I’ll just post my experience of upgrading from 3.11.17 to 5.0.1 FWIW.
My Debian LXC container config migrated over automatically and appeared to have started but could not be reached via SSH or pinged. I tried to restart it a couple of times, sometimes it appeared to start and once failed with the below entries in the log file:
lxc-start 1592136765.939 ERROR lxc_conf - conf.c:run_buffer:342 - Script exited with status 127
lxc-start 1592136765.992 ERROR lxc_conf - conf.c:lxc_create_network:3079 - failed to create netdev
lxc-start 1592136765.992 ERROR lxc_start - start.c:lxc_spawn:935 - failed to create the network
lxc-start 1592136765.992 ERROR lxc_start - start.c:__lxc_start:1192 - failed to spawn 'Debian'
After a while both the Luci & Foris interfaces failed to load with the below error:
/usr/lib/lua/luci/dispatcher.lua:426: /etc/config/luci seems to be corrupt, unable to find section ‘main’
A reboot sorted out both issues.
The reason I upgraded was version 3.11.16 caused my Fire TV stick to go from losing it’s wifi
connection about once a week to once an hour. Only been a few hours but appears to be more reliable now.
@jada4p the automatic update was for sure because you rolled back to state where you have tos3to4 package installed. That package has to be removed if you want to stay on 3.x for time being. It also looks likely that update wasn’t finished. Ten minutes is way short. There is at least five minutes window for ubus timeout before it dies and starts again. This might be the window you saw. pkgupdate during that time just does nothing, prints nothing, just waits. Or rather explain what “ceased to work” means.
@jiberjaber and @conel I am not sure what are the steps to reproduce this. Is it that starting LXC container breaks Luci? I can’t reproduce that at all.
@conel thank you for log from service start. Are you sure that you run LXC migration? It is not executed automatically at the moment (that is going to be fixed with release of Turris OS 5.0.1).
That was probably because of running instance. I don’t think that we should invest time on fixing every single issue caused by system running components from old and new system, reboot is the solution for that. I just don’t want to force it immediately after update.
That is then for sure because you had router set to rc branch in Turris OS 3.x. That is HBT branch in TOS 4.0+ and that already contained TOS 5.0.1 during that time. That is the version with LXC script already included and executed.
By “pkgupdate ceased to work” I mean that it disappeared from filtered
htop display after short time and never appeared again for about one hour.
Another attempt to migrate today. This time I waited for migration to finish more than two hours. No chance, rollback (and removing /usr/bin/updater-supervisor this time, tos3to4 was not found).
Tue Jun 16 14:26:16 CEST 2020
uptime: 14:26:16 up 1 min, load average: 1.36, 0.35, 0.12
openwrt_version: 15.05
turris-version: 3.11.17
branch:
thermometer: CPU: 84
serial-number: xxxxxxxxxxx
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p1 7633920 1362456 6295020 18% /
tmpfs 1035016 21428 1013588 2% /tmp
tmpfs 512 0 512 0% /dev
/dev/sda1 14747216 2346812 11628224 17% /srv/lxc
/dev/sdb1 7304224 19748 6890396 0% /tmp/run/mount/sda1
root@turris:~# schnapps create -t single “Migration 3rd attempt”
Snapshot number 454 created
root@turris:~# schnapps list
# | Type | Size | Date | Description
439 | post | 13.73MiB | 2020-06-02 08:55:40 +0200 | Automatic post-update snapshot
440 | pre | 13.50MiB | 2020-06-04 09:08:21 +0200 | Automatic pre-update snapshot
441 | post | 13.51MiB | 2020-06-04 09:08:25 +0200 | Automatic post-update snapshot
442 | time | 13.55MiB | 2020-06-07 01:05:02 +0200 | Snapshot created by cron
443 | single | 13.51MiB | 2020-06-10 15:45:07 +0200 | Before Migration
444 | pre | 13.51MiB | 2020-06-10 15:47:34 +0200 | Automatic pre-update snapshot
446 | pre | 13.57MiB | 2020-06-10 21:08:24 +0200 | Automatic pre-update snapshot
447 | rollback | 195.32MiB | 2020-06-10 21:55:06 +0200 | Rollback to snapshot 443
448 | single | 13.51MiB | 2020-06-11 15:22:29 +0200 | Migration 2nd attempt
449 | pre | 13.51MiB | 2020-06-11 15:31:45 +0200 | Automatic pre-update snapshot
450 | rollback | 195.42MiB | 2020-06-11 16:07:32 +0200 | Rollback to snapshot 449
451 | pre | 8.85MiB | 2020-06-11 16:18:30 +0200 | Automatic pre-update snapshot
452 | rollback | 195.22MiB | 2020-06-11 16:40:38 +0200 | Rollback to snapshot 443
453 | time | 8.91MiB | 2020-06-14 01:05:01 +0200 | Snapshot created by cron
454 | single | 12.00KiB | 2020-06-16 14:31:41 +0200 | Migration 3rd attempt
root@turris:~# opkg-cl update
Downloading https://repo.turris.cz/omnia/packages//base/Packages.gz
100 151k 100 151k 0 0 1031k 0 --:–:-- --:–:-- --:–:-- 1232k
Updated list of available packages in /var/opkg-lists/omnia_base
Downloading https://repo.turris.cz/omnia/packages//base/Packages.sig
100 151 100 151 0 0 2097 0 --:–:-- --:–:-- --:–:-- 2126
Signature check passed.
