U-Boot 2015.04-04654-gbcfb33e-dirty (Jun 26 2015 - 12:50:49)
CPU0: P2020E, Version: 2.1, (0x80ea0021)
Core: e500, Version: 5.1, (0x80211051)
Clock Configuration:
CPU0:1200 MHz, CPU1:1200 MHz,
CCB:600 MHz,
DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:37.500 MHz
L1: D-cache 32 KiB enabled
I-cache 32 KiB enabled
wdt status 00000005 reset
Watchdog enabled
Board: TURRIS CPLD: V4.1 PCBA: V4.0
Error, wrong i2c adapter 2 max 2 possible
in: 56
out: 0
io_config: 255
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C: Error, wrong i2c adapter 2 max 2 possible
ready
SPI: ready
DRAM: Error, wrong i2c adapter 2 max 2 possible
Detected UDIMM 9905428-181.A00LF
WARNING: Calling __hwconfig without a buffer and before environment is ready
2 GiB (DDR3, 64-bit, CL=6, ECC off)
Flash: 16 MiB
L2: 512 KiB enabled
NAND: 256 MiB
MMC: FSL_SDHC: 0
PCIe1: Root Complex of mini PCIe SLOT, no link, regs @ 0xffe0a000
PCIe1: Bus 00 - 00
PCIe2: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe09000
02:00.0 - 168c:0030 - Network controller
PCIe2: Bus 01 - 02
PCIe3: Root Complex of PCIe SLOT, no link, regs @ 0xffe08000
PCIe3: Bus 03 - 03
In: serial
Out: serial
Err: serial
Net: Phy 5 not found
PHY reset timed out
eTSEC1
Error: eTSEC1 address not set.
, eTSEC2
Error: eTSEC2 address not set.
, eTSEC3 [PRIME]
Error: eTSEC3 address not set.
Hit any key to stop autoboot: 0
BOOT NAND
reading zImage
3319984 bytes read in 193 ms (16.4 MiB/s)
wdt status 00000003
reading fdt
12945 bytes read in 13 ms (971.7 KiB/s)
WARNING: adjusting available memory to 30000000
Booting kernel from Legacy Image at 02100000 …
Image Name: Linux-4.4.199-f90a52a6230ecb072f
Created: 2020-11-13 0:35:31 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 3319920 Bytes = 3.2 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Uncompressing Kernel Image … OK
Loading Device Tree to 03ff9000, end 03fff290 … OK
WARNING: could not find compatible node fsl-usb2-dr
[ 0.000000] Using P2020 RDB machine description
[ 0.000000] Memory CAM mapping: 256/256 Mb, residual: 1536Mb
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.199-f90a52a6230ecb072f657fce5aebd444-1 (beast@b uild) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r47055) ) #1 SMP Fri No v 13 01:35:22 CET 2020
[ 0.000000] CPU maps initialized for 1 thread per core
[ 0.000000] bootconsole [udbg0] enabled
setup_arch: initmem
mpc85xx_rdb_setup_arch()
[ 0.000000] mpc85xx_qe_init: Could not find Quicc Engine node
[ 0.000000] MPC85xx RDB board from Freescale Semiconductor
arch: exit
[ 0.000000] barrier-nospec: using isync; sync as speculation barrier
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000020000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] MMU: Allocated 1088 bytes of context maps for 255 contexts
[ 0.000000] PERCPU: Embedded 10 pages/cpu @dedc2000 s9420 r8192 d23348 u40960
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 523136
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait rw rootfstype=b trfs rootflags=subvol=@,commit=5 console=ttyS0,115200
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Sorting __ex_table…
[ 0.000000] Memory: 2005324K/2097152K available (5048K kernel code, 180K rwda ta, 1100K rodata, 200K init, 244K bss, 91828K reserved, 0K cma-reserved, 1572856 K highmem)
[ 0.000000] Kernel virtual memory layout:
[ 0.000000] * 0xfffbf000…0xfffff000 : fixmap
[ 0.000000] * 0xffc00000…0xffe00000 : highmem PTEs
[ 0.000000] * 0xffbfd000…0xffc00000 : early ioremap
[ 0.000000] * 0xe1000000…0xffbfd000 : vmalloc & ioremap
