Package installation issue on Turris Omnia
The package https-cert fails to install on turris omnia, and the luci software installer shows the file size of the .ipk at 0 bytes. The following is the output of opkg after attempted installation:
Installing https-cert (3) to root…
Collected errors:
  • opkg_download_pkg: Package https-cert is not available from any configured src.
  • opkg_install_pkg: Failed to download https-cert. Perhaps you need to run ‘opkg update’?
  • opkg_install_cmd: Cannot install package https-cert.
I have run opkg update multiple times, it does not work.
We’ll look at it, but what I know that package https-cert was renamed to more appropriate lighttpd-https-cert. Can you try it and let us know that it works for you?
lighttpd-https-cert is already installed on the router.