Downloading https://repo.turris.cz/omnia/packages//hardware/Packages.gz
100 1423 100 1423 0 0 19493 0 --:–:-- --:–:-- --:–:-- 19763
Updated list of available packages in /var/opkg-lists/omnia_hardware
Downloading https://repo.turris.cz/omnia/packages//hardware/Packages.sig
100 151 100 151 0 0 1819 0 --:–:-- --:–:-- --:–:-- 1841
Downloading https://repo.turris.cz/omnia/packages//lucics/Packages.gz
100 77284 100 77284 0 0 639k 0 --:–:-- --:–:-- --:–:-- 645k
Updated list of available packages in /var/opkg-lists/omnia_lucics
Downloading https://repo.turris.cz/omnia/packages//lucics/Packages.sig
100 151 100 151 0 0 2188 0 --:–:-- --:–:-- --:–:-- 2220
Downloading https://repo.turris.cz/omnia/packages//management/Packages.gz
100 2451 100 2451 0 0 33575 0 --:–:-- --:–:-- --:–:-- 34041
Updated list of available packages in /var/opkg-lists/omnia_management
Downloading https://repo.turris.cz/omnia/packages//management/Packages.sig
Downloading https://repo.turris.cz/omnia/packages//node/Packages.gz
100 3060 100 3060 0 0 40800 0 --:–:-- --:–:-- --:–:-- 41351
Updated list of available packages in /var/opkg-lists/omnia_node
Downloading https://repo.turris.cz/omnia/packages//node/Packages.sig
100 151 100 151 0 0 2068 0 --:–:-- --:–:-- --:–:-- 2097
Downloading https://repo.turris.cz/omnia/packages//openwisp/Packages.gz
100 400 100 400 0 0 5405 0 --:–:-- --:–:-- --:–:-- 5479
Updated list of available packages in /var/opkg-lists/omnia_openwisp
Downloading https://repo.turris.cz/omnia/packages//openwisp/Packages.sig
Downloading https://repo.turris.cz/omnia/packages//packages/Packages.gz
100 202k 100 202k 0 0 1593k 0 --:–:-- --:–:-- --:–:-- 1605k
Updated list of available packages in /var/opkg-lists/omnia_packages
Downloading https://repo.turris.cz/omnia/packages//packages/Packages.sig
100 151 100 151 0 0 1696 0 --:–:-- --:–:-- --:–:-- 1715
Downloading https://repo.turris.cz/omnia/packages//php/Packages.gz
100 5998 100 5998 0 0 74049 0 --:–:-- --:–:-- --:–:-- 74975
Updated list of available packages in /var/opkg-lists/omnia_php
Downloading https://repo.turris.cz/omnia/packages//php/Packages.sig
Downloading https://repo.turris.cz/omnia/packages//printing/Packages.gz
100 4557 100 4557 0 0 62424 0 --:–:-- --:–:-- --:–:-- 63291
Updated list of available packages in /var/opkg-lists/omnia_printing
Downloading https://repo.turris.cz/omnia/packages//printing/Packages.sig
100 151 100 151 0 0 2126 0 --:–:-- --:–:-- --:–:-- 2157
Downloading https://repo.turris.cz/omnia/packages//routing/Packages.gz
100 11666 100 11666 0 0 153k 0 --:–:-- --:–:-- --:–:-- 156k
Updated list of available packages in /var/opkg-lists/omnia_routing
Downloading https://repo.turris.cz/omnia/packages//routing/Packages.sig
Downloading https://repo.turris.cz/omnia/packages//sidn/Packages.gz
100 1672 100 1672 0 0 23222 0 --:–:-- --:–:-- --:–:-- 23549
Updated list of available packages in /var/opkg-lists/omnia_sidn
Downloading https://repo.turris.cz/omnia/packages//sidn/Packages.sig
100 151 100 151 0 0 1887 0 --:–:-- --:–:-- --:–:-- 1911
Downloading https://repo.turris.cz/omnia/packages//telephony/Packages.gz
100 14864 100 14864 0 0 166k 0 --:–:-- --:–:-- --:–:-- 166k
Updated list of available packages in /var/opkg-lists/omnia_telephony
Downloading https://repo.turris.cz/omnia/packages//telephony/Packages.sig
Downloading https://repo.turris.cz/omnia/packages//turrispackages/Packages.gz
100 153k 100 153k 0 0 1291k 0 --:–:-- --:–:-- --:–:-- 1313k
