I tried to install my new router. I used on ethernet cable from my computer to the router LAN0 and another ethernet cable from WAN to modem. I tried to run the First Run & Foris Interface. It made it up to Step 7. Updated for a long time, then quit and now I can’t do anything.
It says: 192.168.1.1 took too long to respond. I tried last night, again today. Same thing.
I have model: RTROM01. I am using a 2009 MacBook Pro to install. I have a brand new Mac but this has no ethernet cable.
Is there a simple solution?
I tested my cables. Both are working. I don’t know that much about routers so I need help in layperson terms.
Thank you for help.
Carrie
