Question about WIFI Master/Client
Below a screenshot of my wireless cards set to off.
When I turn it on, my main wireless card gets “Master” When its off it gets “Unknown”
Is this normal? If so, what is the reason for this?
You don 't have WiFi module disabled ? What does the Foris setting look like?
Výstřižek2
Thanks for the reply JardaB.
The module is not disabled. It has been turned off.
What’s the question? When the WiFi on so works? Where’s the real problem? Turn on WiFi and enjoy!
yes, i guess its normal. I got same effect in the past.
Means, if i set it off there is no signal anymore so it is shown as unknown - nowadays shown as:
unknown - “name xyz”
Greets,
Pex
