Hello
My Xiaomi Gateway 3 stop suddenly responds via telnet. I use it for communication with Home Assistant integration. This happens at the time of the last Turris update. So it seems to be connected. I try to enable port 23 in firewall settings for all interfaces for the Xiaomi Gateway IP address. But the device still refuses connection when I try to connect to it.
I want to ask if anybody has any idea what I can check further? Gateway is working via the standard Xiaomi app and shows still old firmware 1.4.6_0012 what should have an open and working telnet port.
Forward thanks for any hint or help
Best regards
Michael
