Philips Hue Bridge problems?
Is anyone else with a Philips Hue Bridge having problems with it connecting to the Internet through TO? I’ve opened a ticket with Philips but wondering if anyone else using TO has one connected and working with all 3 status lights solid. My 3rd light is always blinking and I can’t always connect to it. UPnP isn’t working right either.
Hi! I’m running the philips hue bridge (attached via lan) without any problems with the turris omnia.
Ok thanks for confirming. No additional configuration was needed? I’m starting to think my Bridge is faulty.
Sometimes the Turris Omnia is a bit stubborn (Spotify Connect, I’m looking at you), but the Hue Bridge was running out-the-box without any configuration.
