NFS problem in LXC container
Hi everybody. I have been trying to get NFS to work with my router all day. Sadly things seem to be buggy.
I have configured a standard debian LXC container on Turris, running on 192.168.1.203.
With a standard exportsfile.
root@nestor:~# cat /etc/exports
/etc/exports: the access control list for filesystems which may be exported
to NFS clients. See exports(5).
Example for NFSv2 and NFSv3:
/srv/homes hostname1(rw,sync,no_subtree_check) hostname2(ro,sync,no_subtree_check)
Example for NFSv4:
/srv/nfs4 gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check)
/srv/nfs4/homes gss/krb5i(rw,sync,no_subtree_check)
/home 192.168.1.196(rw,sync,subtree_check)
But when I try to mount it I get errorrs
root@comp:~# mount -o tcp,vers=3 -vv 192.168.1.203:/home /tmp/test
mount.nfs: timeout set for Sat Mar 11 19:41:57 2017
mount.nfs: trying text-based options 'tcp,vers=3,addr=192.168.1.203’
mount.nfs: prog 100003, trying vers=3, prot=6
I have also tried getting NFS to work on turris, and to my suprice, there is a live and active exports file
root@turris:~# cat /etc/exports
/mnt *(ro,all_squash,insecure,sync)
But you cant mount it, even on localhost
/etc/exports is the configuration file, but you don’t provide any information about whether the server is running that configuration file.
What’s the out put of running exportfs?
# exportfs
exportfs: could not open /var/lib/nfs/.etab.lock for locking: errno 2 (No such file or directory)
Also what’s the output for ps after I started nfs:
# ps | grep nfs
1272 root 0 SW< [nfsiod]
23589 root 1188 S {nfsd} /bin/sh /etc/rc.common /etc/init.d/nfsd start
23599 root 840 D /usr/sbin/rpc.nfsd
23676 root 1092 S grep nfs
(as a side note, you should probably escape any # symbols (\#) otherwise it bolds your text in the forum)
root@nestor:/ exportfs
/home 192.168.1.0/255.255.255.0
root@nestor:/ ps | grep nfs
root@nestor:/
I am running the kernel-nfs version. Not sure why of if its a good ide on an LXC container.
Please note that if I would comment out the entry in exports I will get a different error on the client side.
