Pkgupdate doesn't work after installing strongswan-full
Omnia Turris 4.0.3
Executing opkg update && opkg install strongswan-full && pkgupdate produces following:
INFO:Target Turris OS: 4.0.3
line not found
line not found
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Package strongswan-mod-mysql requires package libmysqlclient-r that is not available.
I’ve installed libmariadbclient which should provide libmysqlclient-r, but it doesn’t help with pkgupdate
Package: libmariadbclient
Version: 10.4.10-3.4
Depends: libc, libatomic, libopenssl, libstdcpp, zlib
Provides: libmysqlclient, libmysqlclient-r
Status: install user installed
Section: libs
Architecture: arm_cortex-a9_vfpv3
Filename: libmariadbclient_10.4.10-3_arm_cortex-a9_vfpv3.ipk
Description: MariaDB is a fast, stable and true multi-user, multi-threaded SQL
 database server. SQL (Structured Query Language) is the most popular
 database query language in the world. The main goals of MariaDB are
 speed, robustness and ease of use.
 This package includes the client library.
Installed-Time: 1579345059
I just checked it. It seems like a bug. I can reproduce it.
Thank you for reporting it.
You can track issue for updates.