Updated list of available packages in /var/opkg-lists/omnia_turrispackages
Downloading https://repo.turris.cz/omnia/packages//turrispackages/Packages.sig
100 151 100 151 0 0 1735 0 --:–:-- --:–:-- --:–:-- 1755
root@turris:~# opkg-cl install tos3to4
Installing tos3to4 (1.0.2-2) to root…
Downloading https://repo.turris.cz/omnia/packages//turrispackages/tos3to4_1.0.2-2_mvebu.ipk
100 1778 100 1778 0 0 25042 0 --:–:-- --:–:-- --:–:-- 25400
Configuring tos3to4.
root@turris:~# date
Tue Jun 16 14:32:57 CEST 2020
root@turris:~# updater-supervisor -d
--------------------------------------------------------note: at about 16:42 *******
root@turris:~# pkgupdate
line not found
line not found
line not found
ERROR:
runtime: [string “requests”]:417: [string “utils”]:422: Unable to finish URI (https://repo.turris.cz/hbk/omnia/lists/base.lua): Download failed
root@turris:~# date
Tue Jun 16 16:43:37 CEST 2020
root@turris:~#
Tue Jun 16 16:50:33 CEST 2020
uptime: 16:50:33 up 1 min, load average: 1.36, 0.46, 0.16
turris-version: 5.0.1
line not found
line not found
line not found
ERROR:
root@turris:~#
As you can see from screen image, there is some process issuing in loop sleep 180 command
When I upgraded, I ran the script and after a period of time came back to see it had upgraded.
After the upgrade my LXC entries are blank, the LXC that was there and running in TOS3 is no longer listed.
Does the script generate it’s own log file? Perhaps I can look there to see what happened?
The LXC was an Ubuntu OS sitting on my mounted /srv external drive, so I still have it.
My plan was to get TOS5 to create a new LXC so I could see what it does to the config files and then replicate that to point to my existing LXC.
I’ve had a few updates since the upgrade but I am still able to reproduce the issue tonight, If I go to the LXC page, wait for the template fields to populate, then select an OS (Ubuntu X) provide a name, then click create I get ‘session expired’
I don’t understand the code, but here’s where the error is coming from, I think it is saying if local conf “luci.config” isn’t available show this error message. ?
local function determine_request_language()
local conf = require “luci.config”
assert(conf.main, “/etc/config/luci seems to be corrupt, unable to find section ‘main’”)
local lang = conf.main.lang or "auto"
if lang == "auto" then
local aclang = http.getenv("HTTP_ACCEPT_LANGUAGE") or ""
for aclang in aclang:gmatch("[%w_-]+") do
local country, culture = aclang:match("^([a-z][a-z])[_-]([a-zA-Z][a-zA-Z])$")
if country and culture then
local cc = "%s_%s" %{ country, culture:lower() }
if conf.languages[cc] then
lang = cc
break
elseif conf.languages[country] then
lang = country
break
end
elseif conf.languages[aclang] then
lang = aclang
break
end
end
end
lang = i18n.default
end
i18n.setlanguage(lang)
end
|Device|Turris Omnia|
|Serial number|47244668240|
|Turris OS version|5.0.1|
|Turris OS branch|HBK|
|Kernel version|4.14.180|
@jada4p Do you please have system log from update? I would need that to see what exactly happen. I can’t track what is happening just from your description. From system log I should be able to see more. (just send me file /var/log/messages before reboot after migration). Also is your internet connection working after update? That seems to be the core reason. Updater fails later on because it is not able to reach our servers to check for update.
