2019-01-19 08:12:07 info kernel[]: [ 0.000000] Memory CAM mapping: 256/256 Mb, residual: 1536Mb
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Initializing cgroup subsys cpuset
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Initializing cgroup subsys cpuacct
2019-01-19 08:12:07 notice kernel[]: [ 0.000000] Linux version 4.4.169-49a62e79231da4ac50e66e6eb4cd7945-2 (beast@build) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r47055) ) #1 SMP Tue Jan 15 09:50:48 CET 2019
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] Found legacy serial port 0 for /soc@ffe00000
/serial@4500
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] mem=ffe04500, taddr=ffe04500, irq=0, clk=600000000, speed=0
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] Found legacy serial port 1 for /soc@ffe00000/serial@4600
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] mem=ffe04600, taddr=ffe04600, irq=0, clk=600000000, speed=0
2019-01-19 08:12:07 info kernel[]: [ 0.000000] CPU maps initialized for 1 thread per core
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] (thread shift is 0)
2019-01-19 08:12:07 info kernel[]: [ 0.000000] bootconsole [udbg0] enabled
2019-01-19 08:12:07 err kernel[]: [ 0.000000] mpc85xx_qe_init: Could not find Quicc Engine node
2019-01-19 08:12:07 info kernel[]: [ 0.000000] MPC85xx RDB board from Freescale Semiconductor
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] Top of RAM: 0x80000000, Total RAM: 0x80000000
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] Memory hole size: 0MB
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Zone ranges:
2019-01-19 08:12:07 info kernel[]: [ 0.000000] DMA [mem 0x0000000000000000-0x000000001fffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Normal empty
2019-01-19 08:12:07 info kernel[]: [ 0.000000] HighMem [mem 0x0000000020000000-0x000000007fffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Movable zone start for each node
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Early memory node ranges
2019-01-19 08:12:07 info kernel[]: [ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] On node 0 totalpages: 524288
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] free_area_init_node: node 0, pgdat c064a700, node_mem_map dede0000
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] DMA zone: 1152 pages used for memmap
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] DMA zone: 0 pages reserved
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] DMA zone: 131072 pages, LIFO batch:31
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
2019-01-19 08:12:07 info kernel[]: [ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
2019-01-19 08:12:07 info kernel[]: [ 0.000000] PERCPU: Embedded 10 pages/cpu @dedc2000 s9420 r8192 d23348 u40960
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] pcpu-alloc: s9420 r8192 d23348 u40960 alloc=10*4096
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523136
2019-01-19 08:12:07 notice kernel[]: [ 0.000000] Kernel command line: root=ubi0:rootfs rootfstype=ubifs ubi.mtd=9,2048 rootflags=chk_data_crc rw console=ttyS0,115200
2019-01-19 08:12:07 info kernel[]: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
2019-01-19 08:12:07 notice kernel[]: [ 0.000000] Sorting __ex_table...
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Memory: 2005368K/2097152K available (5008K kernel code, 176K rwdata, 1092K rodata, 196K init, 259K bss, 91784K reserved, 0K cma-reserved, 1572856K highmem)
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Kernel virtual memory layout:
2019-01-19 08:12:07 info kernel[]: [ 0.000000] * 0xfffbf000..0xfffff000 : fixmap
2019-01-19 08:12:07 info kernel[]: [ 0.000000] * 0xffc00000..0xffe00000 : highmem PTEs
2019-01-19 08:12:07 info kernel[]: [ 0.000000] * 0xffbfd000..0xffc00000 : early ioremap
2019-01-19 08:12:07 info kernel[]: [ 0.000000] * 0xe1000000..0xffbfd000 : vmalloc & ioremap
2019-01-19 08:12:07 info kernel[]: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
2019-01-19 08:12:07 info kernel[]: [ 0.000000] Hierarchical RCU implementation.
2019-01-19 08:12:07 info kernel[]: [ 0.000000] NR_IRQS:512 nr_irqs:512 16
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] mpic: Resetting
2019-01-19 08:12:07 info kernel[]: [ 0.000000] mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs
2019-01-19 08:12:07 info kernel[]: [ 0.000000] mpic: ISU size: 256, shift: 8, mask: ff
2019-01-19 08:12:07 info kernel[]: [ 0.000000] mpic: Initializing for 256 sources
2019-01-19 08:12:07 err kernel[]: [ 0.000000] mpc85xx_rdb_pic_init: Could not find qe-ic node
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] time_init: decrementer frequency = 75.000000 MHz
2019-01-19 08:12:07 debug kernel[]: [ 0.000000] time_init: processor frequency = 1200.000000 MHz
2019-01-19 08:12:07 info kernel[]: [ 0.000008] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114c1bade8, max_idle_ns: 440795203839 ns
2019-01-19 08:12:07 info kernel[]: [ 0.010276] clocksource: timebase mult[d555555] shift[24] registered
2019-01-19 08:12:07 debug kernel[]: [ 0.016623] clockevent: decrementer mult[13333333] shift[32] cpu[0]
2019-01-19 08:12:07 info kernel[]: [ 0.016658] pid_max: default: 32768 minimum: 301
2019-01-19 08:12:07 info kernel[]: [ 0.021304] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.027843] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.035248] Initializing cgroup subsys io
2019-01-19 08:12:07 info kernel[]: [ 0.039185] Initializing cgroup subsys memory
2019-01-19 08:12:07 info kernel[]: [ 0.043538] Initializing cgroup subsys devices
2019-01-19 08:12:07 info kernel[]: [ 0.047959] Initializing cgroup subsys freezer
2019-01-19 08:12:07 info kernel[]: [ 0.052391] Initializing cgroup subsys net_cls
2019-01-19 08:12:07 info kernel[]: [ 0.056825] Initializing cgroup subsys pids
2019-01-19 08:12:07 info kernel[]: [ 0.061142] mpic: requesting IPIs...
2019-01-19 08:12:07 info kernel[]: [ 0.065632] Brought up 2 CPUs
2019-01-19 08:12:07 info kernel[]: [ 0.070606] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
2019-01-19 08:12:07 info kernel[]: [ 0.080283] futex hash table entries: 512 (order: 2, 16384 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.086465] xor: measuring software checksum speed
2019-01-19 08:12:07 info kernel[]: [ 0.101223] 8regs : 1472.000 MB/sec
2019-01-19 08:12:07 info kernel[]: [ 0.115360] 8regs_prefetch: 1312.000 MB/sec
2019-01-19 08:12:07 info kernel[]: [ 0.129844] 32regs : 1472.000 MB/sec
2019-01-19 08:12:07 info kernel[]: [ 0.143981] 32regs_prefetch: 1360.000 MB/sec
2019-01-19 08:12:07 info kernel[]: [ 0.148513] xor: using function: 32regs (1472.000 MB/sec)
2019-01-19 08:12:07 info kernel[]: [ 0.154230] NET: Registered protocol family 16
2019-01-19 08:12:07 info kernel[]: [ 0.163646] cpuidle: using governor ladder
2019-01-19 08:12:07 info kernel[]: [ 0.173876] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus number: 0->0
2019-01-19 08:12:07 info kernel[]: [ 0.181724] PCI host bridge /pcie@ffe08000 (primary) ranges:
2019-01-19 08:12:07 info kernel[]: [ 0.187374] MEM 0x00000000c0000000..0x00000000dfffffff -> 0x00000000c0000000
2019-01-19 08:12:07 info kernel[]: [ 0.194587] IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000
2019-01-19 08:12:07 info kernel[]: [ 0.201725] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
2019-01-19 08:12:07 info kernel[]: [ 0.206495] setup_pci_atmu: end of DRAM 80000000
2019-01-19 08:12:07 info kernel[]: [ 0.211370] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->1
2019-01-19 08:12:07 info kernel[]: [ 0.219212] PCI host bridge /pcie@ffe09000 ranges:
2019-01-19 08:12:07 info kernel[]: [ 0.224079] MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
2019-01-19 08:12:07 info kernel[]: [ 0.231293] IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
2019-01-19 08:12:07 info kernel[]: [ 0.238429] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
2019-01-19 08:12:07 info kernel[]: [ 0.243201] setup_pci_atmu: end of DRAM 80000000
2019-01-19 08:12:07 info kernel[]: [ 0.248057] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->1
2019-01-19 08:12:07 info kernel[]: [ 0.255897] PCI host bridge /pcie@ffe0a000 ranges:
2019-01-19 08:12:07 info kernel[]: [ 0.260765] MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
2019-01-19 08:12:07 info kernel[]: [ 0.267979] IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
2019-01-19 08:12:07 info kernel[]: [ 0.275115] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
2019-01-19 08:12:07 info kernel[]: [ 0.279887] setup_pci_atmu: end of DRAM 80000000
2019-01-19 08:12:07 info kernel[]: [ 0.293244] PCI: Probing PCI hardware
2019-01-19 08:12:07 info kernel[]: [ 0.296974] fsl-pci ffe08000.pcie: PCI host bridge to bus 0000:00
2019-01-19 08:12:07 info kernel[]: [ 0.302995] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
2019-01-19 08:12:07 info kernel[]: [ 0.309159] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.316028] pci_bus 0000:00: root bus resource [bus 00-ff]
2019-01-19 08:12:07 debug kernel[]: [ 0.321506] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to ff
2019-01-19 08:12:07 debug kernel[]: [ 0.321535] pci 0000:00:00.0: [1957:0070] type 01 class 0x0b2000
2019-01-19 08:12:07 debug kernel[]: [ 0.321557] pci 0000:00:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.321602] pci 0000:00:00.0: supports D1 D2
