Since a few months, I could not use my sync code on Netmetr website as it was reported as invalid.
During last update, I have deleted the sync code from the code file to have a new one generated. On the website, my code is recognized and it shows my old measurements. But new measurements still cannot be seen.
thank you for your feedback. Could you provide us with config file located at /etc/config/netmetr and a full debug output generated by running netmetr --debug? Have tried to delete line containing sync_code more than once?
thank you for the conf file and debug output. If I understand it clearly - your new sync code is showing some measurements but it doeen’t show the newest measurements measured on Turris? Anyway, send me please a full sync code and full uuid in PM. We will check it in DB.
OK, yes but the new code does nothing, but deleting the sync code before each measurement. So I’m a bit confused how the manually applied commit could be more helpful then manually deleted sync code. Anyway, thank you for you feedback!