@jiberjaber all configuration files /srv/lxc/*/config are migrated with release of Turris OS 5.0.1. I am not sure what exactly is happening in your case but it seems that Luci for some reason corrupts probably its own overlay on UCI. You uci as well as code you listed seems to be correct. Just to be sure I have to ask, is this before or after reboot after migration? Anyway that code just checks if conf.main section exists and it does in your case but UCI has runtime overlay and it is possible that Luci removed that section in it. Reboot should recover that for sure. The question is of course why is Luci doing that in your case.
The TO has had a number of reboots since the script was run. It’s on HBK branch at the moment so a few updates have come through (though the current set of updates doesn’t seem to want to install)
root@TurrisOmnia:~# pkgupdate
INFO:Target Turris OS: 5.0.2
WARN:Request not satisfied to install package: knot-resolver
WARN:Package wpad is in cyclic dependency. It might fail its post-install script.
WARN:Package hostapd is in cyclic dependency. It might fail its post-install script.
WARN:Requested package luci-i18n-rainbow-en that is missing, ignoring as requested.
WARN:Requested package luci-i18n-sqm-en that is missing, ignoring as requested.
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Requested package luci that is not available.
root@TurrisOmnia:~#
We are working on this one. 5.0.2 is not in the stable neither in the testing branch. It is in the development branch (HBK) and you might want to complain in OpenWrt that they didn’t review a patch since February.
More details here: TO 5.0.2 in HBK - Package LuCI is not available
I can send you logs from all migration attempts, fortunately, for I relocated log file(s) to flash memory, where they survive reboots
logs
-rw------- 1 root root 980251 Jun 17 14:57 messages
-rw------- 1 root root 1581988 Jun 17 04:35 messages.1
-rw------- 1 root root 129444 Jun 16 04:35 messages.2.gz
-rw------- 1 root root 120809 Jun 14 04:35 messages.3.gz
-rw------- 1 root root 241616 Jun 12 04:35 messages.4.gz
-rw------- 1 root root 103376 Jun 10 17:12 messages.5.gz
-rw------- 1 root root 82906 Jun 10 04:35 messages.6.gz
-rw------- 1 root root 83882 Jun 8 04:35 messages.7.gz
If I understand it well, log file from last migration attempt is messages.1 (dated Jun 17 04:35); of interest maight be times from 14:25 (shutdown - reboot) or even later, 14:33 (pkgupdate).
As far as I don’t know how to send it to you directly from Omnia, I can unplug flash drive and hopefuly send the file using Windows
Edit: better I generated diagnostics by Foris (renamed messages.1 to messages…). Mailing it to support.
I’ve completed the upgrade following the migration docs at https://docs.turris.cz/geek/tos3_migration/ - I upgraded from 3.11.17 to 5.0.2, which and encountered a few issues:
tos3to4: the postrm process for tos3to4 errored like so:
INFO:Running postrm of tos3to4
/usr/lib/opkg/info//tos3to4.postrm: line 1: luci-app-squid: not found
/usr/lib/opkg/info//tos3to4.postrm: line 20: syntax error: unexpected "}"
INFO:Running postrm of cznic-repo-keys-test
INFO:Cleaning up control files
ERROR:Failed operations:
tos3to4/postrm: /usr/lib/opkg/info//tos3to4.postrm: line 1: luci-app-squid: not found
LXC containers failed to load after migration. The issue is because they had static IP addresses assigned and the LXC migration script failed to take this into account:
turris# lxc-ls -l DEBUG
lxc-ls: parse.c: lxc_file_for_each_line_mmap: 142 Failed to parse config file "/srv/lxc/con/config" at line "lxc.net.0.ipv4.ipv4 = 192.168.1.2"
Failed to load config for con
Wireguard interface was broken was an error DEVICE_CLAIM_FAILED displayed in the LuCI UI. I fixed the issue by removing the following line from /etc/config/network:
option ifname 'wg0'
and restarting the interface. New wg interfaces don’t add this line but my other interfaces seem to have it just fine. I don’t know what the issue here was.
