I have a more or less no name 32Gb msata ssd, which is gpt with a ext4 file system on a single partition. The issue is - it doesn’t work, it isn’t detected and isn’t showing either in dmesg, /dev or lspci, what more I get the following answer with lspci -v (no matter if msata is in or not).
00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Flags: fast devsel
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Prefetchable memory behind bridge: 00000000-000fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
lspci: Unable to load libkmod resources: error -12
I did follow the instruction properly and the msata is in the correct slot, according to the leds my pci1 and 2 are occupied (as they should). What is also relevant that the msata ssd is detected and auto-mounted in a usb3 enclosure and works fine.
[ 66.240796] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 66.262037] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 66.262216] scsi host2: usb-storage 3-1:1.0
[ 67.261179] scsi 2:0:0:0: Direct-Access KSM-mSAT A.L2-032MS 8105 PQ: 0 ANSI: 6
[ 67.261522] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 67.262596] sd 2:0:0:0: [sda] Spinning up disk...
[ 68.270746] .ready
[ 68.270987] sd 2:0:0:0: [sda] 61865984 512-byte logical blocks: (31.7 GB/29.5 GiB)
[ 68.271194] sd 2:0:0:0: [sda] Write Protect is off
[ 68.271202] sd 2:0:0:0: [sda] Mode Sense: 33 00 00 08
[ 68.271398] sd 2:0:0:0: [sda] No Caching mode page found
[ 68.276725] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 68.287408] sda: sda1
[ 68.288998] sd 2:0:0:0: [sda] Attached SCSI disk
[ 69.201407] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Frankly I am at a loss and can’t really guess the issue here. Is my TO broken?
