Hello
I was thinking of using a lxc container as a test/dev server for easyengine v4.
The install script failed to install Docker on the Bionic container I set up. I realize that running Docker in a container is a bit redundant but I would prefer to not install Docker on the Omnia directly since it is not supported officially(yet??).
My question is this. Did the Docker install inside lxc container fail from host(Omnia/openwrt) kernel support or did it fail because the Bionic container from Turris lack support for Docker. Has anyone done this or aware of a container with docker preinstalled?
I hope I am being clear. Curious as to the communities thoughts on running easyengine v4 inside an lxc container.
Thank you
