2017-02-12T12:58:01+01:00 info /usr/sbin/cron[14099]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2017-02-12T12:58:01+01:00 info /usr/sbin/cron[14098]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T12:59:01+01:00 info /usr/sbin/cron[14175]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14218]: (root) CMD (nethist_stats.lua)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14214]: (root) CMD (/usr/bin/watchdog.sh)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14225]: (root) CMD (/root/connCheck.sh > /dev/null 2>&1)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14227]: (root) CMD (/usr/bin/get-api-crl)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14223]: (root) CMD (/usr/share/firewall/turris-download)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14222]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14226]: (root) CMD (   /usr/bin/notifier)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14232]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T13:00:01+01:00 info /usr/sbin/cron[14233]: (root) CMD (majordomo_db.sh downsize)
2017-02-12T14:00:02+01:00 info nikola[]: (v41) recognized WAN interfaces: eth1, lo
2017-02-12T13:00:30+01:00 warning odhcpd[2149]: DHCPV6 REBIND IA_NA from 000300010011320d2cfc on br-lan: ok
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Establishing connection took 0.698331 seconds
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Logrotate took 0.004513 seconds
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Syslog parsing took 0.037163 seconds
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Session init took 0.830247 seconds
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Records parsed: 17
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Records after filtering: 9
2017-02-12T14:00:49+01:00 info nikola[]: (v41) Records filtering took 0.007323 seconds
2017-02-12T14:00:50+01:00 info nikola[]: (v41) {u'msg': u'Data were inserted into work queue.'}
2017-02-12T14:00:50+01:00 info nikola[]: (v41) Sending records took 0.108003 seconds
2017-02-12T13:01:01+01:00 info /usr/sbin/cron[14437]: (root) CMD (majordomo_db.sh genhour)
2017-02-12T13:01:01+01:00 info /usr/sbin/cron[14436]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-02-12T13:01:10+01:00 info ucollect[27232]: Updating filter addresses from version 49563441 to version 49563481 (epoch 4)
2017-02-12T13:01:11+01:00 info ucollect[27232]: Updating ipset turris_100FA4E0_lb_a_4_X from version 49563441 to version 49563481 (epoch 4)
2017-02-12T13:01:16+01:00 warning ucollect[27232]: epoll_wait on 4 interrupted, retry
