I have set-up vlans over the ethernet ports and it is working fine. The set-up is equivalent to a managed switch.
Now I want to expand vlans to Wifi, but I encounter a difficulty:
I have created 4 vlans in the br-lan device, but, I enabled ‘local’ only for the management vlan. This set-up is then creating only 1 vlan in device and I can only create only interface with the management vlan.
When I go to wireless page and I want to create an SSID, I am only proposed the management vlan which is the one I don’t want to see over WIFI. I can’t see any other vlan.
Do I need to enable ‘local’ on the other vlans, even though I don’t want any of them to connect to the router except for the management vlan? Or is there another way to do it?
What should be the firewall set-up to ensure that there is no cross vlan routing and that only the management vlan is authorized to communicate with the router?