2019-01-19 08:12:07 debug kernel[]: [ 0.321609] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2019-01-19 08:12:07 info kernel[]: [ 0.321797] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
2019-01-19 08:12:07 info kernel[]: [ 0.329814] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
2019-01-19 08:12:07 debug kernel[]: [ 0.334963] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
2019-01-19 08:12:07 debug kernel[]: [ 0.334971] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.334981] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
2019-01-19 08:12:07 debug kernel[]: [ 0.334995] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
2019-01-19 08:12:07 debug kernel[]: [ 0.335004] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 01
2019-01-19 08:12:07 info kernel[]: [ 0.335153] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
2019-01-19 08:12:07 info kernel[]: [ 0.341172] pci_bus 0001:02: root bus resource [io 0x20000-0x2ffff] (bus address [0x0000-0xffff])
2019-01-19 08:12:07 info kernel[]: [ 0.350121] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.356988] pci_bus 0001:02: root bus resource [bus 02-ff]
2019-01-19 08:12:07 debug kernel[]: [ 0.362465] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to ff
2019-01-19 08:12:07 debug kernel[]: [ 0.362485] pci 0001:02:00.0: [1957:0070] type 01 class 0x0b2000
2019-01-19 08:12:07 debug kernel[]: [ 0.362503] pci 0001:02:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.362536] pci 0001:02:00.0: supports D1 D2
2019-01-19 08:12:07 debug kernel[]: [ 0.362544] pci 0001:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2019-01-19 08:12:07 warning kernel[]: [ 0.362707] pci 0001:02:00.0: Primary bus is hard wired to 0
2019-01-19 08:12:07 info kernel[]: [ 0.368289] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
2019-01-19 08:12:07 debug kernel[]: [ 0.376387] pci 0001:03:00.0: [168c:0030] type 00 class 0x028000
2019-01-19 08:12:07 debug kernel[]: [ 0.376425] pci 0001:03:00.0: reg 0x10: [mem 0xa0000000-0xa001ffff 64bit]
2019-01-19 08:12:07 debug kernel[]: [ 0.376462] pci 0001:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
2019-01-19 08:12:07 debug kernel[]: [ 0.376517] pci 0001:03:00.0: supports D1
2019-01-19 08:12:07 debug kernel[]: [ 0.376524] pci 0001:03:00.0: PME# supported from D0 D1 D3hot
2019-01-19 08:12:07 info kernel[]: [ 0.378312] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
2019-01-19 08:12:07 debug kernel[]: [ 0.383463] pci 0001:02:00.0: bridge window [io 0x20000-0x20fff]
2019-01-19 08:12:07 debug kernel[]: [ 0.383472] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xa00fffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.383517] pci_bus 0001:03: busn_res: [bus 03-ff] end is updated to 03
2019-01-19 08:12:07 debug kernel[]: [ 0.383528] pci_bus 0001:02: busn_res: [bus 02-ff] end is updated to 03
2019-01-19 08:12:07 info kernel[]: [ 0.383675] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0002:04
2019-01-19 08:12:07 info kernel[]: [ 0.389695] pci_bus 0002:04: root bus resource [io 0x40000-0x4ffff] (bus address [0x0000-0xffff])
2019-01-19 08:12:07 info kernel[]: [ 0.398644] pci_bus 0002:04: root bus resource [mem 0x80000000-0x9fffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.405511] pci_bus 0002:04: root bus resource [bus 04-ff]
2019-01-19 08:12:07 debug kernel[]: [ 0.410988] pci_bus 0002:04: busn_res: [bus 04-ff] end is updated to ff
2019-01-19 08:12:07 debug kernel[]: [ 0.411008] pci 0002:04:00.0: [1957:0070] type 01 class 0x0b2000
2019-01-19 08:12:07 debug kernel[]: [ 0.411027] pci 0002:04:00.0: reg 0x10: [mem 0xfff00000-0xffffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.411060] pci 0002:04:00.0: supports D1 D2
2019-01-19 08:12:07 debug kernel[]: [ 0.411067] pci 0002:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
2019-01-19 08:12:07 warning kernel[]: [ 0.411235] pci 0002:04:00.0: Primary bus is hard wired to 0
2019-01-19 08:12:07 info kernel[]: [ 0.416817] pci 0002:04:00.0: bridge configuration invalid ([bus 01-01]), reconfiguring
2019-01-19 08:12:07 debug kernel[]: [ 0.424912] pci 0002:05:00.0: [168c:002a] type 00 class 0x028000
2019-01-19 08:12:07 debug kernel[]: [ 0.424954] pci 0002:05:00.0: reg 0x10: [mem 0x80000000-0x8000ffff 64bit]
2019-01-19 08:12:07 debug kernel[]: [ 0.425043] pci 0002:05:00.0: supports D1
2019-01-19 08:12:07 debug kernel[]: [ 0.425050] pci 0002:05:00.0: PME# supported from D0 D1 D3hot
2019-01-19 08:12:07 info kernel[]: [ 0.425185] pci 0002:05:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
2019-01-19 08:12:07 info kernel[]: [ 0.435126] pci 0002:04:00.0: PCI bridge to [bus 05-ff]
2019-01-19 08:12:07 debug kernel[]: [ 0.440328] pci 0002:04:00.0: bridge window [io 0x40000-0x40fff]
2019-01-19 08:12:07 debug kernel[]: [ 0.440337] pci 0002:04:00.0: bridge window [mem 0x80000000-0x800fffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.440376] pci_bus 0002:05: busn_res: [bus 05-ff] end is updated to 05
2019-01-19 08:12:07 debug kernel[]: [ 0.440387] pci_bus 0002:04: busn_res: [bus 04-ff] end is updated to 05
2019-01-19 08:12:07 warning kernel[]: [ 0.440432] PCI: Cannot allocate resource region 0 of PCI bridge 1, will remap
2019-01-19 08:12:07 warning kernel[]: [ 0.447584] PCI: Cannot allocate resource region 0 of device 0000:00:00.0, will remap
2019-01-19 08:12:07 warning kernel[]: [ 0.455399] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, will remap
2019-01-19 08:12:07 warning kernel[]: [ 0.463226] PCI: Cannot allocate resource region 0 of device 0002:04:00.0, will remap
2019-01-19 08:12:07 debug kernel[]: [ 0.471058] PCI 0001:02 Cannot reserve Legacy IO [io 0x20000-0x20fff]
2019-01-19 08:12:07 debug kernel[]: [ 0.471064] PCI 0002:04 Cannot reserve Legacy IO [io 0x40000-0x40fff]
2019-01-19 08:12:07 info kernel[]: [ 0.471085] pci 0000:00:00.0: BAR 0: no space for [mem size 0x00100000]
2019-01-19 08:12:07 info kernel[]: [ 0.477655] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
2019-01-19 08:12:07 info kernel[]: [ 0.484610] pci 0000:00:00.0: PCI bridge to [bus 01]
2019-01-19 08:12:07 info kernel[]: [ 0.489564] pci 0000:00:00.0: bridge window [mem 0xc0000000-0xdfffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.496345] pci_bus 0000:00: Some PCI device resources are unassigned, try booting with pci=realloc
2019-01-19 08:12:07 debug kernel[]: [ 0.505390] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.505398] pci_bus 0000:00: resource 5 [mem 0xc0000000-0xdfffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.505406] pci_bus 0000:01: resource 1 [mem 0xc0000000-0xdfffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.505422] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
2019-01-19 08:12:07 info kernel[]: [ 0.511993] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
2019-01-19 08:12:07 info kernel[]: [ 0.518951] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref]
2019-01-19 08:12:07 info kernel[]: [ 0.526163] pci 0001:02:00.0: PCI bridge to [bus 03]
2019-01-19 08:12:07 info kernel[]: [ 0.531118] pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
2019-01-19 08:12:07 info kernel[]: [ 0.537377] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xbfffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.544158] pci_bus 0001:02: Some PCI device resources are unassigned, try booting with pci=realloc
2019-01-19 08:12:07 debug kernel[]: [ 0.553199] pci_bus 0001:02: resource 4 [io 0x20000-0x2ffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.553207] pci_bus 0001:02: resource 5 [mem 0xa0000000-0xbfffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.553214] pci_bus 0001:03: resource 0 [io 0x20000-0x2ffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.553221] pci_bus 0001:03: resource 1 [mem 0xa0000000-0xbfffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.553237] pci 0002:04:00.0: BAR 0: no space for [mem size 0x00100000]
2019-01-19 08:12:07 info kernel[]: [ 0.559807] pci 0002:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
2019-01-19 08:12:07 info kernel[]: [ 0.566761] pci 0002:04:00.0: PCI bridge to [bus 05]
2019-01-19 08:12:07 info kernel[]: [ 0.571716] pci 0002:04:00.0: bridge window [io 0x40000-0x4ffff]
2019-01-19 08:12:07 info kernel[]: [ 0.577975] pci 0002:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.584756] pci_bus 0002:04: Some PCI device resources are unassigned, try booting with pci=realloc
2019-01-19 08:12:07 debug kernel[]: [ 0.593797] pci_bus 0002:04: resource 4 [io 0x40000-0x4ffff]
2019-01-19 08:12:07 notice netifd[]: radio1 (4676): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
2019-01-19 08:12:07 debug kernel[]: [ 0.593805] pci_bus 0002:04: resource 5 [mem 0x80000000-0x9fffffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.593812] pci_bus 0002:05: resource 0 [io 0x40000-0x4ffff]
2019-01-19 08:12:07 debug kernel[]: [ 0.593819] pci_bus 0002:05: resource 1 [mem 0x80000000-0x9fffffff]
2019-01-19 08:12:07 info kernel[]: [ 0.594086] mpic-msgr ffe41400.message: Found 0 message registers
2019-01-19 08:12:07 info kernel[]: [ 0.600102] mpic-msgr ffe41400.message: Of-device full name /soc@ffe00000/message@41400
2019-01-19 08:12:07 err kernel[]: [ 0.608106] mpic-msgr ffe41400.message: Failed to find message register block alias
2019-01-19 08:12:07 debug kernel[]: [ 0.615864] Setting up Freescale MSI support
2019-01-19 08:12:07 debug kernel[]: [ 0.616345] Registering qe_ic with sysfs...