DDNS: luci-app-ddns, ddns-scripts and luci-i18n-ddns-en were removed during the upgrade; I don’t know why this was so I had to thus install luci-app-ddns again after the upgrade, which installed the other packages back as dependencies. Running opkg install luci-app-ddns required me to approve the install from Foris and then after I did the result was an error notification:
##### Error notifications #####
Updater failed: Failed operations:
ddns-scripts/preinst: [31;1mDIE [0m:Failed to exec /usr/lib/opkg/info//ddns-scripts.preinst: Exec format error
##### Update notifications #####
• Installed version 2.7.8-13.0 of package ddns-scripts
• Installed version 2.4.9-7.2 of package luci-i18n-ddns-en
ddns-scripts seemingly installed fine though; the preinst script only stops/stopped the ddns service in specific circumstances; no issue since it wasn’t installed then. At this point, I had to restore my /etc/config/ddns file from my old installation, re-set the ddns service to autostart again and reconfigure ddns to use a different network interface as the numbering (eg eth0 to eth1). However, after all that, it’s working.
Docs It’d be helpful if the docs explained I’d end up on HBK after starting from stable; and how to switch to back to HBS. I’ve read all the comments in this thread and the 5.0 thread so I knew to expect this, but if the docs mentioned it that’d be better. I’ve created an issue and patch at https://gitlab.labs.nic.cz/turris/user-docs/issues/67
The last issue I haven’t sorted yet is an old one of mine which has cropped up again, being able to configure /etc/resolv.conf to use a custom DNS. I asked this question a long while ago Set persistent "nameserver" entries in /etc/resolv.conf and still had that config set up in 3.x. The config is still there now in 5.x but it’s not working; /etc/resolv.conf is defaulting to using localhost as the resolver. Thoughts on a fix for that?
To the last issue… the problem is in generic in upstream. This file is part of base-files and not marked as configuration file. Feel free to contact upstream with this. During that time running resolver with forwarding configured should be the same (with exception of course that you have to run resolver on router).
Ah, I understand now, thanks. I see the docs mention this change and I’d read that but I didn’t associate luci-app-ddns with the Netutils package list (or know what this was). Could the migration docs link to a full list of affected packages?
Eh yeh possibly. That list would have to be created. The only link I have is in Lua code https://repo.turris.cz/omnia/lists/netutils.lua. I would be probably better to create some diff list but I am not sure how to grab that.
After reading through /etc/init.d/dnsmasq, I did find a solution to ensuring my LAN’s DNS server is in /etc/resolv.conf:
# Set an interface's DNS server (can be lan, wan, wan6 etc)
uci add_list network.lan.dns=192.168.1.253
# Restores /tmp/resolv.conf to a symlink to /tmp/resolv.conf.auto
/etc/init.d/dnsmasq stop
# Prevent dnsmasq replacing /tmp/resolv.conf again
uci add_list dhcp.@dnsmasq[-1].localuse=0
uci commit
/etc/init.d/dnsmasq start
The result is that /etc/resolv.conf symlinks to /tmp/resolv.conf which links to /tmp/resolv.conf.auto which is generated from the network interface custom DNS server(s) compared to the previous setup where dnsmasq was writing its own /tmp/resolv.conf to use localhost as its sole resolver.
Well after trying everything I could think of to fix my Turris 1.1 and failed I try this thread.
After 5.0.1 came out I tried to upgrade. I’m not sure if there was need to upgrade also my 3.x to higher version or not. Now I’m not sure which version I had installed before upgrade. This ended up with my router throwing errors when I tried to access Forris. I have sent Error log to Turris support. After few hours it became unresponsive. I could not connect to via ethernet to it and wifi was also unavailable. I didn’t have time to fix it and used different router instead.
Reset didn’t help. I tried to remove SD card with no effect. With SD removed I tried to reset it one last time. Also with zero effect. So no what? What is the best way to fix this mess? I could connect to it via serial connection but I’m not sure what would be the best way to fix bricked device.
