I’m curious about my MOX A, it arrived and while I was playing with it I wanted to see some of its functions and so I first booted it into rescue mode 7 over a serial console.
I was able to perform this successfully, and the log output is as follows:
U-Boot 2018.11 (Dec 16 2018 - 12:50:19 +0000), Build: jenkins-turris-os-packages-kittens-mox-90
DRAM: 1 GiB
Enabling Armada 3720 wComphy-0: SGMII1 3.125 Gbps
Comphy-1: PEX0 5 Gbps
Comphy-2: USB3_HOST0 5 Gbps
MMC: sdhci@d8000: 0
Loading Environment from SPI Flash... SF: Detected w25q64dw with page size 256 Bytes, erase size 4 KiB, total 8 MiB
OK
Model: CZ.NIC Turris Mox Board
Net: eth0: neta@30000
Turris Mox:
Board version: 22
RAM size: 1024 MiB
Serial Number: 0000000D300013C9
ECDSA Public Key: 02015b22a7bb431c29ace8120e8d77735ac356d58a7fb884b5a7b5ba58bb08cd1606f668e8fa1ea5cd2b2bc7e7d7af1cef7d0ae23f18a6fa5cc18afd0743f73f653bfd
SD/eMMC version: SD
Hit any key to stop autoboot: 2 1 0
gpio: pin GPIO221 (gpio 57) value is 0
gpio: pin GPIO220 (gpio 56) value is 1
device 0 offset 0x7f0000, size 0x10000
SF: 65536 bytes @ 0x7f0000 Read: OK
Card did not respond to voltage select!
starting USB...
USB0: Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1: USB EHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Device 0: unknown device
neta@30000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
neta@30000: No link.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-d8-58-d7-00-b6-ba
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-mvebu-turris_mox
DRAM: 1 GiB
MMC: sdhci@d8000: 0
OK
Turris Mox:
Board version: 22
RAM size: 1024 MiB
SD/eMMC version: SD
gpio: pin GPIO220 (gpio 56) value is 0
gpio: pin GPIO221 (gpio 57) value is 1
device 0 offset 0x190000, size 0x670000
SF: 6750208 bytes @ 0x190000 Read: OK
Uncompressed size: 15717072 = 0XEFD2D0
## Loading kernel from FIT Image at 08000000 ...
Using 'conf@1' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel with initramfs included
Created: 2018-12-16 12:50:19 UTC
Type: Kernel Image (no loading done)
Compression: uncompressed
Data Start: 0x080000fc
Data Size: 15695880 Bytes = 15 MiB
Hash algo: crc32
Hash value: ebd8c2e0
Hash algo: sha1
Hash value: bcdba3d5254917115643551f2eca24379e7ddb4a
Verifying Hash Integrity ... crc32+ sha1+ OK
## Loading fdt from FIT Image at 08000000 ...
Trying 'fdt@1' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x08ef8238
Data Size: 19292 Bytes = 18.8 KiB
Architecture: AArch64
Hash algo: crc32
Hash value: d2d271e7
Hash algo: sha1
Hash value: 71a1b91456959620837fa45cb168dd06825b6c60
Booting using the fdt blob at 0x8ef8238
Loading Kernel Image ... OK
Loading Device Tree to 000000003bf16000, end 000000003bf1db5b ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.88 (beast@slave10) (gcc version 7.4.0 (OpenWrt GCC 7.4.0 775ba4083e)) #0 SMP Sun Dec 16 12:50:19 2018
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: CZ.NIC Turris Mox Board
[ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '')
[ 0.000000] bootconsole [ar3700_uart0] enabled
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 16 pages/cpu @ffffffc03ffc4000 s27800 r8192 d29544 u65536
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Kernel command line: console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1014724K/1048576K available (5182K kernel code, 352K rwdata, 1656K rodata, 8128K init, 285K bss, 33852K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008590000 ( 5184 KB)
[ 0.000000] .rodata : 0xffffff8008590000 - 0xffffff8008730000 ( 1664 KB)
[ 0.000000] .init : 0xffffff8008730000 - 0xffffff8008f20000 ( 8128 KB)
[ 0.000000] .data : 0xffffff8008f20000 - 0xffffff8008f78008 ( 353 KB)
[ 0.000000] .bss : 0xffffff8008f78008 - 0xffffff8008fbf528 ( 286 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf01000000 ( 16 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc040000000 ( 1024 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
[ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
[ 0.000004] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
[ 0.008405] Console: colour dummy device 80x25
[ 0.012915] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[ 0.023562] pid_max: default: 32768 minimum: 301
[ 0.028379] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.035217] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.043324] ASID allocator initialised with 65536 entries
[ 0.048877] Hierarchical SRCU implementation.
[ 0.053683] smp: Bringing up secondary CPUs ...