2019-01-19 08:12:07 info kernel[]: [ 0.639724] raid6: int32x1 gen() 171 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.661036] raid6: int32x1 xor() 218 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.682396] raid6: int32x2 gen() 300 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.703716] raid6: int32x2 xor() 263 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.725060] raid6: int32x4 gen() 398 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.746376] raid6: int32x4 xor() 289 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.767740] raid6: int32x8 gen() 378 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.789049] raid6: int32x8 xor() 253 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.793234] raid6: using algorithm int32x4 gen() 398 MB/s
2019-01-19 08:12:07 info kernel[]: [ 0.798622] raid6: .... xor() 289 MB/s, rmw enabled
2019-01-19 08:12:07 info kernel[]: [ 0.803490] raid6: using intx1 recovery algorithm
2019-01-19 08:12:07 info kernel[]: [ 0.809456] clocksource: Switched to clocksource timebase
2019-01-19 08:12:07 info kernel[]: [ 0.815565] NET: Registered protocol family 2
2019-01-19 08:12:07 info kernel[]: [ 0.820246] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.827254] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.833692] TCP: Hash tables configured (established 4096 bind 4096)
2019-01-19 08:12:07 info kernel[]: [ 0.840059] UDP hash table entries: 256 (order: 1, 8192 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.845839] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
2019-01-19 08:12:07 info kernel[]: [ 0.852218] NET: Registered protocol family 1
2019-01-19 08:12:07 debug kernel[]: [ 0.856560] PCI: CLS 32 bytes, default 32
2019-01-19 08:12:07 info kernel[]: [ 0.862632] squashfs: version 4.0 (2009/01/31) Phillip Lougher
2019-01-19 08:12:07 info kernel[]: [ 0.868545] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
2019-01-19 08:12:07 info kernel[]: [ 0.881229] bounce: pool size: 64 pages
2019-01-19 08:12:07 info kernel[]: [ 0.885035] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
2019-01-19 08:12:07 info kernel[]: [ 0.892382] io scheduler noop registered
2019-01-19 08:12:07 info kernel[]: [ 0.896289] io scheduler deadline registered (default)
2019-01-19 08:12:07 info kernel[]: [ 0.901700] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
2019-01-19 08:12:07 info kernel[]: [ 0.907860] pcieport 0002:04:00.0: enabling device (0106 -> 0107)
2019-01-19 08:12:07 debug kernel[]: [ 0.914088] aer 0000:00:00.0:pcie02: service driver aer loaded
2019-01-19 08:12:07 debug kernel[]: [ 0.914122] aer 0001:02:00.0:pcie02: service driver aer loaded
2019-01-19 08:12:07 debug kernel[]: [ 0.914150] aer 0002:04:00.0:pcie02: service driver aer loaded
2019-01-19 08:12:07 info kernel[]: [ 0.914204] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
2019-01-19 08:12:07 debug kernel[]: [ 0.921097] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
2019-01-19 08:12:07 info kernel[]: [ 0.921136] pcieport 0001:02:00.0: Signaling PME through PCIe PME interrupt
2019-01-19 08:12:07 info kernel[]: [ 0.928045] pci 0001:03:00.0: Signaling PME through PCIe PME interrupt
2019-01-19 08:12:07 debug kernel[]: [ 0.934566] pcie_pme 0001:02:00.0:pcie01: service driver pcie_pme loaded
2019-01-19 08:12:07 info kernel[]: [ 0.934590] pcieport 0002:04:00.0: Signaling PME through PCIe PME interrupt
2019-01-19 08:12:07 info kernel[]: [ 0.941519] pci 0002:05:00.0: Signaling PME through PCIe PME interrupt
2019-01-19 08:12:07 debug kernel[]: [ 0.948037] pcie_pme 0002:04:00.0:pcie01: service driver pcie_pme loaded
2019-01-19 08:12:07 info kernel[]: [ 0.973903] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
2019-01-19 08:12:07 info kernel[]: [ 0.982430] console [ttyS0] disabled
2019-01-19 08:12:07 info kernel[]: [ 0.985979] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550A
2019-01-19 08:12:07 notice netifd[]: radio1 (4676): wlan1: interface state COUNTRY_UPDATE->HT_SCAN
2019-01-19 08:12:07 info kernel[]: [ 0.994614] console [ttyS0] enabled
2019-01-19 08:12:07 info kernel[]: [ 1.001558] bootconsole [udbg0] disabled
2019-01-19 08:12:07 info kernel[]: [ 1.009783] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550A
2019-01-19 08:12:07 info kernel[]: [ 1.019084] console [ttyS0] disabled
2019-01-19 08:12:07 info kernel[]: [ 1.022690] ffe04500.serial: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 37500000) is a 16550
2019-01-19 08:12:07 info kernel[]: [ 1.022702] console [ttyS0] enabled
2019-01-19 08:12:07 info kernel[]: [ 1.026605] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
2019-01-19 08:12:07 info kernel[]: [ 1.042616] brd: module loaded
2019-01-19 08:12:07 info kernel[]: [ 1.046411] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002101
2019-01-19 08:12:07 info kernel[]: [ 1.056432] Amd/Fujitsu Extended Query Table at 0x0040
2019-01-19 08:12:07 info kernel[]: [ 1.061600] Amd/Fujitsu Extended Query version 1.3.
2019-01-19 08:12:07 notice kernel[]: [ 1.066657] number of CFI chips: 1
2019-01-19 08:12:07 notice kernel[]: [ 1.070275] 6 ofpart partitions found on MTD device ef000000.nor
2019-01-19 08:12:07 notice kernel[]: [ 1.076293] Creating 6 MTD partitions on "ef000000.nor":
2019-01-19 08:12:07 notice kernel[]: [ 1.081612] 0x000000000000-0x000000020000 : "NOR (RO) DTB Image"
2019-01-19 08:12:07 notice kernel[]: [ 1.088219] 0x000000020000-0x0000001c0000 : "NOR (RO) Linux Kernel Image"
2019-01-19 08:12:07 notice kernel[]: [ 1.095570] 0x0000001c0000-0x000000340000 : "NOR (RO) JFFS2 Root File System"
2019-01-19 08:12:07 notice kernel[]: [ 1.103281] 0x000000340000-0x000000e40000 : "NOR (RO) NAND FW backup"
2019-01-19 08:12:07 notice kernel[]: [ 1.110304] 0x000000e40000-0x000000f00000 : "NOR (RW) Cert backup"
2019-01-19 08:12:07 notice kernel[]: [ 1.117060] 0x000000f00000-0x000001000000 : "NOR (RO) U-Boot Image"
2019-01-19 08:12:07 info kernel[]: [ 1.124421] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
2019-01-19 08:12:07 info kernel[]: [ 1.130799] nand: Micron MT29F2G08ABAEAWP
2019-01-19 08:12:07 info kernel[]: [ 1.134813] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
2019-01-19 08:12:07 info kernel[]: [ 1.143707] Bad block table found at page 131008, version 0x01
2019-01-19 08:12:07 info kernel[]: [ 1.150315] Bad block table found at page 130944, version 0x01
2019-01-19 08:12:07 notice kernel[]: [ 1.156730] 4 ofpart partitions found on MTD device ff800000.flash
2019-01-19 08:12:07 notice kernel[]: [ 1.162924] Creating 4 MTD partitions on "ff800000.flash":
2019-01-19 08:12:07 notice kernel[]: [ 1.168417] 0x000000000000-0x000000200000 : "NAND (RW) DTB Image"
2019-01-19 08:12:07 notice kernel[]: [ 1.175103] 0x000000200000-0x000000700000 : "NAND (RW) Linux Kernel Image"
2019-01-19 08:12:07 notice kernel[]: [ 1.182518] 0x000000700000-0x000010000000 : "NAND (RW) JFFS2 Root File System"
2019-01-19 08:12:07 notice kernel[]: [ 1.190499] 0x000000000000-0x000010000000 : "rootfs-ubifs"
2019-01-19 08:12:07 info kernel[]: [ 1.196728] eLBC NAND device at 0xff800000, bank 1
2019-01-19 08:12:07 info kernel[]: [ 1.202019] fsl_espi ffe07000.spi: cs=0, init_csmode=0x100008
2019-01-19 08:12:07 info kernel[]: [ 1.207780] fsl_espi ffe07000.spi: cs=1, init_csmode=0x100008
2019-01-19 08:12:07 info kernel[]: [ 1.213541] fsl_espi ffe07000.spi: cs=2, init_csmode=0x100008
2019-01-19 08:12:07 info kernel[]: [ 1.219294] fsl_espi ffe07000.spi: cs=3, init_csmode=0x100008
2019-01-19 08:12:07 info kernel[]: [ 1.226125] fsl_espi ffe07000.spi: at 0xe11c0000 (irq = 59)
2019-01-19 08:12:07 info kernel[]: [ 1.232158] libphy: Fixed MDIO Bus: probed
2019-01-19 08:12:07 info kernel[]: [ 1.236464] libphy: Freescale PowerQUICC MII Bus: probed
2019-01-19 08:12:07 info kernel[]: [ 1.244327] switch0: Atheros AR8337 rev. 2 switch registered on mdio@ffe24520
2019-01-19 08:12:07 info kernel[]: [ 1.296161] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
2019-01-19 08:12:07 info kernel[]: [ 1.314085] fsl-gianfar ffe24000.ethernet eth0: mac: 00:00:00:00:00:00
2019-01-19 08:12:07 info kernel[]: [ 1.320626] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
2019-01-19 08:12:07 info kernel[]: [ 1.327422] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
2019-01-19 08:12:07 info kernel[]: [ 1.334567] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
2019-01-19 08:12:07 info kernel[]: [ 1.341993] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
2019-01-19 08:12:07 info kernel[]: [ 1.359865] fsl-gianfar ffe25000.ethernet eth1: mac: 00:00:00:00:00:00
2019-01-19 08:12:07 info kernel[]: [ 1.366408] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
2019-01-19 08:12:07 info kernel[]: [ 1.373204] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
2019-01-19 08:12:07 info kernel[]: [ 1.380347] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
2019-01-19 08:12:07 info kernel[]: [ 1.387566] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
