Thanks for the development of Turris Omnia. At present I have purchased the super early bird perk and I wonder whether the board only MOX C ethernet module would fit into the case as well or do I need a different perk in order to have an access point combined with a switch?
It won’t fit inside. My understanding is that every board module “makes the case longer” (you can see that from pictures of the perks), so you would need some additional case pieces as well.