[ 0.058564] Detected VIPT I-cache on CPU1
[ 0.058594] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
[ 0.058623] CPU1: Booted secondary processor [410fd034]
[ 0.058690] smp: Brought up 1 node, 2 CPUs
[ 0.079396] SMP: Total of 2 processors activated.
[ 0.084237] CPU features: detected feature: GIC system register CPU interface
[ 0.091587] CPU features: detected feature: 32-bit EL0 Support
[ 0.097590] CPU: All CPU(s) started at EL2
[ 0.102338] devtmpfs: initialized
[ 0.107213] random: get_random_u32 called from bucket_table_alloc+0x1ac/0x214 with crng_init=0
[ 0.116149] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.126212] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 0.132553] xor: measuring software checksum speed
[ 0.237444] 8regs : 1808.000 MB/sec
[ 0.337472] 8regs_prefetch: 1621.200 MB/sec
[ 0.437502] 32regs : 2448.000 MB/sec
[ 0.537534] 32regs_prefetch: 2052.400 MB/sec
[ 0.542201] xor: using function: 32regs (2448.000 MB/sec)
[ 0.547767] pinctrl core: initialized pinctrl subsystem
[ 0.553649] NET: Registered protocol family 16
[ 0.558839] vdso: 2 pages (1 code @ ffffff8008594000, 1 data @ ffffff8008f24000)
[ 0.566571] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.573982] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
[ 0.582909] console [ttyMV0] enabled
[ 0.590226] bootconsole [ar3700_uart0] disabled
[ 0.779694] raid6: int64x1 gen() 364 MB/s
[ 0.949820] raid6: int64x1 xor() 306 MB/s
[ 1.119822] raid6: int64x2 gen() 578 MB/s
[ 1.289944] raid6: int64x2 xor() 424 MB/s
[ 1.459992] raid6: int64x4 gen() 835 MB/s
[ 1.630083] raid6: int64x4 xor() 564 MB/s
[ 1.800189] raid6: int64x8 gen() 644 MB/s
[ 1.970239] raid6: int64x8 xor() 517 MB/s
[ 2.140311] raid6: neonx1 gen() 637 MB/s
[ 2.310361] raid6: neonx1 xor() 681 MB/s
[ 2.480455] raid6: neonx2 gen() 968 MB/s
[ 2.650489] raid6: neonx2 xor() 961 MB/s
[ 2.820545] raid6: neonx4 gen() 1303 MB/s
[ 2.990620] raid6: neonx4 xor() 1187 MB/s
[ 3.160709] raid6: neonx8 gen() 1340 MB/s
[ 3.330760] raid6: neonx8 xor() 1213 MB/s
[ 3.334903] raid6: using algorithm neonx8 gen() 1340 MB/s
[ 3.340386] raid6: .... xor() 1213 MB/s, rmw enabled
[ 3.345516] raid6: using neon recovery algorithm
[ 3.351245] SCSI subsystem initialized
[ 3.355214] usbcore: registered new interface driver usbfs
[ 3.360792] usbcore: registered new interface driver hub
[ 3.366071] usbcore: registered new device driver usb
[ 3.371850] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
[ 3.386108] clocksource: Switched to clocksource arch_sys_counter
[ 3.397091] NET: Registered protocol family 2
[ 3.401638] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.409022] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 3.415844] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.422554] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.428705] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.435408] NET: Registered protocol family 1
[ 3.460564] Crashlog allocated RAM at address 0x3f00000
[ 3.466332] workingset: timestamp_bits=62 max_order=18 bucket_order=0
[ 3.476312] ntfs: driver 2.1.32 [Flags: R/O].
