Possible to use Turris Omnia as WIFI Repeater?
Hi there.
My question: It is Possible to use Turris Omnia as WIFI Repeater?
[Modem+WIFI] <2.4Ghz/5Ghz> [Turris Omnia] <2.4Ghz/5Ghz> [Client]
thx
Which modem it is? I think first modem+wifi needs to have wifi bridging.
hi,
Standard modem from provider.
I use AVM FRITZ!WLAN Repeater 1750E and works fine with any Modem+WIFI without wifi bridging.
If Turris Omnia can work as WIFI Repeater so i can replace my FRITZ!WLAN Repeater.
it’s possible, it’s just some configuration effort:
https://wiki.openwrt.org/doc/recipes/relayclient or if your provider’s router supports WDS: https://wiki.openwrt.org/doc/recipes/atheroswds and if everything fails: https://wiki.openwrt.org/doc/recipes/routedclient
Thanks.
I hope i can configure it. :smiley:
Or if everything fails, Omnia has two WiFis, so you can use one as client and other as AP. Or you can even put in third WiFi :slight_smile:
Got my Turris Omnia (btw. great device) yesterday.
Added Linksys WUSB600N v2 Dual-Band Wireless-N Network Adapter [Ralink RT3572] as third WIFI and it works fine.
thx @ll
