Hi there,
I have configured RAID 1 following this manual: Linux RAID mdadm [Turris wiki]
It worked well and the RAID1 is working as expected. But sometimes (about 20% of boots) the raid is not created during boot even though that mdadm service is reported to be running. If I manually restarm mdamd from terminal I get this:
root@turris:~# /etc/init.d/mdadm restart
mdadm: Fail create md0 when using /sys/module/md_mod/parameters/new_array
mdadm: /dev/md0 has been started with 2 drives.
After that RAID1 is created and can be mounted.
root@turris:~# mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Wed Feb 1 19:39:00 2023
Raid Level : raid1
Array Size : 3906885440 (3725.90 GiB 4000.65 GB)
Used Dev Size : 3906885440 (3725.90 GiB 4000.65 GB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Mon Feb 27 10:13:42 2023
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Consistency Policy : bitmap
Name : turris:0 (local to host turris)
UUID : 20646394:ad410baf:6a7f66dd:f85fc211
Events : 6464
Number Major Minor RaidDevice State
0 8 17 0 active sync /dev/sdb1
1 8 1 1 active sync /dev/sda1
I was trying to find some error in system log and found even no mentioning of “md” related to RAID.
Is anyone else having the same problem?
Thanks for any hint!