[ 3.482601] io scheduler noop registered
[ 3.486787] io scheduler deadline registered (default)
[ 3.496338] mv_xor d0060900.xor: Marvell shared XOR driver
[ 3.556769] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.626692] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.634390] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 3.642766] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.651637] loop: module loaded
[ 3.660266] random: fast init done
[ 3.669306] m25p80 spi0.0: w25q64dw (8192 Kbytes)
[ 3.674017] 5 fixed-partitions partitions found on MTD device spi0.0
[ 3.680745] Creating 5 MTD partitions on "spi0.0":
[ 3.685253] 0x000000000000-0x000000020000 : "secure-firmware"
[ 3.691967] 0x000000020000-0x000000180000 : "u-boot"
[ 3.697568] 0x000000180000-0x000000190000 : "u-boot-env"
[ 3.703243] 0x000000190000-0x0000007f0000 : "Rescue system"
[ 3.709438] 0x0000007f0000-0x000000800000 : "dtb"
[ 3.714753] moxtet spi0.1: Found SD Turris Mox CPU module
[ 3.720835] libphy: Fixed MDIO Bus: probed
[ 3.725494] libphy: orion_mdio_bus: probed
[ 3.747965] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:b6:ba
[ 3.756770] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.763436] ehci-pci: EHCI PCI platform driver
[ 3.768181] ehci-platform: EHCI generic platform driver
[ 3.773599] ehci-orion: EHCI orion driver
[ 3.777554] orion-ehci d005e000.usb: EHCI Host Controller
[ 3.783246] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
[ 3.791155] orion-ehci d005e000.usb: irq 12, io mem 0xd005e000
[ 3.826109] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
[ 3.832628] hub 1-0:1.0: USB hub found
[ 3.836542] hub 1-0:1.0: 1 port detected
[ 3.840868] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.847719] usbcore: registered new interface driver usb-storage
[ 3.854156] i2c /dev entries driver
[ 3.858224] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec, nowayout
[ 3.865913] sdhci: Secure Digital Host Controller Interface driver
[ 3.871884] sdhci: Copyright(c) Pierre Ossman
[ 3.876545] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.882768] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 3.888655] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 3.894782] NET: Registered protocol family 10
[ 3.900024] Segment Routing with IPv6
[ 3.903682] NET: Registered protocol family 17
[ 3.908458] 8021q: 802.1Q VLAN Support v1.8
[ 3.914385] Btrfs loaded, crc32c=crc32c-generic
[ 3.923006] rtc-ds1307 0-006f: registered as rtc0
[ 3.927758] i2c i2c-0: PXA I2C adapter
[ 3.931849] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.937016] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
[ 3.944577] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
[ 3.954120] xhci-hcd d0058000.usb: irq 11, io mem 0xd0058000
[ 3.960508] hub 2-0:1.0: USB hub found
[ 3.963958] hub 2-0:1.0: 1 port detected
[ 3.968558] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.973610] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
[ 3.981540] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
[ 3.988236] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.996678] hub 3-0:1.0: USB hub found
[ 4.000307] hub 3-0:1.0: 1 port detected
[ 4.005233] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 4.086109] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
[ 4.094101] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 4.166253] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
[ 4.175354] rtc-ds1307 0-006f: setting system clock to 2019-02-16 01:25:09 UTC (1550280309)
[ 4.189605] Freeing unused kernel memory: 8128K
sed: /proc/cmdline: No such file or directory
Initializing the system
Now is your chance to change a mode from 1 to something else, press the button to do so
[ 5.299914] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 5.306877] watchdog: watchdog0: watchdog did not stop!
expr: syntax error
Waiting for s ...
6s left
Mode changed to 2
Btrfs rollback
6s left
Mode changed to 3
Factory reset
6s left
Mode changed to 4
USB flash
6s left
Mode changed to 5
Unsecure SSH on 192.168.1.1
6s left
Mode changed to 6
Flash from the Cloud :-)
6s left
Mode changed to 7
Serial console
6s left
5s left
4s left
3s left
2s left
1s left
0s left
Mode 7 selected!
Running shell
BusyBox v1.29.3 (2018-12-16 14:59:37 UTC) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Once it was booted (this is with no SD card or Turris OS) I was unable to send any commands to the board over UART. I also noted that it shows
Is this why I could not send commands to the MOX? Or did I merely do something incorrectly, perhaps, while using moserial to connect to MOX A.
I tried typing ‘help’ once MOX had loaded the shell and received no response.
I thought this may be interesting to some as well, here is console output loading MOX A from rescue mode 4
DRAM: 1 GiB
MMC: sdhci@d8000: 0
OK
Turris Mox:
Board version: 22
RAM size: 1024 MiB
SD/eMMC version: SD
Hash algo: crc32
Hash algo: sha1
Hash algo: crc32
Hash algo: sha1
Starting kernel ...
[ 0.012917] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[ 0.023563] pid_max: default: 32768 minimum: 301
[ 0.028381] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.035219] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.043329] ASID allocator initialised with 65536 entries
[ 0.048883] Hierarchical SRCU implementation.
[ 0.053684] smp: Bringing up secondary CPUs ...
