i have some problems setting up openVPN
configuration
I have a static public IP address.
My network configuration looks like this.
config dhcp 'lan'
option interface 'lan'
option start '100'
option dhcpv6 'server'
option ra 'server'
option leasetime '43200'
option ra_management '1'
option limit '50'
list dns '2002:4e5e:691e::e37'
list domain 'fdb7:cc78:74b7::e37'
list dhcp_option '6,10.0.0.3'
My VPN configuration looks like this.
Problem 1
I created a client for my iPhone and downloaded the file for the openVPN app to my iPhone.
I can connect my iPhone to the VPN via the app.
Turris Log
2019-03-18 21:37:53 notice openvpn(server_turris)[29412]: XXXXXXXXX TLS: Initial packet from [AF_INET6]XXXXXXXXXXXXXXXXXX, sid=XXXXXXXXXXXXXXXXXX
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX VERIFY OK: depth=1, CN=openvpn
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX VERIFY OK: depth=0, CN=iPhone
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_GUI_VER=net.openvpn.connect.ios_3.0.2-894
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_VER=3.2
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_PLAT=ios
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_NCP=2
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_TCPNL=1
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_PROTO=2
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_LZO_STUB=1
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_COMP_STUB=1
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_COMP_STUBv2=1
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_AUTO_SESS=1
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX peer info: IV_BS64DL=1
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: XXXXXXXXX [iPhone] Peer Connection Initiated with [AF_INET6]XXXXXXXXX
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX MULTI_sva: pool returned IPv4=10.0.1.6, IPv6=(Not enabled)
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX MULTI: Learn: 10.0.1.6 -> iPhone/XXXXXXXXX
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX MULTI: primary virtual IP for iPhone/XXXXXXXXX: 10.0.1.6
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX PUSH: Received control message: 'PUSH_REQUEST'
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX SENT CONTROL [iPhone]: 'PUSH_REPLY,route 10.0.0.0 255.255.255.0,redirect-gateway def1,route 10.0.1.1,topology net30,ping 10,ping-restart 120,ifconfig 10.0.1.6 10.0.1.5,peer-id 0,cipher AES-256-GCM' (status=1)
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX Data Channel: using negotiated cipher 'AES-256-GCM'
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
2019-03-18 21:37:54 notice openvpn(server_turris)[29412]: iPhone/XXXXXXXXX Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
After the connection, however, I no longer have Internet access on my iPhone.
I have the same problem with my laptop.