2019-01-19 08:12:07 info kernel[]: [ 1.405422] fsl-gianfar ffe26000.ethernet eth2: mac: 00:00:00:00:00:00
2019-01-19 08:12:07 info kernel[]: [ 1.411973] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
2019-01-19 08:12:07 info kernel[]: [ 1.418770] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
2019-01-19 08:12:07 info kernel[]: [ 1.425913] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
2019-01-19 08:12:07 info kernel[]: [ 1.433155] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
2019-01-19 08:12:07 info kernel[]: [ 1.439284] i2c /dev entries driver
2019-01-19 08:12:07 info kernel[]: [ 1.442916] mpc-i2c ffe03000.i2c: timeout 1000000 us
2019-01-19 08:12:07 info kernel[]: [ 1.450386] rtc-ds1307 0-006f: rtc core: registered mcp7940x as rtc0
2019-01-19 08:12:07 info kernel[]: [ 1.456766] rtc-ds1307 0-006f: 64 bytes nvram
2019-01-19 08:12:07 info kernel[]: [ 1.461306] mpc-i2c ffe03100.i2c: timeout 1000000 us
2019-01-19 08:12:07 info kernel[]: [ 1.466557] booke_wdt: powerpc book-e watchdog driver loaded
2019-01-19 08:12:07 info kernel[]: [ 1.472416] sdhci: Secure Digital Host Controller Interface driver
2019-01-19 08:12:07 info kernel[]: [ 1.478607] sdhci: Copyright(c) Pierre Ossman
2019-01-19 08:12:07 info kernel[]: [ 1.482970] sdhci-pltfm: SDHCI platform and OF driver helper
2019-01-19 08:12:07 info kernel[]: [ 1.488778] /soc@ffe00000/sdhc@2e000: voltage-ranges unspecified
2019-01-19 08:12:07 info kernel[]: [ 1.494804] sdhci-esdhc ffe2e000.sdhc: No vmmc regulator found
2019-01-19 08:12:07 info kernel[]: [ 1.500643] sdhci-esdhc ffe2e000.sdhc: No vqmmc regulator found
2019-01-19 08:12:07 info kernel[]: [ 1.528976] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
2019-01-19 08:12:07 info kernel[]: [ 1.536840] NET: Registered protocol family 10
2019-01-19 08:12:07 info kernel[]: [ 1.541908] NET: Registered protocol family 17
2019-01-19 08:12:07 info kernel[]: [ 1.546410] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
2019-01-19 08:12:07 notice kernel[]: [ 1.559068] Bridge firewalling registered
2019-01-19 08:12:07 info kernel[]: [ 1.563097] 8021q: 802.1Q VLAN Support v1.8
2019-01-19 08:12:07 warning kernel[]: [ 1.568098] BTRFS: using crc32c-generic for crc32c
2019-01-19 08:12:07 info kernel[]: [ 1.574259] Btrfs loaded, integrity-checker=on
2019-01-19 08:12:07 notice kernel[]: [ 1.579122] ubi0: attaching mtd9
2019-01-19 08:12:07 notice kernel[]: [ 2.749280] random: nonblocking pool is initialized
2019-01-19 08:12:07 notice kernel[]: [ 2.937952] ubi0: scanning is finished
2019-01-19 08:12:07 notice kernel[]: [ 2.952009] ubi0: attached mtd9 (name "rootfs-ubifs", size 256 MiB)
2019-01-19 08:12:07 notice kernel[]: [ 2.958290] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
2019-01-19 08:12:07 notice kernel[]: [ 2.965171] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
2019-01-19 08:12:07 notice kernel[]: [ 2.971877] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
2019-01-19 08:12:07 notice kernel[]: [ 2.978844] ubi0: good PEBs: 2044, bad PEBs: 4, corrupted PEBs: 0
2019-01-19 08:12:07 notice kernel[]: [ 2.984942] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
2019-01-19 08:12:07 notice kernel[]: [ 2.992170] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 116289186
2019-01-19 08:12:07 notice kernel[]: [ 3.001224] ubi0: available PEBs: 0, total reserved PEBs: 2044, PEBs reserved for bad PEB handling: 36
2019-01-19 08:12:07 notice kernel[]: [ 3.010575] ubi0: background thread "ubi_bgt0d" started, PID 1029
2019-01-19 08:12:07 info kernel[]: [ 3.017631] rtc-ds1307 0-006f: setting system clock to 2019-01-19 07:11:44 UTC (1547881904)
2019-01-19 08:12:07 notice kernel[]: [ 3.027533] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 1031
2019-01-19 08:12:07 notice kernel[]: [ 3.120071] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
2019-01-19 08:12:07 notice kernel[]: [ 3.127482] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
2019-01-19 08:12:07 notice kernel[]: [ 3.137408] UBIFS (ubi0:0): FS size: 252555264 bytes (240 MiB, 1989 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
2019-01-19 08:12:07 notice kernel[]: [ 3.148113] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
2019-01-19 08:12:07 notice kernel[]: [ 3.153953] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID ED5EDC36-F2A1-4CCB-A4E5-876345B82F95, small LPT model
2019-01-19 08:12:07 info kernel[]: [ 3.168035] VFS: Mounted root (ubifs filesystem) on device 0:13.
2019-01-19 08:12:07 info kernel[]: [ 3.174274] Freeing unused kernel memory: 196K
2019-01-19 08:12:07 info kernel[]: 3.397363] init: Console is alive
2019-01-19 08:12:07 info kernel[]: 3.400886] init: - watchdog -
2019-01-19 08:12:07 info kernel[]: [ 4.515658] usbcore: registered new interface driver usbfs
2019-01-19 08:12:07 info kernel[]: [ 4.521205] usbcore: registered new interface driver hub
2019-01-19 08:12:07 info kernel[]: [ 4.526575] usbcore: registered new device driver usb
2019-01-19 08:12:07 info kernel[]: [ 4.540105] Button Hotplug driver version 0.4.1
2019-01-19 08:12:07 info kernel[]: [ 4.566478] exFAT: Version 1.2.9
2019-01-19 08:12:07 info kernel[]: [ 4.801842] JFS: nTxBlock = 8192, nTxLock = 65536
2019-01-19 08:12:07 info kernel[]: [ 5.034680] SGI XFS with security attributes, no debug enabled
2019-01-19 08:12:07 notice kernel[]: [ 5.076194] SCSI subsystem initialized
2019-01-19 08:12:07 info kernel[]: [ 5.092128] usbcore: registered new interface driver usb-storage
2019-01-19 08:12:07 info kernel[]: [ 5.101476] usbcore: registered new interface driver uas
2019-01-19 08:12:07 info kernel[]: [ 5.125235] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
2019-01-19 08:12:07 info kernel[]: [ 5.132564] ehci-platform: EHCI generic platform driver
2019-01-19 08:12:07 info kernel[]: [ 5.138337] ehci-fsl: Freescale EHCI Host controller driver
2019-01-19 08:12:07 info kernel[]: [ 5.143995] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
2019-01-19 08:12:07 info kernel[]: [ 5.150638] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
2019-01-19 08:12:07 info kernel[]: [ 5.157934] fsl-ehci fsl-ehci.0: irq 28, io mem 0xffe22000
2019-01-19 08:12:07 info kernel[]: [ 5.168975] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
2019-01-19 08:12:07 info kernel[]: [ 5.175000] hub 1-0:1.0: USB hub found
2019-01-19 08:12:07 info kernel[]: [ 5.178782] hub 1-0:1.0: 1 port detected
2019-01-19 08:12:07 debug kernel[]: [ 5.230125] libata version 3.00 loaded.
2019-01-19 08:12:07 info kernel[]: [ 5.243859] uhci_hcd: USB Universal Host Controller Interface driver
2019-01-19 08:12:07 info kernel[]: 5.405223] init: - preinit -
2019-01-19 08:12:07 info kernel[]: [ 5.483982] usb 1-1: new high-speed USB device number 2 using fsl-ehci
2019-01-19 08:12:07 info kernel[]: [ 5.604856] hub 1-1:1.0: USB hub found
2019-01-19 08:12:07 info kernel[]: [ 5.608702] hub 1-1:1.0: 2 ports detected
2019-01-19 08:12:07 notice kernel[]: 9.204218] mount_root: mounting /dev/root
2019-01-19 08:12:07 info kernel[]: 9.216592] mount_root: loading kmods from internal overlay
2019-01-19 08:12:07 info kernel[]: 9.656460] block: attempting to load /etc/config/fstab
2019-01-19 08:12:07 info kernel[]: 9.670721] block: extroot: not configured
2019-01-19 08:12:07 info kernel[]: 9.684879] procd: - early -
2019-01-19 08:12:07 info kernel[]: 9.687823] procd: - watchdog -
2019-01-19 08:12:07 info kernel[]: 10.341397] procd: - ubus -
2019-01-19 08:12:07 info kernel[]: 11.351195] procd: - init -
2019-01-19 08:12:07 info kernel[]: [ 11.783936] NET: Registered protocol family 38
2019-01-19 08:12:07 info kernel[]: [ 11.860125] md: linear personality registered for level -1
2019-01-19 08:12:07 info kernel[]: [ 11.867413] md: raid0 personality registered for level 0
2019-01-19 08:12:07 info kernel[]: [ 11.881211] md: raid1 personality registered for level 1
2019-01-19 08:12:07 info kernel[]: [ 11.897273] md: raid10 personality registered for level 10
2019-01-19 08:12:07 info kernel[]: [ 11.928488] md: raid6 personality registered for level 6
2019-01-19 08:12:07 info kernel[]: [ 11.933842] md: raid5 personality registered for level 5
2019-01-19 08:12:07 info kernel[]: [ 11.939174] md: raid4 personality registered for level 4
2019-01-19 08:12:07 notice kernel[]: [ 11.962321] FS-Cache: Loaded
2019-01-19 08:12:07 info kernel[]: [ 11.966999] md: multipath personality registered for level -4
2019-01-19 08:12:07 info kernel[]: [ 11.987815] NET: Registered protocol family 8
2019-01-19 08:12:07 info kernel[]: [ 11.992222] NET: Registered protocol family 20
2019-01-19 08:12:07 info kernel[]: [ 12.027504] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
2019-01-19 08:12:07 notice kernel[]: [ 12.047044] Key type dns_resolver registered
2019-01-19 08:12:07 info kernel[]: [ 12.082004] NET: Registered protocol family 33
2019-01-19 08:12:07 notice kernel[]: [ 12.086495] Key type rxrpc registered
2019-01-19 08:12:07 notice kernel[]: [ 12.090183] Key type rxrpc_s registered
2019-01-19 08:12:07 info kernel[]: [ 12.125105] kAFS: Red Hat AFS client v0.1 registering.
