I have one of these “easy to test and find” problems.
Setup:
- 1/0,5Gbps FTTH converted to copper on WAN
- Omnia w/both 5 and 2.4Ghz wifi networks turned on
- netdata + openvpn server running as the major services turned on
- no heavy load in the network (just home newtork with <10 devices incl phones), the most heavy probably being transmission server (over copper, not wifi, but it’s mostly running <2MB/s and capped at 100 connections in total and 20MB/s)
Now the problem. My wife complains that during her Gmeet / Zoho / Whatsapp calls there are sudden “lags” where it’s telling her the connection is weak, video&sound is stuttering and after few seconds it’s fine again. And according to her that repeats once per 1-5 minutes. Some calls are fine but some being problematic. I tried SQM but according to her the problem still persists (test results after setting up are at worst B for both the quality and bufferbloat).
And I’m stuck now - do you have any idea what might be causing it? What to modify? How to run some long-term test to find the source issue?
