My omnia won’t boot anymore. As soon as I connect the power supply the LED B is blue/white for ca. 2 seconds after that LED A blinks 5 times in red and then it starts again with LED B.
Any idea what could cause this? Is my Omnia broken?
Not necessarily. Did you try a reset rollback to last snapshot?
Else if you got a console cable you could try to connect to that port and investigate what happens.
Other options are factory reset or flashing a fresh medkit image bot incurring loss of settings and any data on the router’s internal drive.
Hey! Did you resolve your issue? The same thing happened to me just now.
Sadly I could solve the issue itself because it is the internal MMC storage that is defect.
But I am running my omnia from a PCIe SSD now.
