Problem with nfs server
Currently I am unable to connect to nfs server runing on Turris Omnia.
I am getting
NFSD: Unable to create client record on stable storage: -110
in /var/log/messages
In https://forums.gentoo.org/viewtopic-t-951452-start-0.html suggested too create diectory /proc/fs/nfsd/nfsv4recoverydir .
It didn’t solve the problem for me.
Any suggestions please.
I’m also searching for the solution still didn’t find the solution. :disappointed:
NFS 4 seams to be broken.
I can mount nfs3 using -o vers=3 mount parameter or nfsvers=3 parameter in fstabs mount point on client.
I am stil getting errors for nfs4:
2017-10-15T16:11:45+02:00 err kernel: [132074.865572] NFSD: Unable to create client record on stable storage: -110
2017-10-15T16:11:45+02:00 warning kernel: [132074.873808] NFS: SECINFO: security flavor 390003 is not supported
2017-10-15T16:11:45+02:00 warning kernel: [132074.873860] NFS: SECINFO: security flavor 390004 is not supported
2017-10-15T16:11:45+02:00 warning kernel: [132074.873904] NFS: SECINFO: security flavor 390005 is not supported
Hope it will be fixed soon.
I would suggest to write to the tech support email instead of writing here. That’s how NFSv4 support was initially added.