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:512 nr_irqs:512 16
[ 0.000000] mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs
[ 0.000000] mpic: ISU size: 256, shift: 8, mask: ff
[ 0.000000] mpic: Initializing for 256 sources
[ 0.000000] mpc85xx_rdb_pic_init: Could not find qe-ic node
[ 0.000008] clocksource: timebase: mask: 0xffffffffffffffff max_cycles: 0x114 c1bade8, max_idle_ns: 440795203839 ns
[ 0.010276] clocksource: timebase mult[d555555] shift[24] registered
[ 0.016657] pid_max: default: 32768 minimum: 301
[ 0.021305] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.027843] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.035253] Initializing cgroup subsys io
[ 0.039190] Initializing cgroup subsys memory
[ 0.043542] Initializing cgroup subsys devices
[ 0.047964] Initializing cgroup subsys freezer
[ 0.052397] Initializing cgroup subsys net_cls
[ 0.056829] Initializing cgroup subsys pids
[ 0.061147] mpic: requesting IPIs…
[ 0.065665] Brought up 2 CPUs
[ 0.070677] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 1911260446275000 ns
[ 0.080354] futex hash table entries: 512 (order: 2, 16384 bytes)
[ 0.086529] xor: measuring software checksum speed
[ 0.101288] 8regs : 1472.000 MB/sec
[ 0.115426] 8regs_prefetch: 1312.000 MB/sec
[ 0.129910] 32regs : 1472.000 MB/sec
[ 0.144045] 32regs_prefetch: 1356.000 MB/sec
[ 0.148578] xor: using function: 32regs (1472.000 MB/sec)
[ 0.154297] NET: Registered protocol family 16
[ 0.163701] cpuidle: using governor ladder
[ 0.173956] Found FSL PCI host bridge at 0x00000000ffe08000. Firmware bus num ber: 0->0
[ 0.181806] PCI host bridge /pcie@ffe08000 (primary) ranges:
[ 0.187453] MEM 0x00000000c0000000…0x00000000dfffffff -> 0x00000000c0000000
[ 0.194666] IO 0x00000000ffc20000…0x00000000ffc2ffff -> 0x0000000000000000
[ 0.201804] /pcie@ffe08000: PCICSRBAR @ 0xfff00000
[ 0.206574] setup_pci_atmu: end of DRAM 80000000
[ 0.211441] Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus num ber: 0->1
[ 0.219282] PCI host bridge /pcie@ffe09000 ranges:
[ 0.224150] MEM 0x00000000a0000000…0x00000000bfffffff -> 0x00000000a0000000
[ 0.231364] IO 0x00000000ffc10000…0x00000000ffc1ffff -> 0x0000000000000000
[ 0.238500] /pcie@ffe09000: PCICSRBAR @ 0xfff00000
[ 0.243272] setup_pci_atmu: end of DRAM 80000000
[ 0.248129] Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus num ber: 0->0
[ 0.255971] PCI host bridge /pcie@ffe0a000 ranges:
[ 0.260839] MEM 0x0000000080000000…0x000000009fffffff -> 0x0000000080000000
[ 0.268053] IO 0x00000000ffc00000…0x00000000ffc0ffff -> 0x0000000000000000
[ 0.275189] /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
[ 0.279961] setup_pci_atmu: end of DRAM 80000000
[ 0.293317] PCI: Probing PCI hardware
[ 0.297051] fsl-pci ffe08000.pcie: PCI host bridge to bus 0000:00
[ 0.303071] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.309238] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff]
[ 0.316107] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.321879] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec onfiguring
[ 0.329898] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.335241] fsl-pci ffe09000.pcie: PCI host bridge to bus 0001:02
[ 0.341262] pci_bus 0001:02: root bus resource [io 0x20000-0x2ffff] (bus add ress [0x0000-0xffff])
[ 0.350211] pci_bus 0001:02: root bus resource [mem 0xa0000000-0xbfffffff]
[ 0.357078] pci_bus 0001:02: root bus resource [bus 02-ff]
[ 0.362797] pci 0001:02:00.0: Primary bus is hard wired to 0
[ 0.368381] pci 0001:02:00.0: bridge configuration invalid ([bus 01-01]), rec onfiguring
