I’ve just moved into this new place and I need some advice on how to configure the LAN here.
Situation:
There are two rooms with two routers.
Room 1 - ISP connection + office equipment
Room 2 - home theater/network_disk/kodi
The two rooms are connected via power-link as they are quite far away with multiple walls in between.
What I’ve done so far:
I’ve connected power-link in the Room 2 to the WAN port of the Turris Omnia 2 router which made it connect to the internet so that works.
What is broken now is the LAN connection between Room 1 and Room 2. They are now on different LAN’s and (for example), the local disk is not visible in the office.
What I want to achieve:
I want to have the same network in both rooms, or at least somehow connect them so they are visible to each other.
Thank you all.
