You have my verbose log in PM.
If you are affected by this problem, please try installing http://repo.turris.cz/omnia-dev-ondrej/packages/turrispackages/knot-resolver_1.2.6-1_mvebu.ipk
Download the package to Turris Omnia and install using opkg. Something like:
cd /tmp
wget https://repo.turris.cz/omnia-dev-ondrej/packages/turrispackages/knot-resolver_1.2.6-1_mvebu.ipk
opkg install knot-resolver_1.2.6-1_mvebu.ipk
And please report back whether it has helped you or not (it should). The problem manifest itself only with slightly unreliable authoritative nameservers (or networks) that makes some packets to be lost.
For the people who want all the technical details on that awful and serious bug, see the Knot resolvers issues #178 https://gitlab.labs.nic.cz/knot/resolver/issues/178 and #179.https://gitlab.labs.nic.cz/knot/resolver/issues/179 (it is not Google-specific)
This seems to fix the issue
I can confirm this, I applied your patch and it seems it fixed the issue.
I would appreciate if:
- all Turris team members have turris_team icon badge (Iâd like to know if the patch/advice Iâm going to apply is from official team member)
- you provide info what we have to do afterwards - I see my auto.lua was updated
Seems to work indeed, stopped using the google dns. My android wifi sign isnât showing the little cross anymore either. If anything happens Iâll reply but I hope not.
Still works, thanks guys for the effort!
any possible official update for this issue? I have 2 omnias where I dont have acces at this moment
I installed package knot-resolver_1.2.5-3_mvebu.ipk yesterday. And after 24 hours still ok. IMHO this package solve described problem with Google.
I canât install this package, i donât understand why ?
root@turris:~# opkg install knot-resolver_1.2.5-3_mvebu.ipk
Collected errors:
- wfopen: knot-resolver_1.2.5-3_mvebu.ipk: No such file or directory.
- pkg_init_from_file: Failed to extract control file from knot-resolver_1.2.5-3_mvebu.ipk.
You must make steps as described by âoerdnjâ in previous post.
cd /tmp
wget https://repo.turris.cz/omnia-dev-ondrej/packages/turrispackages/knot-resolver_1.2.5-3_mvebu.ipk
ZdravĂm, OndĹeji. Tato VaĹĄe odpovÄÄ by se velice lĂbila @miska, kterĂ˝ nĂĄm na konci seminĂĄĹe âTurris Omnia praktickyâ promĂtl poslednĂ slide s informacĂ: âNa Internetu se to poslednĂ dobou jen hemŞà nĂĄvody typu stĂĄhnÄte si pomocĂ wget nebo curl nÄjakĂ˝ balĂÄek Äi skript a nainstalujte Äi spusĹĽte ho na svĂŠm routeru. To doma nikdy nedÄlejte. Jde to proti vĹĄem best practise.â
PotÄĹĄil by jste jej âŚ
P.S.: Sorry for Czech, but it is only a off-topic
This isnât just âsomewhere from the internetâ. Still, I recommend you to use that link with https:// at least
hello, did you change from:
to
at this moment i have installed 1.2.5-3 .
Now i try reinstall with 1.2.6 but for relevant result is need some time. (is need few hours)
After three hours with version 1.2.6-1 it still works ok.
The announcement for Turris 0S 3.6 (due today) includes an upgrade of the Knot resolver. Will it solve this very serious bug?
I believe it will. (fill to 20 chars)
The problem with Google that appeared in Turris OS 3.6.2 is fixed and tested in 3.6.3 that is now in RC branch and it should be out in master today.
EDIT: 3.6.3 update have been published, your routers should intstall it automatically soon. In case you are eager user you can install it manually.
just write these lines in SSH
opkg update
updater.sh
reboot