2019-01-19 08:12:07 notice kernel[]: [ 12.130323] FS-Cache: Netfs 'afs' registered for caching
2019-01-19 08:12:07 info kernel[]: [ 12.338332] RPC: Registered named UNIX socket transport module.
2019-01-19 08:12:07 info kernel[]: [ 12.344288] RPC: Registered udp transport module.
2019-01-19 08:12:07 info kernel[]: [ 12.349000] RPC: Registered tcp transport module.
2019-01-19 08:12:07 info kernel[]: [ 12.353719] RPC: Registered tcp NFSv4.1 backchannel transport module.
2019-01-19 08:12:07 notice kernel[]: [ 12.493113] NFS: Registering the id_resolver key type
2019-01-19 08:12:07 notice kernel[]: [ 12.498209] Key type id_resolver registered
2019-01-19 08:12:07 notice kernel[]: [ 12.502399] Key type id_legacy registered
2019-01-19 08:12:07 info kernel[]: [ 12.508468] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
2019-01-19 08:12:07 info kernel[]: [ 12.547275] ntfs: driver 2.1.32 [Flags: R/O MODULE].
2019-01-19 08:12:07 notice kernel[]: [ 12.583197] RxRPC: Registered security type 2 'rxkad'
2019-01-19 08:12:07 info kernel[]: [ 12.654925] tun: Universal TUN/TAP device driver, 1.6
2019-01-19 08:12:07 info kernel[]: [ 12.660013] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
2019-01-19 08:12:07 info kernel[]: [ 12.685195] sit: IPv6 over IPv4 tunneling driver
2019-01-19 08:12:07 info kernel[]: [ 12.693064] gre: GRE over IPv4 demultiplexor driver
2019-01-19 08:12:07 info kernel[]: [ 12.700627] ip_gre: GRE over IPv4 tunneling driver
2019-01-19 08:12:07 info kernel[]: [ 12.781818] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
2019-01-19 08:12:07 info kernel[]: [ 12.796378] PPP generic driver version 2.4.2
2019-01-19 08:12:07 info kernel[]: [ 12.809857] ip6_tables: (C) 2000-2006 Netfilter Core Team
2019-01-19 08:12:07 info kernel[]: [ 12.828780] cryptodev: driver 1.8 loaded.
2019-01-19 08:12:07 info kernel[]: [ 12.838183] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
2019-01-19 08:12:07 info kernel[]: [ 12.846216] Backport generated by backports.git backports-20160324-13-g24da7d3c
2019-01-19 08:12:07 info kernel[]: [ 13.182395] u32 classifier
2019-01-19 08:12:07 info kernel[]: [ 13.185120] input device check on
2019-01-19 08:12:07 info kernel[]: [ 13.188792] Actions configured
2019-01-19 08:12:07 info kernel[]: [ 13.193275] Mirror/redirect action on
2019-01-19 08:12:07 info kernel[]: [ 13.200211] GACT probability on
2019-01-19 08:12:07 info kernel[]: [ 13.215220] netem: version 1.3
2019-01-19 08:12:07 info kernel[]: [ 13.248331] fuse init (API version 7.23)
2019-01-19 08:12:07 info kernel[]: [ 13.361206] usbcore: registered new interface driver cdc_wdm
2019-01-19 08:12:07 info kernel[]: [ 13.374131] Ebtables v2.0 registered
2019-01-19 08:12:07 info kernel[]: [ 13.384034] ip_tables: (C) 2000-2006 Netfilter Core Team
2019-01-19 08:12:07 info kernel[]: [ 13.419435] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
2019-01-19 08:12:07 info kernel[]: [ 13.484231] Netfilter messages via NETLINK v0.30.
2019-01-19 08:12:07 info kernel[]: [ 13.491499] PPP MPPE Compression module registered
2019-01-19 08:12:07 info kernel[]: [ 13.497664] NET: Registered protocol family 24
2019-01-19 08:12:07 info kernel[]: [ 13.506547] usbcore: registered new interface driver ums-alauda
2019-01-19 08:12:07 info kernel[]: [ 13.515090] usbcore: registered new interface driver ums-cypress
2019-01-19 08:12:07 info kernel[]: [ 13.523518] usbcore: registered new interface driver ums-datafab
2019-01-19 08:12:07 info kernel[]: [ 13.531995] usbcore: registered new interface driver ums-freecom
2019-01-19 08:12:07 info kernel[]: [ 13.540198] usbcore: registered new interface driver ums-isd200
2019-01-19 08:12:07 info kernel[]: [ 13.548341] usbcore: registered new interface driver ums-jumpshot
2019-01-19 08:12:07 info kernel[]: [ 13.556595] usbcore: registered new interface driver ums-karma
2019-01-19 08:12:07 info kernel[]: [ 13.565843] usbcore: registered new interface driver ums-sddr09
2019-01-19 08:12:07 info kernel[]: [ 13.573987] usbcore: registered new interface driver ums-sddr55
2019-01-19 08:12:07 info kernel[]: [ 13.583296] usbcore: registered new interface driver ums-usbat
2019-01-19 08:12:07 info kernel[]: [ 13.610178] usbcore: registered new interface driver usbserial
2019-01-19 08:12:07 info kernel[]: [ 13.616099] usbcore: registered new interface driver usbserial_generic
2019-01-19 08:12:07 info kernel[]: [ 13.622724] usbserial: USB Serial support registered for generic
2019-01-19 08:12:07 info kernel[]: [ 13.645660] xt_time: kernel timezone is -0000
2019-01-19 08:12:07 info kernel[]: [ 13.659567] usbcore: registered new interface driver cdc_ether
2019-01-19 08:12:07 info kernel[]: [ 13.680802] ctnetlink v0.93: registering with nfnetlink.
2019-01-19 08:12:07 info kernel[]: [ 13.695522] usbcore: registered new interface driver qmi_wwan
2019-01-19 08:12:07 info kernel[]: [ 13.704043] usbcore: registered new interface driver rndis_host
2019-01-19 08:12:07 debug kernel[]: [ 13.865791] ath: EEPROM regdomain: 0x0
2019-01-19 08:12:07 debug kernel[]: [ 13.865801] ath: EEPROM indicates default country code should be used
2019-01-19 08:12:07 debug kernel[]: [ 13.865805] ath: doing EEPROM country->regdmn map search
2019-01-19 08:12:07 debug kernel[]: [ 13.865814] ath: country maps to regdmn code: 0x3a
2019-01-19 08:12:07 debug kernel[]: [ 13.865819] ath: Country alpha2 being used: US
2019-01-19 08:12:07 debug kernel[]: [ 13.865823] ath: Regpair used: 0x3a
2019-01-19 08:12:07 debug kernel[]: [ 13.873641] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
2019-01-19 08:12:07 info kernel[]: [ 13.875609] ieee80211 phy0: Atheros AR9300 Rev:3 mem=0xe3f40000, irq=27
2019-01-19 08:12:07 debug kernel[]: [ 14.311841] ath: EEPROM regdomain: 0x65
2019-01-19 08:12:07 debug kernel[]: [ 14.311851] ath: EEPROM indicates we should expect a direct regpair map
2019-01-19 08:12:07 debug kernel[]: [ 14.311864] ath: Country alpha2 being used: 00
2019-01-19 08:12:07 debug kernel[]: [ 14.311869] ath: Regpair used: 0x65
2019-01-19 08:12:07 debug kernel[]: [ 14.327090] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
2019-01-19 08:12:07 info kernel[]: [ 14.329056] ieee80211 phy1: Atheros AR9280 Rev:2 mem=0xe3f20000, irq=37
2019-01-19 08:12:07 info kernel[]: [ 14.342575] usbcore: registered new interface driver option
2019-01-19 08:12:07 info kernel[]: [ 14.348251] usbserial: USB Serial support registered for GSM modem (1-port)
2019-01-19 08:12:07 info kernel[]: [ 20.059722] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
2019-01-19 08:12:07 info kernel[]: [ 20.063488] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2019-01-19 08:12:07 info kernel[]: [ 20.066510] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
2019-01-19 08:12:07 info kernel[]: [ 22.063163] fsl-gianfar ffe24000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
2019-01-19 08:12:07 info kernel[]: [ 22.063244] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
2019-01-19 08:12:07 info kernel[]: [ 22.066989] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
2019-01-19 08:12:07 info kernel[]: [ 22.067005] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
2019-01-19 08:12:07 info kernel[]: [ 24.424952] device eth0 entered promiscuous mode
2019-01-19 08:12:07 info kernel[]: [ 24.426173] br-lan: port 1(eth0) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 24.426203] br-lan: port 1(eth0) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 24.457243] device eth1 entered promiscuous mode
2019-01-19 08:12:07 info kernel[]: [ 24.457297] br-lan: port 2(eth1) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 24.457317] br-lan: port 2(eth1) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 24.461234] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
2019-01-19 08:12:07 debug kernel[]: [ 24.736823] ath: EEPROM regdomain: 0x80cb
2019-01-19 08:12:07 debug kernel[]: [ 24.736833] ath: EEPROM indicates we should expect a country code
2019-01-19 08:12:07 debug kernel[]: [ 24.736838] ath: doing EEPROM country->regdmn map search
2019-01-19 08:12:07 debug kernel[]: [ 24.736843] ath: country maps to regdmn code: 0x36
2019-01-19 08:12:07 debug kernel[]: [ 24.736848] ath: Country alpha2 being used: CZ
2019-01-19 08:12:07 debug kernel[]: [ 24.736852] ath: Regpair used: 0x36
2019-01-19 08:12:07 debug kernel[]: [ 24.736857] ath: regdomain 0x80cb dynamically updated by user
2019-01-19 08:12:07 debug kernel[]: [ 24.736951] ath: EEPROM regdomain: 0x80cb
2019-01-19 08:12:07 debug kernel[]: [ 24.736956] ath: EEPROM indicates we should expect a country code
2019-01-19 08:12:07 debug kernel[]: [ 24.737011] ath: doing EEPROM country->regdmn map search
2019-01-19 08:12:07 debug kernel[]: [ 24.737016] ath: country maps to regdmn code: 0x36
2019-01-19 08:12:07 debug kernel[]: [ 24.737020] ath: Country alpha2 being used: CZ
2019-01-19 08:12:07 debug kernel[]: [ 24.737024] ath: Regpair used: 0x36
2019-01-19 08:12:07 debug kernel[]: [ 24.737029] ath: regdomain 0x80cb dynamically updated by user
2019-01-19 08:12:07 info kernel[]: [ 26.066178] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
2019-01-19 08:12:07 info kernel[]: [ 26.097851] device wlan1 entered promiscuous mode
2019-01-19 08:12:07 info kernel[]: [ 26.097907] br-lan: port 3(wlan1) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 26.097929] br-lan: port 3(wlan1) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 26.426050] br-lan: port 3(wlan1) entered disabled state
2019-01-19 08:12:07 info kernel[]: [ 26.427231] fsl-gianfar ffe24000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
2019-01-19 08:12:07 info kernel[]: [ 26.428971] br-lan: port 1(eth0) entered forwarding state
2019-01-19 08:12:07 info kernel[]: [ 26.459030] fsl-gianfar ffe25000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
2019-01-19 08:12:07 info kernel[]: [ 26.460979] br-lan: port 2(eth1) entered forwarding state
2019-01-19 08:12:09 notice netifd[]: radio1 (4676): 20/40 MHz operation not permitted on channel pri=11 sec=7 based on overlapping BSSes
2019-01-19 08:12:09 notice netifd[]: radio1 (4676): Using interface wlan1 with hwaddr 70:1a:04:36:90:25 and ssid "WIFI-H-2.4GHz"
2019-01-19 08:12:09 info kernel[]: [ 27.844657] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
2019-01-19 08:12:09 info kernel[]: [ 27.844767] br-lan: port 3(wlan1) entered forwarding state
2019-01-19 08:12:09 info kernel[]: [ 27.844801] br-lan: port 3(wlan1) entered forwarding state
2019-01-19 08:12:09 notice netifd[]: radio1 (4676): wlan1: interface state HT_SCAN->ENABLED
2019-01-19 08:12:09 notice netifd[]: radio1 (4676): wlan1: AP-ENABLED
2019-01-19 08:12:09 notice netifd[]: Network device 'wlan1' link is up
2019-01-19 08:12:10 emerg turris[]: Router Turris successfully started.