[ 0.378401] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.383759] fsl-pci ffe0a000.pcie: PCI host bridge to bus 0002:04
[ 0.389784] pci_bus 0002:04: root bus resource [io 0x40000-0x4ffff] (bus add ress [0x0000-0xffff])
[ 0.398728] pci_bus 0002:04: root bus resource [mem 0x80000000-0x9fffffff]
[ 0.405596] pci_bus 0002:04: root bus resource [bus 04-ff]
[ 0.411326] pci 0002:04:00.0: bridge configuration invalid ([bus 00-00]), rec onfiguring
[ 0.419343] pci 0002:04:00.0: PCI bridge to [bus 05-ff]
[ 0.424579] PCI: Cannot allocate resource region 0 of PCI bridge 1, will rema p
[ 0.431730] PCI: Cannot allocate resource region 0 of device 0000:00:00.0, wi ll remap
[ 0.439550] PCI: Cannot allocate resource region 0 of device 0001:02:00.0, wi ll remap
[ 0.447373] PCI: Cannot allocate resource region 0 of device 0002:04:00.0, wi ll remap
[ 0.455228] pci 0000:00:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.461803] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.468757] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.473712] pci 0000:00:00.0: bridge window [mem 0xc0000000-0xdfffffff]
[ 0.480493] pci_bus 0000:00: Some PCI device resources are unassigned, try bo oting with pci=realloc
[ 0.489563] pci 0001:02:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.496140] pci 0001:02:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.503098] pci 0001:03:00.0: BAR 6: assigned [mem 0xa0020000-0xa002ffff pref ]
[ 0.510315] pci 0001:02:00.0: PCI bridge to [bus 03]
[ 0.515266] pci 0001:02:00.0: bridge window [io 0x20000-0x2ffff]
[ 0.521525] pci 0001:02:00.0: bridge window [mem 0xa0000000-0xbfffffff]
[ 0.528305] pci_bus 0001:02: Some PCI device resources are unassigned, try bo oting with pci=realloc
[ 0.537384] pci 0002:04:00.0: BAR 0: no space for [mem size 0x00100000]
[ 0.543954] pci 0002:04:00.0: BAR 0: failed to assign [mem size 0x00100000]
[ 0.550907] pci 0002:04:00.0: PCI bridge to [bus 05]
[ 0.555863] pci 0002:04:00.0: bridge window [io 0x40000-0x4ffff]
[ 0.562122] pci 0002:04:00.0: bridge window [mem 0x80000000-0x9fffffff]
[ 0.568903] pci_bus 0002:04: Some PCI device resources are unassigned, try bo oting with pci=realloc
[ 0.578228] mpic-msgr ffe41400.message: Found 0 message registers
[ 0.584245] mpic-msgr ffe41400.message: Of-device full name /soc@ffe00000/mes sage@41400
[ 0.592249] mpic-msgr ffe41400.message: Failed to find message register block alias
[ 0.624746] raid6: int32x1 gen() 171 MB/s
[ 0.646133] raid6: int32x1 xor() 220 MB/s
[ 0.667447] raid6: int32x2 gen() 300 MB/s
[ 0.688816] raid6: int32x2 xor() 261 MB/s
[ 0.710118] raid6: int32x4 gen() 398 MB/s
[ 0.731422] raid6: int32x4 xor() 283 MB/s
[ 0.752783] raid6: int32x8 gen() 378 MB/s
[ 0.774117] raid6: int32x8 xor() 253 MB/s
[ 0.778303] raid6: using algorithm int32x4 gen() 398 MB/s
[ 0.783691] raid6: … xor() 283 MB/s, rmw enabled
[ 0.788560] raid6: using intx1 recovery algorithm
[ 0.794429] clocksource: Switched to clocksource timebase
[ 0.800682] NET: Registered protocol family 2
[ 0.805321] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.812325] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.818766] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.825137] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.830915] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.837274] NET: Registered protocol family 1
[ 0.847804] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.853728] jffs2: version 2.2 (NAND) (SUMMARY) (ZLIB) (LZO) (LZMA) (RTIME) ( RUBIN) (CMODE_PRIORITY) © 2001-2006 Red Hat, Inc.
