I attached another router and used same network name and same network password. It works pretty fine, but it has a disadvantage. It creates another network. So when I walk in my flat then the device starts to obtain a new IP address.
Is there a solution for that?
I would like to use DHCP of the turris instead of the additional router.
I tried that and it will not help to disable DHCP on second router . It will just mean you have to set IP address manually on your cell phone. The network of the second router will remain.
I guess I would like to build mesh network.
I am looking for something like network switch, but for wifi.
It should
just ‘convert’ ethernet to wifi
not create it’s own network (like the second router)
