Not able to update after factory reset
I was experiencing a lot of connectivity issues after Turris 6.0 update. I decided to try the factory reset option as it was recommended in some post.
To my surprise, the factory reset took me all the way back to version 4.0. Now I can’t seem to be able to update back to version 6, as the updater gives the following notification:
Error from 2022/10/24 18:11:37
Updater failed:
inconsistent: Candidate exists for virtual package ath10k-firmware-qca9888-ct-htt
How can I fix this and update back to the current OS?
https://repo.turris.cz/hbs/medkit/omnia-medkit-latest.tar.gz
Thanks. I flashed the image from a USB stick. That seemed to do the trick.
I also have to install a clean system soon, because after updating to version 6.01 everything works except reForis, which crashes after logging in.