[ 0.058560] Detected VIPT I-cache on CPU1
[ 0.058591] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
[ 0.058620] CPU1: Booted secondary processor [410fd034]
[ 0.084236] CPU features: detected feature: GIC system register CPU interface
[ 0.091586] CPU features: detected feature: 32-bit EL0 Support
[ 0.097589] CPU: All CPU(s) started at EL2
[ 0.102341] devtmpfs: initialized
[ 0.107216] random: get_random_u32 called from bucket_table_alloc+0x1ac/0x214 with crng_init=0
[ 0.116150] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.126215] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 0.132554] xor: measuring software checksum speed
[ 0.437503] 32regs : 2448.000 MB/sec
[ 0.553654] NET: Registered protocol family 16
[ 0.558840] vdso: 2 pages (1 code @ ffffff8008594000, 1 data @ ffffff8008f24000)
[ 0.566573] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.573981] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
[ 0.779699] raid6: int64x1 gen() 364 MB/s
[ 0.949807] raid6: int64x1 xor() 305 MB/s
[ 1.119833] raid6: int64x2 gen() 578 MB/s
[ 1.289899] raid6: int64x2 xor() 424 MB/s
[ 1.630034] raid6: int64x4 xor() 565 MB/s
[ 1.800191] raid6: int64x8 gen() 644 MB/s
[ 1.970210] raid6: int64x8 xor() 517 MB/s
[ 2.140272] raid6: neonx1 gen() 637 MB/s
[ 2.310325] raid6: neonx1 xor() 681 MB/s
[ 2.480417] raid6: neonx2 gen() 967 MB/s
[ 2.650492] raid6: neonx2 xor() 961 MB/s
[ 2.820543] raid6: neonx4 gen() 1303 MB/s
[ 2.990618] raid6: neonx4 xor() 1187 MB/s
[ 3.160703] raid6: neonx8 gen() 1339 MB/s
[ 3.330753] raid6: neonx8 xor() 1213 MB/s
[ 3.334985] raid6: using algorithm neonx8 gen() 1339 MB/s
[ 3.340290] raid6: .... xor() 1213 MB/s, rmw enabled
[ 3.345420] raid6: using neon recovery algorithm
[ 3.351217] SCSI subsystem initialized
[ 3.355096] usbcore: registered new interface driver usbfs
[ 3.360585] usbcore: registered new interface driver hub
[ 3.366040] usbcore: registered new device driver usb
[ 3.371816] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
[ 3.386051] clocksource: Switched to clocksource arch_sys_counter
[ 3.397199] NET: Registered protocol family 2
[ 3.401979] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.409094] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 3.416087] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.422792] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.428943] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.435571] NET: Registered protocol family 1
[ 3.461204] Crashlog allocated RAM at address 0x3f00000
[ 3.466862] workingset: timestamp_bits=62 max_order=18 bucket_order=0
[ 3.477246] ntfs: driver 2.1.32 [Flags: R/O].
[ 3.482938] io scheduler noop registered
[ 3.486870] io scheduler deadline registered (default)
[ 3.495890] mv_xor d0060900.xor: Marvell shared XOR driver
[ 3.556644] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.626634] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.634696] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 3.643112] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.652869] loop: module loaded
[ 3.661957] random: fast init done
[ 3.671159] m25p80 spi0.0: w25q64dw (8192 Kbytes)
[ 3.675865] 5 fixed-partitions partitions found on MTD device spi0.0
[ 3.682509] Creating 5 MTD partitions on "spi0.0":
[ 3.687184] 0x000000000000-0x000000020000 : "secure-firmware"
[ 3.693937] 0x000000020000-0x000000180000 : "u-boot"
[ 3.699589] 0x000000180000-0x000000190000 : "u-boot-env"
[ 3.705528] 0x000000190000-0x0000007f0000 : "Rescue system"
[ 3.711475] 0x0000007f0000-0x000000800000 : "dtb"
[ 3.716867] moxtet spi0.1: Found SD Turris Mox CPU module
[ 3.722912] libphy: Fixed MDIO Bus: probed
[ 3.727804] libphy: orion_mdio_bus: probed
[ 3.747938] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:b6:ba
[ 3.756474] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.763150] ehci-pci: EHCI PCI platform driver
[ 3.767444] ehci-platform: EHCI generic platform driver
[ 3.773052] ehci-orion: EHCI orion driver
[ 3.777525] orion-ehci d005e000.usb: EHCI Host Controller
[ 3.783034] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
[ 3.790763] orion-ehci d005e000.usb: irq 12, io mem 0xd005e000
[ 3.826048] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
[ 3.832206] hub 1-0:1.0: USB hub found
[ 3.835655] hub 1-0:1.0: 1 port detected
[ 3.839958] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.847317] usbcore: registered new interface driver usb-storage
[ 3.853401] i2c /dev entries driver
[ 3.857748] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec, nowayout
[ 3.865788] sdhci: Secure Digital Host Controller Interface driver
[ 3.872212] sdhci: Copyright(c) Pierre Ossman
[ 3.876814] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.882967] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 3.888853] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 3.894974] NET: Registered protocol family 10
[ 3.899944] Segment Routing with IPv6
[ 3.903598] NET: Registered protocol family 17
[ 3.908289] 8021q: 802.1Q VLAN Support v1.8
[ 3.914226] Btrfs loaded, crc32c=crc32c-generic
[ 3.922809] rtc-ds1307 0-006f: registered as rtc0
[ 3.927751] i2c i2c-0: PXA I2C adapter
[ 3.931746] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.937010] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
[ 3.944823] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
[ 3.953884] xhci-hcd d0058000.usb: irq 11, io mem 0xd0058000
[ 3.960446] hub 2-0:1.0: USB hub found
[ 3.964345] hub 2-0:1.0: 1 port detected
[ 3.968612] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.973753] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
[ 3.981688] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
[ 3.988141] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.996787] hub 3-0:1.0: USB hub found
[ 4.000415] hub 3-0:1.0: 1 port detected
[ 4.005334] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 4.086052] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
[ 4.093952] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 4.166221] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
[ 4.174669] rtc-ds1307 0-006f: setting system clock to 2019-02-16 01:38:25 UTC (1550281105)
[ 4.188823] Freeing unused kernel memory: 8128K
[ 4.496293] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 4.533087] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 4.539350] scsi host0: usb-storage 3-1:1.0
[ 4.614315] mmc1: new ultra high speed SDR104 SDHC card at address 59b4
[ 4.621231] mmcblk1: mmc1:59b4 SMI 14.8 GiB
[ 5.320957] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 5.327916] watchdog: watchdog0: watchdog did not stop!