2019-01-19 08:12:10 info procd[]: - init complete -
2019-01-19 08:12:11 info kernel[]: [ 29.844981] br-lan: port 3(wlan1) entered forwarding state
2019-01-19 08:12:18 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001222d8b973085a99641aa on br-lan: no addresses available
2019-01-19 08:12:18 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:12:18 info dnsmasq[4855]: started, version 2.78 DNS disabled
2019-01-19 08:12:18 warning dnsmasq[4855]: overflow: 4 log entries lost
2019-01-19 08:12:19 info dnsmasq-dhcp[4855]: DHCPREQUEST(br-lan) 192.168.1.121 30:85:a9:96:41:aa
2019-01-19 08:12:19 info dnsmasq-dhcp[4855]: DHCPACK(br-lan) 192.168.1.121 30:85:a9:96:41:aa DEJVID-PC
2019-01-19 08:12:19 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001222d8b973085a99641aa on br-lan: no addresses available
2019-01-19 08:12:22 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:12:22 notice netifd[]: Network device 'eth2' link is up
2019-01-19 08:12:22 notice netifd[]: Interface 'wan' has link connectivity
2019-01-19 08:12:22 notice netifd[]: Interface 'wan' is setting up now
2019-01-19 08:12:22 info kernel[]: [ 41.495348] fsl-gianfar ffe26000.ethernet eth2: Link is Up - 100Mbps/Full - flow control off
2019-01-19 08:12:22 info kernel[]: [ 41.495374] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
2019-01-19 08:12:23 notice netifd[]: wan (5457): udhcpc: started, v1.29.3
2019-01-19 08:12:23 notice netifd[]: wan (5457): udhcpc: sending discover
2019-01-19 08:12:26 notice netifd[4653]: Last message 'wan (5457): udhcpc: ' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:12:26 notice netifd[]: wan (5457): udhcpc: sending select for 92.240.162.2
2019-01-19 08:12:27 notice netifd[]: wan (5457): udhcpc: lease of 92.240.162.2 obtained, lease time 14400
2019-01-19 08:12:27 notice netifd[]: Interface 'wan6' is enabled
2019-01-19 08:12:27 notice netifd[]: Network alias 'eth2' link is up
2019-01-19 08:12:27 notice netifd[]: Interface 'wan6' has link connectivity
2019-01-19 08:12:27 notice netifd[]: Interface 'wan6' is setting up now
2019-01-19 08:12:27 notice netifd[]: Interface 'wan' is now up
2019-01-19 08:12:27 notice firewall[]: Reloading firewall due to ifup of wan (eth2)
2019-01-19 08:12:27 info dnsmasq[4855]: exiting on receipt of SIGTERM
2019-01-19 08:12:27 info dnsmasq[5682]: started, version 2.78 DNS disabled
2019-01-19 08:12:27 info dnsmasq[5682]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
2019-01-19 08:12:27 info dnsmasq-dhcp[5682]: DHCP, IP range 192.168.1.100 -- 192.168.1.254, lease time 12h
2019-01-19 08:12:27 info dnsmasq-dhcp[5682]: read /etc/ethers - 0 addresses
2019-01-19 08:12:28 info unbound[]: [4799:0] info: service stopped (unbound 1.8.3).
2019-01-19 08:12:28 info unbound[]: [5755:0] info: start of service (unbound 1.8.3).
2019-01-19 08:13:01 info /usr/sbin/cron[6566]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:14:01 info /usr/sbin/cron[6783]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:14:01 info /usr/sbin/cron[6782]: (root) CMD (nethist_stats.lua)
2019-01-19 08:14:19 info kernel[]: [ 157.828402] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
2019-01-19 08:14:35 err foris-controller[4843]: WARNING:turrishw:unsupported model: TURRIS
2019-01-19 08:14:39 err foris-controller[4653]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:14:41 err foris-controller[4843]: WARNING:turrishw:unsupported model: TURRIS
2019-01-19 08:14:46 err foris-controller[4653]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:14:52 err foris-controller[4843]: WARNING:turrishw:unsupported model: TURRIS
2019-01-19 08:14:56 err foris-controller[4653]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:15:01 info /usr/sbin/cron[6951]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:15:01 info /usr/sbin/cron[6952]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:15:08 err foris-controller[4843]: WARNING:turrishw:unsupported model: TURRIS
2019-01-19 08:15:12 err foris-controller[4653]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:16:01 info /usr/sbin/cron[7140]: (root) CMD (nethist_stats.lua)
2019-01-19 08:16:01 info /usr/sbin/cron[7141]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:17:01 info /usr/sbin/cron[7248]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:18:01 info /usr/sbin/cron[7309]: (root) CMD (nethist_stats.lua)
2019-01-19 08:18:01 info /usr/sbin/cron[7310]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:18:07 err foris-controller[4843]: WARNING:turrishw:unsupported model: TURRIS
2019-01-19 08:18:11 err foris-controller[4653]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:18:22 err foris-controller[4843]: WARNING:turrishw:unsupported model: TURRIS
2019-01-19 08:18:27 err foris-controller[4653]: Last message 'WARNING:turrishw:uns' repeated 1 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 08:19:01 info /usr/sbin/cron[7479]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:20:01 info /usr/sbin/cron[7523]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:20:01 info /usr/sbin/cron[7524]: (root) CMD (nethist_stats.lua)
2019-01-19 08:20:01 info /usr/sbin/cron[7525]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:21:01 info /usr/sbin/cron[7600]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:22:01 info /usr/sbin/cron[7643]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:22:01 info /usr/sbin/cron[7642]: (root) CMD (nethist_stats.lua)
2019-01-19 08:23:01 info /usr/sbin/cron[7685]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:24:01 info /usr/sbin/cron[7728]: (root) CMD (nethist_stats.lua)
2019-01-19 08:24:01 info /usr/sbin/cron[7730]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:25:01 info /usr/sbin/cron[7772]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:25:01 info /usr/sbin/cron[7773]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:26:01 info /usr/sbin/cron[7850]: (root) CMD (nethist_stats.lua)
2019-01-19 08:26:01 info /usr/sbin/cron[7851]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:27:01 info /usr/sbin/cron[7892]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:28:01 info /usr/sbin/cron[7937]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:28:01 info /usr/sbin/cron[7936]: (root) CMD (nethist_stats.lua)
2019-01-19 08:29:01 info /usr/sbin/cron[7979]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:30:01 info /usr/sbin/cron[8023]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:30:01 info /usr/sbin/cron[8021]: (root) CMD (nethist_stats.lua)
2019-01-19 08:30:01 info /usr/sbin/cron[8026]: (root) CMD (/usr/bin/get-api-crl)
2019-01-19 08:30:01 info /usr/sbin/cron[8028]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:31:01 info /usr/sbin/cron[8105]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:32:01 info /usr/sbin/cron[8149]: (root) CMD (nethist_stats.lua)
2019-01-19 08:32:01 info /usr/sbin/cron[8150]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:33:01 info /usr/sbin/cron[8192]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:34:01 info /usr/sbin/cron[8234]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:34:01 info /usr/sbin/cron[8235]: (root) CMD (nethist_stats.lua)
2019-01-19 08:34:31 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c IEEE 802.11: authenticated
2019-01-19 08:34:31 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c IEEE 802.11: associated (aid 1)
2019-01-19 08:34:31 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c RADIUS: starting accounting session 2A730D04EFD7DE5B
2019-01-19 08:34:31 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c WPA: pairwise key handshake completed (RSN)
2019-01-19 08:34:35 info dnsmasq-dhcp[5682]: DHCPDISCOVER(br-lan) cc:fd:17:f0:be:8c
2019-01-19 08:34:35 info dnsmasq-dhcp[5682]: DHCPOFFER(br-lan) 192.168.1.154 cc:fd:17:f0:be:8c
2019-01-19 08:34:35 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.154 cc:fd:17:f0:be:8c
2019-01-19 08:34:35 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.154 cc:fd:17:f0:be:8c android-2827836216eaf3ab
2019-01-19 08:35:01 info /usr/sbin/cron[8279]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:35:01 info /usr/sbin/cron[8282]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:36:01 info /usr/sbin/cron[8358]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:36:01 info /usr/sbin/cron[8357]: (root) CMD (nethist_stats.lua)
2019-01-19 08:37:01 info /usr/sbin/cron[8400]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:38:01 info /usr/sbin/cron[8444]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:38:01 info /usr/sbin/cron[8443]: (root) CMD (nethist_stats.lua)
2019-01-19 08:39:01 info /usr/sbin/cron[8488]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:40:01 info /usr/sbin/cron[8531]: (root) CMD (nethist_stats.lua)
2019-01-19 08:40:01 info /usr/sbin/cron[8533]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:40:01 info /usr/sbin/cron[8534]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:41:01 info /usr/sbin/cron[8609]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:42:01 info /usr/sbin/cron[8651]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:42:01 info /usr/sbin/cron[8652]: (root) CMD (nethist_stats.lua)
2019-01-19 08:42:09 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c WPA: group key handshake completed (RSN)
2019-01-19 08:43:01 info /usr/sbin/cron[8694]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:44:01 info /usr/sbin/cron[8737]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:44:01 info /usr/sbin/cron[8736]: (root) CMD (nethist_stats.lua)
2019-01-19 08:45:01 info /usr/sbin/cron[8780]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:45:01 info /usr/sbin/cron[8781]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:46:01 info /usr/sbin/cron[8858]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:46:01 info /usr/sbin/cron[8857]: (root) CMD (nethist_stats.lua)
2019-01-19 08:47:01 info /usr/sbin/cron[8901]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:48:01 info /usr/sbin/cron[8945]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:48:01 info /usr/sbin/cron[8944]: (root) CMD (nethist_stats.lua)
2019-01-19 08:49:01 info /usr/sbin/cron[8987]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:50:01 info /usr/sbin/cron[9032]: (root) CMD (nethist_stats.lua)
2019-01-19 08:50:01 info /usr/sbin/cron[9034]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:50:01 info /usr/sbin/cron[9037]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:51:01 info /usr/sbin/cron[9110]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:52:01 info /usr/sbin/cron[9152]: (root) CMD (nethist_stats.lua)
2019-01-19 08:52:01 info /usr/sbin/cron[9153]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:53:01 info /usr/sbin/cron[9195]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:54:01 info /usr/sbin/cron[9237]: (root) CMD (nethist_stats.lua)
2019-01-19 08:54:01 info /usr/sbin/cron[9239]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:55:01 info /usr/sbin/cron[9282]: (root) CMD ( /usr/bin/notifier)
2019-01-19 08:55:01 info /usr/sbin/cron[9281]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:56:01 info /usr/sbin/cron[9359]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:56:01 info /usr/sbin/cron[9358]: (root) CMD (nethist_stats.lua)
