OpenVPN and local DNS (not Turris Omnia)
I’m using the following setup:
Network:           192.168.0.0/24
Turris Omnia:      192.168.0.1        (no DNS, DHCP-Option "6,192.168.0.2")
DNS-Server:        192.168.0.2        (Raspberry Pi, dnsmasq)
OpenVPN network:   172.16.1.0/24
If I now connect a device over VPN, the gateway (Turris Omnia, 172.16.1.1) from the VPN network is specified as DNS:
172.16.1.1
But that doesn’t take my local DNS into account! At the moment, there is no DNS at all.
How can I get my local DNS (192.168.1.2) to be used instead of the VPN gateway (172.16.1.1)? He’s on another network. I’m a little at a loss right now.
I’m grateful for tips.
In /etc/config/openvpn you can set the server manually:
list push 'dhcp-option DNS 192.168.0.2'
Exactly what I was looking for. Thank you.
