Hi
I have really liked what the Turris Omnia have been doing and was ready to purchase after a failure of my router BUT then I saw that the guys at netgate where bringing out a new model that looked very much like Omina (a bit late after a couple of years
I dont want to get into a discussion about software… but I wanted your collected opinion on the netgate hardware
They are using the Marvell 88F6820 is that the same as OMNIA ?
for the switch they use the Marvell 88E6141 is that the same ?
( their spec’s claim :
2x 1GbE, configured as dual WAN or one WAN one LAN
four-port 1 gbps Marvell 88E6141 switch, uplinked at 2.5 gbps to the third port on the SoC for LAN. )
Can you tell what the difference is beyond the SFP ?
thanks
John Jones
https://john.jones.name