Serial output:
Without sd
ible
in: 56
out: 0
io_config: 255
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C: Error, wrong i2c adapter 2 max 2 possible
ready
SPI: ready
DRAM: Error, wrong i2c adapter 2 max 2 possible
Detected UDIMM 9905594-003.A00G
2 GiB (DDR3, 64-bit, CL=6, ECC off)
[ 0.556043] pci 0002:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
[ 0.562824] pci_bus 0002:04: Some PCI device resources are unassigned, try booting with pci=realloc
[ 0.572151] mpic-msgr ffe41400.message: Found 0 message registers
[ 0.578169] mpic-msgr ffe41400.message: Of-device full name /soc@ffe00000/message@41400
[ 0.586172] mpic-msgr ffe41400.message: Failed to find message register block alias
[ 0.616789] raid6: int32x1 gen() 171 MB/s
[ 0.638175] raid6: int32x1 xor() 220 MB/s
[ 0.659489] raid6: int32x2 gen() 300 MB/s
[ 0.680867] raid6: int32x2 xor() 261 MB/s
[ 0.723472] raid6: int32x4 xor() 283 MB/s
[ 0.744833] raid6: int32x8 gen() 378 MB/s
[ 0.766169] raid6: int32x8 xor() 253 MB/s
[ 0.770354] raid6: using algorithm int32x4 gen() 398 MB/s
[ 0.775743] raid6: .... xor() 283 MB/s, rmw enabled
[ 0.780611] raid6: using intx1 recovery algorithm
[ 0.786611] clocksource: Switched to clocksource timebase
[ 0.792743] NET: Registered protocol family 2
[ 0.797439] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.804452] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.810887] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.817254] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.823032] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.829424] NET: Registered protocol family 1
[ 0.842343] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.848282] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) (RUBIN) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.861082] bounce: pool size: 64 pages
[ 0.864910] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.872238] io scheduler noop registered
[ 0.876144] io scheduler deadline registered (default)
[ 0.881565] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
[ 0.887728] pcieport 0002:04:00.0: enabling device (0106 -> 0107)
[ 0.894071] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.900963] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 0.907502] pcieport 0001:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.914434] pci 0001:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.920981] pcieport 0002:04:00.0: Signaling PME through PCIe PME interrupt
[ 0.954233] Serial: [ 1.276313] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.294252] fsl-gianfar ffe24000.ethernet eth0: mac: 00:00:00:00:00:00
[ 1.300796] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
[ 1.307596] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
[ 1.314742] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
[ 1.322174] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.340047] fsl-gianfar ffe25000.ethernet eth1: mac: 00:00:00:00:00:00
[ 1.346593] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
[ 1.353393] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
[ 1.360539] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
[ 1.367764] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.385623] fsl-gianfar ffe26000.ethernet eth2: mac: 00:00:00:00:00:00
[ 1.392173] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
[ 1.398973] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
[ 1.406119] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
[ 1.413356] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
[ 1.419482] i2c /dev entries driver
[ 1.423129] mpc-i2c ffe03000.i2c: timeout 1000000 us
[ 1.430572] rtc-ds1307 0-006f: rtc core: registered mcp7940x as rtc0
[ 1.436956] rtc-ds1307 0-006f: 64 bytes nvram
[ 1.441514] mpc-i2c ffe03100.i2c: timeout 1000000 us
[ 1.446762] booke_wdt: powerpc book-e watchdog driver loaded
[ 1.452618] sdhci: Secure Digital Host Controller Interface driver
[ 1.458812] sdhci: Copyright(c) Pierre Ossman
[ 1.463177] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.469018] sdhci-esdhc ffe2e000.sdhc: No vmmc regulator found
[ 1.474865] sdhci-esdhc ffe2e000.sdhc: No vqmmc regulator found
[ 1.503111] mmc0: SDHCI controller on ffe2e000.sdhc/etc/preinit: exec: line 5: /sbin/init: not found
[ 3.546168] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 3.546168]
[ 3.555312] CPU: 0 PID: 1 Comm: sh Not tainted 4.4.199-f90a52a6230ecb072f657fce5aebd444-0 #1
[ 3.563751] Call Trace:
[ 3.566200] [da843e60] [c04ed1e0] dump_stack+0x84/0xb0 (unreliable)
[ 3.572472] [da843e70] [c04e8d7c] panic+0xe0/0x21c
[ 3.577267] [da843ed0] [c002e778] do_exit+0x430/0x84c
[ 3.582318] [da843f10] [c002ec18] do_group_exit+0x48/0xac
[ 3.587718] [da843f30] [c002ec90] __wake_up_parent+0x0/0x18
[ 3.593294] [da843f40] [c000e18c] ret_from_syscall+0x0/0x3c
[ 3.598867] --- interrupt: c01 at 0xb7b92214
[ 3.598867] LR = 0xb7be9648
[ 3.606271] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 3.606271]
SD card:
ible
in: 56
out: 0
io_config: 255
SD/MMC : 4-bit Mode
eSPI : Enabled
ready
SPI: ready
= 59)
[ 1.210273] libphy: Fixed MDIO Bus: probed
[ 1.214580] libphy: Freescale PowerQUICC MII Bus: probed
[ 1.222470] switch0: Atheros AR8337 rev. 2 switch registered on mdio@ffe24520
has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.531271] Bridge firewalling registered
[ 1.535301] 8021q: 802.1Q VLAN Support v1.8
[ 1.540338] BTRFS: using crc32c-generic for crc32c
[ 1.546463] Btrst is w4/r0), UUID 2BB8079F-4C36-4826-89FF-B335CD044083, small LPT model
[ 3.391235] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 3.397475] Freeing unused kernel memory: 200K
Must say that now 3 weeks later the trouble from moving from 3.17 ( kickstarter omnia ) to 5.0.x was worth it. Moved from HBT or even more wonky to HBS ( both on Omnia and Mox ) so all is quiet and running. Thxs pepe and gang!
