No internet connection after upgrade to Turris OS 6
When I upgrade to Turris OS 6 I can no longer connect to the internet after rebooting. The only fix I found so far is a rollback to 5.4.4. The error I keep getting in the system log is this:
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 3: import: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 4: import: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 5: import: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 6: from: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 7: import: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 8: import: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 9: import: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 10: from: not found
Oct 21 19:10:35 turris dnsmasq-script[5362]: /usr/lib/dnsmasq/dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 13: syntax error: unexpected “(”
Oct 21 19:10:35 turris dnsmasq[5362]: script process exited with status 2
What could the problem be? Is anyone else facing similar problems?
The full system log can be found here.
These logs should have nothing to do with “no longer connect to the internet”.
Hmm, then what could the problem be? Any hints on how to diagnose the problem? The connectivity test shows all red crosses, and the Luci landing page shows “no” for both IPv4 and IPv6 connectivity. I’m connecting to a fiber connection using an SFP module.
Which SFP module? It is correctly hooked up in the system? You would need to send us diagnostics.
The kernel log shows it as “sfp sfp: module TP-LINK TL-SM321B rev 1.1”. It is definitely hooked up correctly, as I’m sending this message with it from Turris OS 5.4.4 after a rollback. I’ll upgrade again and send diagnostics later.
Usually I’d recommend against posting the diagnostics publicly, as there’s lots of information in them and some might be considered private.
