Hi!
I am trying to follow this tutorial on how to setup prometheus monitoring on OpenWRT, so I installed the packages:
opkg install prometheus-node-exporter-lua prometheus-node-exporter-lua-netstat prometheus-node-exporter-lua-openwrt prometheus-node-exporter-lua-wifi prometheus-node-exporter-lua-wifi_stations
and did the little dance to change the listening interface:
sed -i.bak 's#loopback#lan#g' /etc/config/prometheus-node-exporter-lua
/etc/init.d/prometheus-node-exporter-lua restart
and it … works, somewhat? At least Prometheus is scraping metrics, but I’m not seeing what I expected. The wifi stats, namely, are sorely missing.
It looks like the only wifi metrics exporter are the number of clients;
root@octavia:~# curl -s localhost:9100/metrics | grep wifi
# TYPE wifi_client gauge
wifi_client{iface="wlan0"} 1
wifi_client{iface="wlan1"} 2
node_exporter_scrape_duration_seconds{collector="wifi_clients",result="success"} 0.014352083206177
node_exporter_scrape_duration_seconds_sum{collector="wifi_clients",result="success"} 0.78434109687805
node_exporter_scrape_duration_seconds_count{collector="wifi_clients",result="success"} 62
This is odd! That metric is not available on another OpenWRT device, and that device has much more data:
$ curl -s 192.168.0.11:9100/metrics | grep -c wifi_client
0
73
I have also tried the prometheus-node-exporter-lua-hostapd_stations
and prometheus-node-exporter-lua-hostapd_ubus_stations
packages, neither of which show station stats.
Ideas?