[ 5.738814] scsi 0:0:0:0: Direct-Access Samsung Flash Drive FIT 1100 PQ: 0 ANSI: 6
[ 5.747911] sd 0:0:0:0: [sda] 62668800 512-byte logical blocks: (32.1 GB/29.9 GiB)
[ 5.755917] sd 0:0:0:0: [sda] Write Protect is off
[ 5.761058] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.780313] sda: sda1
[ 5.784469] sd 0:0:0:0: [sda] Attached SCSI removable disk
expr: syntax error
Waiting for s ...
6s left
5s left
Mode changed to 2
Btrfs rollback
6s left
5s left
Mode changed to 3
Factory reset
Mode changed to 4
USB flash
6s left
5s left
4s left
3s left
2s left
1s left
0s left
Mode 4 selected!
Running USB flash
Searching for medkit
mount: mounting /dev/mmcblk1p1 on /mnt/src failed: No such device or address
mount: mounting /dev/sda on /mnt/src failed: Invalid argument
[ 30.046065] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Trying device /dev/sda1
ls: medkit-mox.tar.gz: No such file or directory
ls: medkit-mox-*.tar.gz: No such file or directory
Found mox-medkit-201812071641.tar.gz on device /dev/sda1
Nothing wrong with it
1
And its our newest one!
[ 30.221710] random: crng init done
[ 30.595977] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Repartitioning the drive...
[ 33.816906] mmcblk1: p1
Formatting the drive...
[ 40.933987] BTRFS: device fsid 797e9d9b-0e70-4970-b9b4-e255e870b0f6 devid 1 transid 5 /dev/mmcblk1p1
[ 42.257942] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 42.264883] BTRFS info (device mmcblk1p1): has skinny extents
[ 42.270483] BTRFS info (device mmcblk1p1): flagging fs with big metadata feature
[ 42.284003] BTRFS info (device mmcblk1p1): enabling ssd optimizations
[ 42.292208] BTRFS info (device mmcblk1p1): creating UUID tree
[ 42.762118] ntfs: (device mmcblk1p1): parse_options(): Unrecognized mount option subvol.
[ 42.772176] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 42.778718] BTRFS info (device mmcblk1p1): has skinny extents
[ 42.791910] BTRFS info (device mmcblk1p1): enabling ssd optimizations
Unpacking rootfs to the target directory
Rootfs should be ready
Backing up the current image as new factory
[ 80.778622] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 80.785204] BTRFS info (device mmcblk1p1): has skinny extents
[ 80.800039] BTRFS info (device mmcblk1p1): enabling ssd optimizations
Create a snapshot of '/mnt/tmp/@' in '/mnt/tmp/@factory'
Rebooting!
Debug info:
10240+0 records in
10240+0 records out
10485760 bytes (10.0MB) copied, 2.187217 seconds, 4.6M[ 83.543653] watchdog: watchdog0: nowayout prevents watchdog being stopped!
B/s
Device contains neither[ 83.552394] sd 0:0:0:0: [sda] Synchronizing SCSI cach\FF
DRAM: 1 GiB
MMC: sdhci@d8000: 0
OK
Turris Mox:
Board version: 22
RAM size: 1024 MiB
SD/eMMC version: SD
## Resetting to default environment
Saving Environment to SPI Flash... SF: Detected w25q64dw with page size 256 Bytes, erase size 4 KiB, total 8 MiB
Erasing SPI flash...Writing to SPI flash...done
OK
resetting ...
DRAM: 1 GiB
MMC: sdhci@d8000: 0
OK
Turris Mox:
Board version: 22
RAM size: 1024 MiB
SD/eMMC version: SD
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
403 bytes read in 67 ms (5.9 KiB/s)
## Executing script at 04d00000
9959432 bytes read in 473 ms (20.1 MiB/s)
19162 bytes read in 61 ms (306.6 KiB/s)
## Flattened Device Tree blob at 04f00000
Booting using the fdt blob at 0x4f00000
Loading Device Tree to 000000003bf14000, end 000000003bf1bad9 ... OK
Starting kernel ...
