Hi Hagrid
Thanks for the above. Just before attempting to work on your instructions I thought I will try starting the serial link again. I seem to get different results given below.
mv_ddr: mv_ddr-armada-18.09.2
ddr3_tip_centralization_tx failure CS #0
Title: I/F# , Tj, Calibration_n0, Calibration_p0, Calibration_n1, Calibration_p1, Calibration_n2, Calibration_p2,CS0 ,
VWTx, VWRx, WL_tot, WL_ADLL, WL_PH, RL_Tot, RL_ADLL, RL_PH, RL_Smp, Cen_tx, Cen_rx, Vref, DQVref, PBSTx-Pad0,PBSTx-Pad1,PBSTx-Pad2,PBSTx-Pad3,PBSTx-Pad4,PBSTx-Pad5,PBSTx-Pad6,PBSTx-Pad7,PBSTx-Pad8,PBSTx-Pad9,PBSTx-Pad10, PBSRx-Pad0,PBSRx-Pad1,PBSRx-Pad2,PBSRx-Pad3,PBSRx-Pad4,PBSRx-Pad5,PBSRx-Pad6,PBSRx-Pad7,PBSRx-Pad8,PBSRx-Pad9,PBSRx-Pad10,
Data: 0,64,18,14,20,15,20,20,CS0 ,
0,23,37,5,1,800,0,3,11,27,11,4,0, 2,1,2,2,1,1,1,1,1,0,0, 16,15,10,10,3,3,10,15,14,10,0,
0,21,21,21,0,789,21,2,11,27,10,4,0, 2,3,2,0,1,1,1,3,1,1,0, 13,12,13,13,1,1,10,13,11,11,0,
0,21,16,16,0,782,14,2,11,27,10,4,0, 2,2,1,1,1,1,1,0,2,2,0, 12,16,11,11,3,3,10,10,11,11,0,
0,23,44,12,1,806,6,3,11,27,11,4,0, 3,2,3,0,1,1,1,2,0,0,0, 12,12,11,10,1,1,10,11,10,10,0,
******** DRAM initialization Failed (res 0x1) ********
DDR3 Training Sequence - FAILED
### ERROR ### Please RESET the board ###
Does this make more sense? or not?