2019-01-19 08:57:01 info /usr/sbin/cron[9401]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:58:01 info /usr/sbin/cron[9443]: (root) CMD (nethist_stats.lua)
2019-01-19 08:58:01 info /usr/sbin/cron[9444]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 08:59:01 info /usr/sbin/cron[9486]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:00:01 info /usr/sbin/cron[9531]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2019-01-19 09:00:01 info /usr/sbin/cron[9529]: (root) CMD (nethist_stats.lua)
2019-01-19 09:00:01 info /usr/sbin/cron[9539]: (root) CMD (/usr/bin/get-api-crl)
2019-01-19 09:00:01 info /usr/sbin/cron[9538]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2019-01-19 09:00:01 info /usr/sbin/cron[9534]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:00:01 info /usr/sbin/cron[9543]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2019-01-19 09:00:01 info /usr/sbin/cron[9540]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:00:01 err server_uplink[]: Failed to download contract status
2019-01-19 09:01:01 info /usr/sbin/cron[9636]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:01:01 err server_uplink[]: Failed to get registration code
2019-01-19 09:02:01 info /usr/sbin/cron[9680]: (root) CMD (nethist_stats.lua)
2019-01-19 09:02:01 info /usr/sbin/cron[9681]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:03:01 info /usr/sbin/cron[9723]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:04:01 info /usr/sbin/cron[9765]: (root) CMD (nethist_stats.lua)
2019-01-19 09:04:01 info /usr/sbin/cron[9766]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:05:01 info /usr/sbin/cron[9809]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:05:01 info /usr/sbin/cron[9810]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:06:01 info /usr/sbin/cron[9887]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:06:01 info /usr/sbin/cron[9886]: (root) CMD (nethist_stats.lua)
2019-01-19 09:07:01 info /usr/sbin/cron[9929]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:08:01 info /usr/sbin/cron[9974]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:08:01 info /usr/sbin/cron[9973]: (root) CMD (nethist_stats.lua)
2019-01-19 09:08:11 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: authenticated
2019-01-19 09:08:11 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: associated (aid 1)
2019-01-19 09:08:11 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c RADIUS: starting accounting session 8DDB1609F0BC9144
2019-01-19 09:08:11 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c WPA: pairwise key handshake completed (RSN)
2019-01-19 09:08:12 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.105 98:9e:63:5d:aa:6c
2019-01-19 09:08:12 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.105 98:9e:63:5d:aa:6c iPhone
2019-01-19 09:08:14 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:08:20 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 2 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:08:21 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:08:29 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:08:45 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:09:01 info /usr/sbin/cron[10020]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:09:15 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:10:01 info /usr/sbin/cron[10065]: (root) CMD (nethist_stats.lua)
2019-01-19 09:10:01 info /usr/sbin/cron[10064]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:10:01 info /usr/sbin/cron[10066]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:10:18 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:11:01 info /usr/sbin/cron[10142]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:12:01 info /usr/sbin/cron[10187]: (root) CMD (nethist_stats.lua)
2019-01-19 09:12:01 info /usr/sbin/cron[10191]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2019-01-19 09:12:01 info /usr/sbin/cron[10189]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:12:09 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c WPA: group key handshake completed (RSN)
2019-01-19 09:12:16 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:13:01 info /usr/sbin/cron[10232]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:14:01 info /usr/sbin/cron[10274]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:14:01 info /usr/sbin/cron[10275]: (root) CMD (nethist_stats.lua)
2019-01-19 09:14:24 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:15:01 info /usr/sbin/cron[10320]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:15:01 info /usr/sbin/cron[10321]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:16:01 info /usr/sbin/cron[10399]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:16:01 info /usr/sbin/cron[10398]: (root) CMD (nethist_stats.lua)
2019-01-19 09:16:17 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:17:01 info /usr/sbin/cron[10442]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:18:01 info /usr/sbin/cron[10485]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:18:01 info /usr/sbin/cron[10484]: (root) CMD (nethist_stats.lua)
2019-01-19 09:18:19 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:19:01 info /usr/sbin/cron[10528]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:20:01 info /usr/sbin/cron[10574]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:20:01 info /usr/sbin/cron[10571]: (root) CMD (nethist_stats.lua)
2019-01-19 09:20:01 info /usr/sbin/cron[10573]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:20:09 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:21:01 info /usr/sbin/cron[10649]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:22:01 info /usr/sbin/cron[10692]: (root) CMD (nethist_stats.lua)
2019-01-19 09:22:01 info /usr/sbin/cron[10693]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:22:09 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c WPA: group key handshake completed (RSN)
2019-01-19 09:22:14 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:23:01 info /usr/sbin/cron[10737]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:24:01 info /usr/sbin/cron[10781]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:24:01 info /usr/sbin/cron[10780]: (root) CMD (nethist_stats.lua)
2019-01-19 09:24:25 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:25:01 info /usr/sbin/cron[10826]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:25:01 info /usr/sbin/cron[10825]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:26:01 info /usr/sbin/cron[10902]: (root) CMD (nethist_stats.lua)
2019-01-19 09:26:01 info /usr/sbin/cron[10903]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:26:23 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:27:01 info /usr/sbin/cron[10940]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:28:01 info /usr/sbin/cron[10981]: (root) CMD (nethist_stats.lua)
2019-01-19 09:28:01 info /usr/sbin/cron[10982]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:29:01 info /usr/sbin/cron[11024]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:29:05 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: disassociated
2019-01-19 09:29:06 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2019-01-19 09:30:01 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:30:01 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:30:01 info /usr/sbin/cron[11073]: (root) CMD (/usr/bin/get-api-crl)
2019-01-19 09:30:01 info /usr/sbin/cron[11072]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:30:01 info /usr/sbin/cron[11069]: (root) CMD (nethist_stats.lua)
2019-01-19 09:30:01 info /usr/sbin/cron[11074]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:30:01 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 09:30:05 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:30:05 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:30:05 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:30:13 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:30:13 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:30:46 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:30:46 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:31:01 info /usr/sbin/cron[11151]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:32:01 info /usr/sbin/cron[11194]: (root) CMD (nethist_stats.lua)
2019-01-19 09:32:01 info /usr/sbin/cron[11195]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:33:01 info /usr/sbin/cron[11237]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:33:16 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:33:16 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:34:01 info /usr/sbin/cron[11283]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:34:01 info /usr/sbin/cron[11284]: (root) CMD (nethist_stats.lua)
2019-01-19 09:35:01 info /usr/sbin/cron[11327]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:35:01 info /usr/sbin/cron[11330]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:35:02 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 09:35:07 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:35:26 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:35:26 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:36:01 info /usr/sbin/cron[11405]: (root) CMD (nethist_stats.lua)
2019-01-19 09:36:01 info /usr/sbin/cron[11406]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:36:34 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:36:34 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:37:01 info /usr/sbin/cron[11449]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:37:03 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: authenticated
2019-01-19 09:37:03 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: associated (aid 1)
2019-01-19 09:37:03 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c RADIUS: starting accounting session DE8A0A91290A5DC8
2019-01-19 09:37:03 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c WPA: pairwise key handshake completed (RSN)
2019-01-19 09:37:03 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.105 98:9e:63:5d:aa:6c
2019-01-19 09:37:03 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.105 98:9e:63:5d:aa:6c iPhone
2019-01-19 09:37:05 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:37:11 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 2 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:37:13 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:37:21 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:37:38 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:38:01 info /usr/sbin/cron[11493]: (root) CMD (nethist_stats.lua)
2019-01-19 09:38:01 info /usr/sbin/cron[11494]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:38:11 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 09:38:39 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: disassociated
2019-01-19 09:38:40 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2019-01-19 09:39:01 info /usr/sbin/cron[11538]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:40:01 info /usr/sbin/cron[11581]: (root) CMD (nethist_stats.lua)