[ 0.000000] Linux version 4.14.82 (beast@slave10) (gcc version 7.3.0 (OpenWrt GCC 7.3.0 271973d916)) #0 SMP Fri Dec 7 11:37:22 2018
[ 0.000000] random: get_random_bytes called from start_kernel+0x80/0x458 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu @ffffffc03ffc2000 s28824 r8192 d32616 u69632
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Kernel command line: console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/mmcblk1p1 rootwait rootflags=subvol=@,commit=5
[ 0.000000] Memory: 1020288K/1048576K available (6910K kernel code, 446K rwdata, 2008K rodata, 320K init, 313K bss, 28288K reserved, 0K cma-reserved)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008740000 ( 6912 KB)
[ 0.000000] .rodata : 0xffffff8008740000 - 0xffffff8008940000 ( 2048 KB)
[ 0.000000] .init : 0xffffff8008940000 - 0xffffff8008990000 ( 320 KB)
[ 0.000000] .data : 0xffffff8008990000 - 0xffffff80089ff808 ( 447 KB)
[ 0.000000] .bss : 0xffffff80089ff808 - 0xffffff8008a4df08 ( 314 KB)
[ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
[ 0.008401] Console: colour dummy device 80x25
[ 0.012910] Calibrating delay loop (skipped), value calculated using timer frequency.. 25.00 BogoMIPS (lpj=125000)
[ 0.023558] pid_max: default: 32768 minimum: 301
[ 0.028400] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.035233] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.043514] ASID allocator initialised with 32768 entries
[ 0.049079] Hierarchical SRCU implementation.
[ 0.053889] smp: Bringing up secondary CPUs ...
[ 0.058803] Detected VIPT I-cache on CPU1
[ 0.058833] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
[ 0.058865] CPU1: Booted secondary processor [410fd034]
[ 0.058943] smp: Brought up 1 node, 2 CPUs
[ 0.079649] SMP: Total of 2 processors activated.
[ 0.084489] CPU features: detected feature: GIC system register CPU interface
[ 0.091841] CPU features: detected feature: 32-bit EL0 Support
[ 0.097839] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.107653] CPU: All CPU(s) started at EL2
[ 0.111789] alternatives: patching kernel code
[ 0.117014] devtmpfs: initialized
[ 0.122285] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.132374] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 0.138749] xor: measuring software checksum speed
[ 0.243651] 8regs : 1918.800 MB/sec
[ 0.343684] 8regs_prefetch: 1710.400 MB/sec
[ 0.443717] 32regs : 2358.800 MB/sec
[ 0.543753] 32regs_prefetch: 1984.400 MB/sec
[ 0.548420] xor: using function: 32regs (2358.800 MB/sec)
[ 0.553987] pinctrl core: initialized pinctrl subsystem
[ 0.560038] NET: Registered protocol family 16
[ 0.565654] cpuidle: using governor ladder
[ 0.569907] vdso: 2 pages (1 code @ ffffff8008744000, 1 data @ ffffff8008994000)
[ 0.577664] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.585074] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
[ 0.593995] console [ttyMV0] enabled
[ 0.601319] bootconsole [ar3700_uart0] disabled
[ 0.790936] raid6: int64x1 gen() 320 MB/s
[ 0.960905] raid6: int64x1 xor() 318 MB/s
[ 1.130942] raid6: int64x2 gen() 518 MB/s
[ 1.301058] raid6: int64x2 xor() 450 MB/s
[ 1.471147] raid6: int64x4 gen() 781 MB/s
[ 1.641170] raid6: int64x4 xor() 551 MB/s
[ 1.811268] raid6: int64x8 gen() 938 MB/s
[ 1.981319] raid6: int64x8 xor() 563 MB/s
[ 2.151413] raid6: neonx1 gen() 593 MB/s
[ 2.321464] raid6: neonx1 xor() 626 MB/s
[ 2.491555] raid6: neonx2 gen() 984 MB/s
[ 2.661631] raid6: neonx2 xor() 947 MB/s
[ 2.831704] raid6: neonx4 gen() 1312 MB/s
[ 3.001758] raid6: neonx4 xor() 1170 MB/s
[ 3.171845] raid6: neonx8 gen() 1296 MB/s
[ 3.341909] raid6: neonx8 xor() 1131 MB/s
[ 3.346051] raid6: using algorithm neonx4 gen() 1312 MB/s
[ 3.351446] raid6: .... xor() 1170 MB/s, rmw enabled
[ 3.356665] raid6: using neon recovery algorithm
[ 3.362558] SCSI subsystem initialized
[ 3.367415] usbcore: registered new interface driver usbfs
[ 3.372802] usbcore: registered new interface driver hub
[ 3.378338] usbcore: registered new device driver usb
[ 3.384114] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
[ 3.397687] clocksource: Switched to clocksource arch_sys_counter
[ 3.410490] NET: Registered protocol family 2
[ 3.415328] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.422528] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 3.429445] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.435719] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.442167] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.448561] NET: Registered protocol family 1
[ 3.453641] RPC: Registered named UNIX socket transport module.
