I don’t know what to include here to describe the issue. I wanted to know if I’m the only one experiencing this issue where my connection to the internet works perfectly but for some reason I cannot connect to Discord after some time (if I stop using it for 10 min or so). The same happens on my phone connected to the same router.
I’m not sure if it’s possible it’s a router issue or if I should look into my computer / phone settings. What seems weird to me is that it only happens when I use my turris router. Everything works as normal when on 5G or on other wifi.
I’ve been seeing the same thing. It’s not connecting per sè, rather it’s sometimes unable to look up certain domain names, including discord.com. If I SSH into it and run nslookup discord.com while it’s happening I get “no such domain.”
Thanks; I believe I know what happened in this case and we’ll be improving the heuristic to avoid it.
But people without working IPv6 should better get their resolver configured not to use IPv6. You won’t need to wait for this fix to avoid the case and even generally that configuration should slightly improve latency, etc. From my point of view the ideal way of doing this (with recent-ish Turris OS) is to set IPv6 to disabled in the GUI /reforis/network-settings/wan.
From DNS server’s point of view the detection isn’t so easy. Individual server might not respond, or there might be some kind of a short outage somewhere on the way (specific to IPv6 or not), or perhaps your network hasn’t fully started up yet, etc.
