Pakon-monitor stops running
#24
Thx @tonyquan and @mpetracek for going deeper into the said issue… My apologies for not getting back… Work and life has been very busy…
Since last week (6/21) when 3.10.2 was installed and rebooted, pakon is behaving well for me… Am I just lucky???
#25
same for me. pakon-monitor has been running without issue for a week now.
#26
Hi there. I have the same problem. Pakon-show in SSH gives a list, but stops working after X timestamp . It basically stopped 2 days after install.
pakon-monitor :not found
In luci it tells me pakon-monitor is running, but on the forris it ‘failed to load data"’,
Not very familiar with debugging.
best, Dikke
#27
@DIKKEHENK pakon has been running stably for me, but one thing i might try is seeing if somehow the pakon data is getting corrupted. If you don’t care about completely deleting the existing pakon data I provided instructions on how to do that here Turris OS 3.10.3 released
If it happens again after resetting the data, it may be something else completely of course.
#28
@tonyquan Ha, thank you. I tried that, but strange enough now , after pakon-show its says no records to show.
I do see in luci>process that python3 /usr/libexec/pakon-light/pakon-monitor.py & python3 /usr/libexec/pakon-light/pakon-handler.py is running.
And all 3 pakon’s are started in luci> startup.
Strange…no clue why it is not showing any records…
#29
I assume you ran
/usr/libexec/pakon-light/create_db.py
where i mentioned it in the reset instructions?
if so, is /var/lib/pakon.db there? That is where the live/newest data lives.
#30
i did this ;
@turris:~# /etc/init.d/pakon-handler stop
@turris:~# /etc/init.d/pakon-monitor stop
@turris:~# rm /var/lib/pakon.db
@turris:~# rm /srv/pakon/*
@turris:~# /usr/libexec/pakon-light/create_db.py
@turris:~# /etc/init.d/pakon-monitor start
@turris:~# /etc/init.d/pakon-handler start
@turris:~# pakon-show
no records to show
turris:~# cd /var/lib
@turris:/tmp/lib# ls
misc netdata pakon.db
#31
how big is the pakon.db file and is it getting updated at all?
if it’s not changing I’m stuck as to why not. might be time to contact tech support.
#32
Pakon acting up again…
Error: database or disk is full
Command failed: Not found
@turris:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/mmcblk0p1 7.3G 2.2G 5.1G 31% /
tmpfs 1010.8M 597.5M 413.2M 59% /tmp
tmpfs 512.0K 0 512.0K 0% /dev
Any advice what to do next???
