Nextcloud error installation
#1
Hello guys, I installed nextcloud with the nextcloud_install script. After typing YES, my admin name and a password, three errors occur
Bildschirmfoto%20vom%202018-11-29%2020-56-05
These errors prevent me from setting up Nextcloud any further. Can anyone help me fix it?
My Turris Omnia was freshly set up with all new updates.
#3
i have same problem.
i could not find any solution on forums
#4
utf8mb4 enables Emoji (UTF8 4-byte) support with MySQL. Not sure why that is needed in the first place.
Maybe installing the package perlbase-utf8 helps. Or else from the cli something in this direction
sudo -u nobody www-data php occ config:system:set mysql.utf8mb4 --type boolean --value="false"
or
sudo -u nobody php-cli occ config:system:set mysql.utf8mb4 --type boolean --value="false"
#5
it seems perlbase-utf8 was missing.
after install of that package, nextcloud_install did not show errors anymore.
BTW. my system was cleanly installed from medkit 3.11 and was upgraded to 3.11.1