[ 0.866417] bounce: pool size: 64 pages
[ 0.870230] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 0.877568] io scheduler noop registered
[ 0.881475] io scheduler deadline registered (default)
[ 0.886899] pcieport 0001:02:00.0: enabling device (0106 -> 0107)
[ 0.893061] pcieport 0002:04:00.0: enabling device (0106 -> 0107)
[ 0.899400] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.906316] pcieport 0001:02:00.0: Signaling PME through PCIe PME interrupt
[ 0.913240] pci 0001:03:00.0: Signaling PME through PCIe PME interrupt
[ 0.919794] pcieport 0002:04:00.0: Signaling PME through PCIe PME interrupt
[ 0.952739] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.961245] console [ttyS0] disabled
[ 0.964779] serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42, base_baud = 375 00000) is a 16550A
[ 0.973454] console [ttyS0] enabled
[ 0.980394] bootconsole [udbg0] disabled
[ 0.988630] serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 375 00000) is a 16550A
[ 0.997911] console [ttyS0] disabled
[ 1.001527] console [ttyS0] enabled
[ 1.005437] ffe04600.serial: ttyS1 at MMIO 0xffe04600 (irq = 42, base_baud = 37500000) is a 16550
[ 1.021399] brd: module loaded
[ 1.025177] ef000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufact urer ID 0x000001 Chip ID 0x002101
[ 1.035201] Amd/Fujitsu Extended Query Table at 0x0040
[ 1.040369] Amd/Fujitsu Extended Query version 1.3.
[ 1.045427] number of CFI chips: 1
[ 1.049064] 6 ofpart partitions found on MTD device ef000000.nor
[ 1.055115] Creating 6 MTD partitions on “ef000000.nor”:
[ 1.060437] 0x000000000000-0x000000020000 : “NOR (RO) DTB Image”
[ 1.067063] 0x000000020000-0x0000001c0000 : “NOR (RO) Linux Kernel Image”
[ 1.074428] 0x0000001c0000-0x000000340000 : “NOR (RO) JFFS2 Root File System”
[ 1.082153] 0x000000340000-0x000000e40000 : “NOR (RO) NAND FW backup”
[ 1.089157] 0x000000e40000-0x000000f00000 : “NOR (RW) Cert backup”
[ 1.095901] 0x000000f00000-0x000001000000 : “NOR (RO) U-Boot Image”
[ 1.103250] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 1.109621] nand: Micron MT29F2G08ABAEAWP
[ 1.113634] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB siz e: 64
[ 1.122542] Bad block table found at page 131008, version 0x02
[ 1.129149] Bad block table found at page 130944, version 0x02
[ 1.135333] nand_read_bbt: bad block at 0x000005a00000
[ 1.140717] 4 ofpart partitions found on MTD device ff800000.flash
[ 1.146909] Creating 4 MTD partitions on “ff800000.flash”:
[ 1.152402] 0x000000000000-0x000000200000 : “NAND (RW) DTB Image”
[ 1.159077] 0x000000200000-0x000000700000 : “NAND (RW) Linux Kernel Image”
[ 1.166497] 0x000000700000-0x000010000000 : "NAND (RW) JFFS2 Root File System "
[ 1.174480] 0x000000000000-0x000010000000 : “rootfs-ubifs”
[ 1.180730] eLBC NAND device at 0xff800000, bank 1
[ 1.185966] fsl_espi ffe07000.spi: cs=0, init_csmode=0x100008
[ 1.191733] fsl_espi ffe07000.spi: cs=1, init_csmode=0x100008
[ 1.197493] fsl_espi ffe07000.spi: cs=2, init_csmode=0x100008
[ 1.203248] fsl_espi ffe07000.spi: cs=3, init_csmode=0x100008
[ 1.210073] fsl_espi ffe07000.spi: at 0xe11c0000 (irq = 59)
[ 1.216099] libphy: Fixed MDIO Bus: probed
[ 1.220390] libphy: Freescale PowerQUICC MII Bus: probed
[ 1.228249] switch0: Atheros AR8337 rev. 2 switch registered on mdio@ffe24520
[ 1.280213] fsl-gianfar ffe24000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.298147] fsl-gianfar ffe24000.ethernet eth0: mac: 00:00:00:00:00:00
