Hi, my MOX A arrived today. I want to netboot it from my Omnia. How do I proceed? There’s no documentation for this. I assume this should work without an SD card, right?
In foris on Omnia (with OS 3.11) I checked the netboot package list, but there’s no new menu item in Foris (I’m even pretty sure it was there in past, but now it’s gone).
I´ve installed the package in foris but no new tab.
And I also have no luck with connect directly to the pc.
When I set the IP Adress on my PC to 192.168.1.2 and the Gateway to 192.168.1.1 I have no chance to connect to the Turris Mox
I’ve same problem. Also in advance I tried look at some netboot scripts in Omnia and found this, maybe it would be useful.
netboot-manager regen
tar: ./usr/share/turris-netboot/initrd-aarch64: Not found in archive
tar: ./usr/share/turris-netboot/mox.its: Not found in archive
tar: Exiting with failure status due to previous errors
Wrong rootfs
Same issue. have tried factory reset and reinstalling the Mox package on Omnia, with no luck. No menu option on Foris, no notifications and the device is not picked up by a Figbox monitoring new devices on the network, so not booting up (network lights, etc., work, so power is good)
We are so sorry for the missing tab in administration interface Foris. Can you please try now the RC version of Turris OS 3.11.5 and let me know if it works for you guys? The tab should be there.
netboot-manager regen now works, AP is able to download boot image and I was able to netboot-manager accept , omnia created mox_ boot image
After reboot mox_ is downloaded from tftp and mox is connecting to ssh periodicaly in one minute internal
2019-06-10 10:08:52 info sshd[14790]: Accepted publickey for turris-netboot from x.x.x.x port 55846 ssh2: ED25519 SHA256:…
2019-06-10 10:08:52 info sshd[14792]: Received disconnect from x.x.x.x port 55846:11: disconnected by user
2019-06-10 10:08:52 info sshd[14792]: Disconnected from user turris-netboot x.x.x.x port 55846
But it seems AP is not working. There are two fast blinks of diod every cca 1sec.
I see. Thank you for confirming. @miska was able to find what is going on here and find why you don’t have the tab as we have it on our side. He fixed it as well and it will be included in the upcoming RC version of Turris OS 3.11.5, which we will release really soon.
root@turris:~# netboot-manager list-incoming
Incoming:
* xxxx
root@turris:~# netboot-manager accept xxxx
Incoming:
root@turris:~# netboot-manager list-accepted
Accepted:
* xxxx
Accepted:
* xxxx
Incoming:
Transfering:
root@turris:~# arp -a
IP address HW type Flags HW address Mask Device
192.168.18.192 0x1 0x2 xx:xx:xx:xx:xx:xx * br-lan
^ this is the MOX
But I don’t know what next. Wifi scanner doesn’t show any new AP. MOX blinks 2 blinks fast, then a pause, then 2 blinks again (are there docs for the LED signals?). I can ping the MOX, but I can’t e.g. ssh to it (what’s the password? why doesn’t it have passwordless login from Omnia set up?). Ports 80 and 443 are also silent. And still no netboot tab in foris (even after accepting the MOX).