2019-01-19 09:40:01 info /usr/sbin/cron[11583]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:40:01 info /usr/sbin/cron[11584]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:40:03 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 09:40:08 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:40:13 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:40:13 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:41:01 info /usr/sbin/cron[11659]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:41:16 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 09:41:16 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 09:42:01 info /usr/sbin/cron[11704]: (root) CMD (nethist_stats.lua)
2019-01-19 09:42:01 info /usr/sbin/cron[11705]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:43:01 info /usr/sbin/cron[11747]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:44:01 info /usr/sbin/cron[11792]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:44:01 info /usr/sbin/cron[11791]: (root) CMD (nethist_stats.lua)
2019-01-19 09:45:01 info /usr/sbin/cron[11837]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:45:01 info /usr/sbin/cron[11838]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:45:04 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 09:45:09 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:46:01 info /usr/sbin/cron[11915]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:46:01 info /usr/sbin/cron[11914]: (root) CMD (nethist_stats.lua)
2019-01-19 09:47:01 info /usr/sbin/cron[11957]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:48:01 info /usr/sbin/cron[11999]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:48:01 info /usr/sbin/cron[12000]: (root) CMD (nethist_stats.lua)
2019-01-19 09:49:01 info /usr/sbin/cron[12043]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:50:01 info /usr/sbin/cron[12088]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:50:01 info /usr/sbin/cron[12086]: (root) CMD (nethist_stats.lua)
2019-01-19 09:50:01 info /usr/sbin/cron[12091]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:50:05 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 09:50:10 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:51:01 info /usr/sbin/cron[12164]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:52:01 info /usr/sbin/cron[12207]: (root) CMD (nethist_stats.lua)
2019-01-19 09:52:01 info /usr/sbin/cron[12208]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:53:01 info /usr/sbin/cron[12250]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:54:01 info /usr/sbin/cron[12292]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:54:01 info /usr/sbin/cron[12293]: (root) CMD (nethist_stats.lua)
2019-01-19 09:55:01 info /usr/sbin/cron[12337]: (root) CMD ( /usr/bin/notifier)
2019-01-19 09:55:01 info /usr/sbin/cron[12336]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:55:06 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 09:55:11 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 09:56:01 info /usr/sbin/cron[12415]: (root) CMD (nethist_stats.lua)
2019-01-19 09:56:01 info /usr/sbin/cron[12416]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:57:01 info /usr/sbin/cron[12457]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:58:01 info /usr/sbin/cron[12500]: (root) CMD (nethist_stats.lua)
2019-01-19 09:58:01 info /usr/sbin/cron[12501]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 09:59:01 info /usr/sbin/cron[12543]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:00:01 info /usr/sbin/cron[12588]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2019-01-19 10:00:01 info /usr/sbin/cron[12586]: (root) CMD (nethist_stats.lua)
2019-01-19 10:00:01 info /usr/sbin/cron[12594]: (root) CMD (/usr/bin/get-api-crl)
2019-01-19 10:00:01 info /usr/sbin/cron[12598]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:00:01 info /usr/sbin/cron[12596]: (root) CMD ( /usr/bin/notifier)
2019-01-19 10:00:01 info /usr/sbin/cron[12599]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2019-01-19 10:00:01 info /usr/sbin/cron[12600]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2019-01-19 10:00:01 err server_uplink[]: Failed to download contract status
2019-01-19 10:00:07 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 10:00:12 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:00:14 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 10:00:14 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 10:01:01 info /usr/sbin/cron[12690]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:02:01 info /usr/sbin/cron[12733]: (root) CMD (nethist_stats.lua)
2019-01-19 10:02:01 info /usr/sbin/cron[12734]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:03:01 info /usr/sbin/cron[12776]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:03:21 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 10:03:21 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 10:04:01 info /usr/sbin/cron[12820]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:04:01 info /usr/sbin/cron[12819]: (root) CMD (nethist_stats.lua)
2019-01-19 10:05:01 info /usr/sbin/cron[12863]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:05:01 info /usr/sbin/cron[12865]: (root) CMD ( /usr/bin/notifier)
2019-01-19 10:05:08 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 10:05:13 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:06:01 info /usr/sbin/cron[12940]: (root) CMD (nethist_stats.lua)
2019-01-19 10:06:01 info /usr/sbin/cron[12941]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:07:01 info /usr/sbin/cron[12985]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:08:01 info /usr/sbin/cron[13028]: (root) CMD (nethist_stats.lua)
2019-01-19 10:08:01 info /usr/sbin/cron[13029]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:08:26 info dnsmasq-dhcp[5682]: DHCPINFORM(br-lan) 192.168.1.182 44:8a:5b:59:92:35
2019-01-19 10:08:26 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.182 44:8a:5b:59:92:35 NADA-HOME-PC
2019-01-19 10:09:01 info /usr/sbin/cron[13072]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:10:01 info /usr/sbin/cron[13116]: (root) CMD (nethist_stats.lua)
2019-01-19 10:10:01 info /usr/sbin/cron[13118]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:10:01 info /usr/sbin/cron[13121]: (root) CMD ( /usr/bin/notifier)
2019-01-19 10:10:09 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 10:10:14 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:11:01 info /usr/sbin/cron[13194]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:12:01 info /usr/sbin/cron[13240]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
2019-01-19 10:12:01 info /usr/sbin/cron[13239]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:12:01 info /usr/sbin/cron[13237]: (root) CMD (nethist_stats.lua)
2019-01-19 10:12:27 notice netifd[]: wan (5457): udhcpc: sending renew to 172.25.8.4
2019-01-19 10:12:27 notice netifd[]: wan (5457): udhcpc: lease of 92.240.162.2 obtained, lease time 14400
2019-01-19 10:13:01 info /usr/sbin/cron[13289]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:13:41 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: authenticated
2019-01-19 10:13:41 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: associated (aid 1)
2019-01-19 10:13:41 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c RADIUS: starting accounting session 09C0F4D3524D15F2
2019-01-19 10:13:41 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c WPA: pairwise key handshake completed (RSN)
2019-01-19 10:13:41 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.105 98:9e:63:5d:aa:6c
2019-01-19 10:13:41 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.105 98:9e:63:5d:aa:6c iPhone
2019-01-19 10:13:42 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 10:13:47 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 2 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:13:49 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 10:13:58 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 10:14:01 info /usr/sbin/cron[13334]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:14:01 info /usr/sbin/cron[13333]: (root) CMD (nethist_stats.lua)
2019-01-19 10:14:14 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001213d6e83989e635daa6c on br-lan: no addresses available
2019-01-19 10:14:22 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: disassociated
2019-01-19 10:14:23 info hostapd[]: wlan1: STA 98:9e:63:5d:aa:6c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2019-01-19 10:15:01 info /usr/sbin/cron[13377]: (root) CMD ( /usr/bin/notifier)
2019-01-19 10:15:01 info /usr/sbin/cron[13378]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:15:10 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 10:15:15 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:16:01 info /usr/sbin/cron[13455]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:16:01 info /usr/sbin/cron[13454]: (root) CMD (nethist_stats.lua)
2019-01-19 10:17:01 info /usr/sbin/cron[13497]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:18:01 info /usr/sbin/cron[13542]: (root) CMD (nethist_stats.lua)
2019-01-19 10:18:01 info /usr/sbin/cron[13543]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:18:42 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c IEEE 802.11: authenticated
2019-01-19 10:18:42 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c IEEE 802.11: associated (aid 1)
2019-01-19 10:18:43 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c RADIUS: starting accounting session 2E1BBCEE47F14958
2019-01-19 10:18:43 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c WPA: pairwise key handshake completed (RSN)
2019-01-19 10:18:43 info dnsmasq-dhcp[5682]: DHCPDISCOVER(br-lan) cc:fd:17:f0:be:8c
2019-01-19 10:18:43 info dnsmasq-dhcp[5682]: DHCPOFFER(br-lan) 192.168.1.154 cc:fd:17:f0:be:8c
2019-01-19 10:18:43 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.154 cc:fd:17:f0:be:8c
2019-01-19 10:18:43 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.154 cc:fd:17:f0:be:8c android-2827836216eaf3ab
2019-01-19 10:19:01 info /usr/sbin/cron[13586]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:20:01 info /usr/sbin/cron[13629]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:20:01 info /usr/sbin/cron[13630]: (root) CMD (nethist_stats.lua)
2019-01-19 10:20:01 info /usr/sbin/cron[13631]: (root) CMD ( /usr/bin/notifier)
2019-01-19 10:20:11 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 000100011bf12454448a5b599235 on br-lan: no addresses available
2019-01-19 10:20:16 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:21:01 info /usr/sbin/cron[13706]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:22:01 info /usr/sbin/cron[13748]: (root) CMD (nethist_stats.lua)
2019-01-19 10:22:01 info /usr/sbin/cron[13749]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:22:09 info hostapd[]: wlan1: STA cc:fd:17:f0:be:8c WPA: group key handshake completed (RSN)
2019-01-19 10:22:46 info dnsmasq-dhcp[5682]: DHCPREQUEST(br-lan) 192.168.1.121 30:85:a9:96:41:aa
2019-01-19 10:22:46 info dnsmasq-dhcp[5682]: DHCPACK(br-lan) 192.168.1.121 30:85:a9:96:41:aa DEJVID-PC
2019-01-19 10:22:46 warning odhcpd[4536]: DHCPV6 SOLICIT IA_NA from 00010001222d8b973085a99641aa on br-lan: no addresses available
2019-01-19 10:22:51 warning odhcpd[4653]: Last message 'DHCPV6 SOLICIT IA_NA' repeated 6 times, suppressed by syslog-ng on TURRUS-CL
2019-01-19 10:23:01 info /usr/sbin/cron[13793]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-19 10:24:01 info /usr/sbin/cron[13836]: (root) CMD (nethist_stats.lua)
2019-01-19 10:24:01 info /usr/sbin/cron[13837]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
