I received this SFP module for my Turris Omnia to connect to my ISP (Telecom/Germany).
I followed this guide for the settings. Sadly this didn’t completely work:
After some further research, I found this thread which seems quiet related to my issues. I was able to follow until it was suggested to execute this command:
/etc/init.d/sfpswitch enable; /etc/init.d/sfpswitch restart && /etc/init.d/network reload && echo 'Success' || echo 'Failed'
For some reason sfpswitch is not present on my installation:
root@turris:~# /etc/init.d/sfpswitch enable; /etc/init.d/sfpswitch restart && /etc/init.d/network reload && echo 'Success' || echo 'Failed'
-ash: /etc/init.d/sfpswitch: not found
Failed
I was not able to figure out, why this is missing or how I can install it. Prior to the manual upgrade to Foris 101.1.1 this was present. I did the upgrade because the first thread I mentioned suggested, that this SFP module will only work on updated versions. I didn’t get it to work on this version (it was 95.x) so I flashed the most recent version.
Does anybody know why I am missing sfpswitch or what else I could try to establish the connection to my ISP?
Here are some infos on my configuration:
root@turris:~# cat /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd4a:4d2b:4284::/48'
config interface 'lan'
option type 'bridge'
option ipaddr '192.168.1.1'
option ip6assign '60'
option bridge_empty '1'
list ifname 'lan0'
list ifname 'lan1'
list ifname 'lan2'
list ifname 'lan3'
list ifname 'lan4'
option netmask '255.255.0.0'
config interface 'wan'
option proto 'pppoe'
option password '...'
option ipv6 'auto'
option ifname 'eth1.7'
option username '...@t-online.de'
config interface 'wan6'
option proto 'dhcpv6'
option ifname '@wan'
option enabled '1'
option ipaddr '10.111.222.1'
And here the tail of my log
Feb 18 22:02:39 turris insmod: module is already loaded - ppp_generic
Feb 18 22:02:39 turris insmod: module is already loaded - pppox
Feb 18 22:02:39 turris insmod: module is already loaded - pppoe
Feb 18 22:02:39 turris netifd: wan (3801): ppp: warning: Sleeping for '10' seconds
Feb 18 22:02:49 turris pppd[4089]: Plugin rp-pppoe.so loaded.
Feb 18 22:02:49 turris pppd[4089]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
Feb 18 22:02:50 turris pppd[4089]: pppd 2.4.7 started by root, uid 0
Feb 18 22:03:05 turris pppd[4089]: Timeout waiting for PADO packets
Feb 18 22:03:05 turris pppd[4089]: Unable to complete PPPoE Discovery
Feb 18 22:03:05 turris pppd[4089]: Exit.
Thanks in advance.