[ 3.459524] RPC: Registered udp transport module.
[ 3.464260] RPC: Registered tcp transport module.
[ 3.469035] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.476869] Crashlog allocated RAM at address 0x3f00000
[ 3.482224] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 3.493073] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.499289] NFS: Registering the id_resolver key type
[ 3.504446] Key type id_resolver registered
[ 3.508593] Key type id_legacy registered
[ 3.512820] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 3.524850] io scheduler noop registered
[ 3.528588] io scheduler deadline registered (default)
[ 3.538021] mv_xor d0060900.xor: Marvell shared XOR driver
[ 3.598344] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.678247] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 3.686424] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 3.695600] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.704546] loop: module loaded
[ 3.713329] random: fast init done
[ 3.722530] m25p80 spi0.0: w25q64dw (8192 Kbytes)
[ 3.727335] 5 fixed-partitions partitions found on MTD device spi0.0
[ 3.733614] Creating 5 MTD partitions on "spi0.0":
[ 3.738645] 0x000000000000-0x000000020000 : "secure-firmware"
[ 3.745127] 0x000000020000-0x000000180000 : "u-boot"
[ 3.750695] 0x000000180000-0x000000190000 : "u-boot-env"
[ 3.756721] 0x000000190000-0x0000007f0000 : "Rescue system"
[ 3.762744] 0x0000007f0000-0x000000800000 : "dtb"
[ 3.768184] moxtet spi0.1: Found SD Turris Mox CPU module
[ 3.774351] libphy: Fixed MDIO Bus: probed
[ 3.778955] libphy: orion_mdio_bus: probed
[ 3.785014] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:b6:ba
[ 3.793803] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.800579] ehci-pci: EHCI PCI platform driver
[ 3.805132] ehci-platform: EHCI generic platform driver
[ 3.810337] ehci-orion: EHCI orion driver
[ 3.814771] orion-ehci d005e000.usb: EHCI Host Controller
[ 3.820386] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
[ 3.828055] orion-ehci d005e000.usb: irq 12, io mem 0xd005e000
[ 3.857686] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
[ 3.864337] hub 1-0:1.0: USB hub found
[ 3.867981] hub 1-0:1.0: 1 port detected
[ 3.872443] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.879423] usbcore: registered new interface driver usb-storage
[ 3.885514] i2c /dev entries driver
[ 3.889934] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec, nowayout
[ 3.898128] sdhci: Secure Digital Host Controller Interface driver
[ 3.904255] sdhci: Copyright(c) Pierre Ossman
[ 3.908777] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.914992] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 3.920711] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 3.929252] NET: Registered protocol family 10
[ 3.934680] Segment Routing with IPv6
[ 3.938358] NET: Registered protocol family 17
[ 3.943093] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.956627] 8021q: 802.1Q VLAN Support v1.8
[ 3.960726] Key type dns_resolver registered
[ 3.967013] Btrfs loaded, crc32c=crc32c-generic
[ 3.975772] rtc-ds1307 0-006f: registered as rtc0
[ 3.980536] i2c i2c-0: PXA I2C adapter
[ 3.984645] xhci-hcd d0058000.usb: xHCI Host Controller
[ 3.989997] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
[ 3.997850] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x00010010
[ 4.006445] xhci-hcd d0058000.usb: irq 11, io mem 0xd0058000
[ 4.012648] hub 2-0:1.0: USB hub found
[ 4.016373] hub 2-0:1.0: 1 port detected
[ 4.020461] xhci-hcd d0058000.usb: xHCI Host Controller
[ 4.025978] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
[ 4.033650] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
[ 4.040292] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.048674] hub 3-0:1.0: USB hub found
[ 4.052396] hub 3-0:1.0: 1 port detected
[ 4.057242] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
[ 4.137685] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
[ 4.145764] xenon-sdhci d00d8000.sdhci: Got CD GPIO
[ 4.207851] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
[ 4.218514] armada-37xx-rwtm-mailbox d00b0000.mailbox: Trust Status: 00000000
[ 4.288502] Turris Mox serial number 0000000D300013C9
[ 4.293459] board version 22
[ 4.297231] burned RAM size 1024 MiB
[ 4.489428] rtc-ds1307 0-006f: setting system clock to 2019-02-16 01:40:01 UTC (1550281201)
[ 4.678951] random: crng init done
[ 4.680362] Waiting for root device /dev/mmcblk1p1...
[ 4.798794] usb 3-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 4.866717] mmc1: new high speed SDHC card at address 59b4
[ 4.872408] mmcblk1: mmc1:59b4 SMI 14.8 GiB
[ 4.879121] mmcblk1: p1
[ 4.895434] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 4.902182] scsi host0: usb-storage 3-1:1.0
[ 4.910166] BTRFS: device fsid 797e9d9b-0e70-4970-b9b4-e255e870b0f6 devid 1 transid 14 /dev/root
[ 4.921027] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 4.927840] BTRFS info (device mmcblk1p1): has skinny extents
[ 4.953494] BTRFS info (device mmcblk1p1): enabling ssd optimizations
[ 4.969179] VFS: Mounted root (btrfs filesystem) readonly on device 0:13.