I agree though I still don’t have a working LXC - is it worth a uninstall and reinstall of the LCX bit in luci I wonder?
Edit: Just tried it, removed LXC packages and reinstalled but still have the same issue with “A new login is required since the authentication session expired.” on the LXC page of Luci??
Today’s trial to migrate from 3.11.17 ended up badly - inaccessible Omnia, division by zero in kernel right after boot (which however did not stop the boot)
Summary
[ 0.000000] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.14.180 #0
[ 0.000000] Hardware name: Marvell Armada 380/385 (Device Tree)
[ 0.000000] [<c010feec>] (unwind_backtrace) from [<c010b35c>] (show_stack+0x10/0x14)
[ 0.000000] [<c010b35c>] (show_stack) from [<c07bfc40>] (dump_stack+0x94/0xa8)
[ 0.000000] [<c07bfc40>] (dump_stack) from [<c07be2cc>] (Ldiv0+0x8/0x10)
[ 0.000000] [<c07be2cc>] (Ldiv0) from [<c0515ea0>] (clk_cpu_recalc_rate+0x28/0x2c)
[ 0.000000] [<c0515ea0>] (clk_cpu_recalc_rate) from [<c0512298>] (clk_register+0x3f4/0x67c)
[ 0.000000] [<c0512298>] (clk_register) from [<c0a1a4a8>] (of_cpu_clk_setup+0x16c/0x310)
[ 0.000000] [<c0a1a4a8>] (of_cpu_clk_setup) from [<c0a19d08>] (of_clk_init+0x16c/0x214)
[ 0.000000] [<c0a19d08>] (of_clk_init) from [<c0a0399c>] (time_init+0x24/0x2c)
[ 0.000000] [<c0a0399c>] (time_init) from [<c0a00c48>] (start_kernel+0x35c/0x4c4)
[ 0.000000] [<c0a00c48>] (start_kernel) from [<0000807c>] (0x807c)
[ 0.000000] Division by zero in kernel.
[ 0.000000] Switching to timer-based delay loop, resolution 40ns
and then lots of
00:56:17 err kernel[]: [ 25.407164] mvneta f1030000.ethernet eth0: bad rx status 0da10000 (crc error), size=99
It might be related to:
00:54:22 crit kernel[]: [2936830.031598] BTRFS critical (device mmcblk0p1): corrupt leaf, non-root leaf's nritems is 0: block=1947410432, root=409, slot=0
00:54:22 info kernel[]: [2936830.043127] BTRFS info (device mmcblk0p1): leaf 1947410432 total ptrs 0 free space 3995
right before reboot, but btrfs scrub shows no errors at all:
Summary
root@turris:~# btrfs scrub status /dev/mmcblk0p1
UUID: 2d640e77-8547-488d-9997-a30dba289df3
Scrub started: Thu Jul 9 03:43:15 2020
Status: finished
Duration: 0:00:50
Total to scrub: 1.67GiB
Rate: 34.27MiB/s
Error summary: no errors found
I’m used to seeing these BTRFS errors from time to time, but I never noticed anything broken and there are discussions saying that these might be false alarms or kernel bugs…
Clean install of TOS 5 (via schnapps import) works well on this particular device.
Just upgraded to 5.1.1 from 3.x.
“Session expired” on lxc page is still shown due to a wrong line in pi-hole lxc config.
lxc.network.ipv4 = 192.168.2.2/24
after correcting this to the right format the session bug is gone.
I thought I read that a problem with static adresses was fixed.