[ 1.304687] fsl-gianfar ffe24000.ethernet eth0: Running with NAPI enabled
[ 1.311484] fsl-gianfar ffe24000.ethernet eth0: RX BD ring size for Q[0]: 256
[ 1.318627] fsl-gianfar ffe24000.ethernet eth0: TX BD ring size for Q[0]: 256
[ 1.326057] fsl-gianfar ffe25000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.343942] fsl-gianfar ffe25000.ethernet eth1: mac: 00:00:00:00:00:00
[ 1.350483] fsl-gianfar ffe25000.ethernet eth1: Running with NAPI enabled
[ 1.357279] fsl-gianfar ffe25000.ethernet eth1: RX BD ring size for Q[0]: 256
[ 1.364422] fsl-gianfar ffe25000.ethernet eth1: TX BD ring size for Q[0]: 256
[ 1.371640] fsl-gianfar ffe26000.ethernet: enabled errata workarounds, flags: 0x4
[ 1.389502] fsl-gianfar ffe26000.ethernet eth2: mac: 00:00:00:00:00:00
[ 1.396048] fsl-gianfar ffe26000.ethernet eth2: Running with NAPI enabled
[ 1.402845] fsl-gianfar ffe26000.ethernet eth2: RX BD ring size for Q[0]: 256
[ 1.409988] fsl-gianfar ffe26000.ethernet eth2: TX BD ring size for Q[0]: 256
[ 1.417216] ucc_geth_driver: QE UCC Gigabit Ethernet Controller
[ 1.423332] i2c /dev entries driver
[ 1.426956] mpc-i2c ffe03000.i2c: timeout 1000000 us
[ 1.433943] rtc-ds1307 0-006f: SET TIME!
[ 1.440164] rtc-ds1307 0-006f: rtc core: registered mcp7940x as rtc0
[ 1.446539] rtc-ds1307 0-006f: 64 bytes nvram
[ 1.451076] mpc-i2c ffe03100.i2c: timeout 1000000 us
[ 1.456316] booke_wdt: powerpc book-e watchdog driver loaded
[ 1.462168] sdhci: Secure Digital Host Controller Interface driver
[ 1.468358] sdhci: Copyright© Pierre Ossman
[ 1.472719] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.478557] sdhci-esdhc ffe2e000.sdhc: No vmmc regulator found
[ 1.484401] sdhci-esdhc ffe2e000.sdhc: No vqmmc regulator found
[ 1.513042] mmc0: SDHCI controller on ffe2e000.sdhc [ffe2e000.sdhc] using DMA
[ 1.520902] NET: Registered protocol family 10
[ 1.525962] NET: Registered protocol family 17
[ 1.530465] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this.
[ 1.543123] Bridge firewalling registered
[ 1.547152] 8021q: 802.1Q VLAN Support v1.8
[ 1.552170] BTRFS: using crc32c-generic for crc32c
[ 1.558314] Btrfs loaded, integrity-checker=on
[ 1.564246] rtc-ds1307 0-006f: setting system clock to 2001-01-01 00:00:00 UT C (978307200)
[ 1.573108] Waiting for root device /dev/mmcblk0p2…
[ 1.587527] mmc0: new high speed SDHC card at address 0001
[ 1.593377] mmcblk0: mmc0:0001 00000 7.61 GiB
[ 1.598581] mmcblk0: p1 p2
[ 1.679702] BTRFS: device fsid b5c19281-dbeb-4cd1-8f37-4d00e14fdb1f devid 1 t ransid 29 /dev/root
[ 1.689673] BTRFS info (device mmcblk0p2): disk space caching is enabled
[ 1.696390] BTRFS: has skinny extents
[ 1.715617] BTRFS: detected SSD devices, enabling SSD mode
[ 1.785071] VFS: Mounted root (btrfs filesystem) on device 0:13.
[ 1.791320] Freeing unused kernel memory: 200K
[ 1.809257] Kernel panic - not syncing: No working init found. Try passing i nit= option to kernel. See Linux Documentation/init.txt for guidance.
[ 1.822401] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.199-f90a52a6230ecb0 72f657fce5aebd444-1 #1
[ 1.831447] Call Trace:
[ 1.833896] [da843ec0] [c04ed1f8] dump_stack+0x84/0xb0 (unreliable)
[ 1.840169] [da843ed0] [c04e8d94] panic+0xe0/0x21c
[ 1.844963] [da843f30] [c0002cf8] kernel_init+0x108/0x120
[ 1.850367] [da843f40] [c000e2c4] ret_from_kernel_thread+0x5c/0x64
[ 1.856553] —[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