[ 4.976414] devtmpfs: mounted
[ 4.979804] Freeing unused kernel memory: 320K
[ 5.150620] init: Console is alive
[ 5.154298] init: - watchdog -
[ 6.073049] scsi 0:0:0:0: Direct-Access Samsung Flash Drive FIT 1100 PQ: 0 ANSI: 6
[ 6.085564] sd 0:0:0:0: [sda] 62668800 512-byte logical blocks: (32.1 GB/29.9 GiB)
[ 6.093749] sd 0:0:0:0: [sda] Write Protect is off
[ 6.099234] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 6.119534] sda: sda1
[ 6.124071] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 7.012220] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 7.076234] gpio_button_hotplug: no symbol version for module_layout
[ 7.083064] gpio_button_hotplug: loading out-of-tree module taints kernel.
[ 7.095938] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 7.113177] init: - preinit -
[ 7.688309] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[ 7.697576] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 7.708406] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 10.833159] mount_root: mounting /dev/root
[ 10.838667] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 10.848253] mount_root: loading kmods from internal overlay
[ 10.881266] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 10.889166] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 11.713449] block: attempting to load /etc/config/fstab
[ 11.719557] block: unable to load configuration (fstab: Entry not found)
[ 11.726687] block: no usable configuration
[ 11.747072] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 11.788111] procd: - early -
[ 11.791131] procd: - watchdog -
[ 12.430810] procd: - watchdog -
[ 12.434863] procd: - ubus -
[ 12.495111] procd: - init -
Please press Enter to activate this console.
[ 12.576340] kmodloader: loading kernel modules from /etc/modules.d/*
[ 12.586632] zram: Added device: zram0
[ 12.596008] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 12.608418] Netfilter messages via NETLINK v0.30.
[ 12.614697] ip_set: protocol 6
[ 12.640360] Loading modules backported from Linux version v4.19-rc5-0-g6bf4ca7fbc85
[ 12.648362] Backport generated by backports.git v4.19-rc5-1-0-g05571dcd
[ 12.691104] u32 classifier
[ 12.693557] input device check on
[ 12.697428] Actions configured
[ 12.703120] Mirror/redirect action on
[ 12.708946] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
[ 12.715570] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
[ 12.758834] Ebtables v2.0 registered
[ 12.764656] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 12.791949] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 12.804397] ctnetlink v0.93: registering with nfnetlink.
[ 12.886378] xt_time: kernel timezone is -0000
[ 12.910785] PPP generic driver version 2.4.2
[ 12.916805] NET: Registered protocol family 24
[ 12.935213] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 19.426747] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 19.433559] watchdog: watchdog0: watchdog did not stop!
[ 19.443673] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 19.450443] watchdog: watchdog0: watchdog did not stop!
[ 19.839184] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[ 19.848564] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 19.856489] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
haveged: haveged starting up
[ 20.062706] zram0: detected capacity change from 0 to 522190848
[ 20.075577] Adding 509948k swap on /dev/zram0. Priority:-2 extents:1 across:509948k SS
haveged: haveged: ver: 1.9.4; arch: generic; vend: ; build: (gcc 7.3.0 CV); collect: 128K
haveged: haveged: cpu: (); data: 32K (P); inst: 32K (P); idx: 17/40; sz: 32712/75040
haveged: haveged: fills: 0, generated: 0
[ 23.518722] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[ 23.528544] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 23.541370] br-lan: port 1(eth0) entered blocking state
[ 23.546443] br-lan: port 1(eth0) entered disabled state
[ 23.552263] device eth0 entered promiscuous mode
[ 23.558317] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 37.191520] device eth0 left promiscuous mode
[ 37.195939] br-lan: port 1(eth0) entered disabled state
[ 37.225274] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 39.368099] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
[ 39.376868] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 39.386515] br-lan: port 1(eth0) entered blocking state
[ 39.392027] br-lan: port 1(eth0) entered disabled state
[ 39.397938] device eth0 entered promiscuous mode
[ 39.403850] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Router Turris successfully started.
Stopping router Turris.
[ 97.129456] device eth0 left promiscuous mode
[ 97.134126] br-lan: port 1(eth0) entered disabled state
[ 97.178528] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 98.530669] BTRFS info (device mmcblk1p1): disk space caching is enabled
[ 98.681876] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 98.688718] watchdog: watchdog0: watchdog did not stop!
[ 98.701822] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 98.709030] watchdog: watchdog0: watchdog did not stop!
[ 101.719925] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 101.767767] reboot: Restarting system
