More 5.1.4 errors after tos 5.x migration
Here’s a quick collection of bugs I’ve found so far after migrating to TOS 5.1.4 from 3.11.26
1.) The KILLER BUG is WAN recv down to ~13MBit, with TOS 3.11.26 it was around 800-900MB. send performance is interestingly ok. It is 100Mbit Upstream with TOS 5.1.4 & 3.11.26. I have checked the Speed on the Network ports but all is set to 1000Mbit LAN & WAN Ports. So why on earth is the downstream so extremly slow. As soon as I switch from TOS 5.1.4 (emmc) to TOS 3.11.26 (sata) performance is back at around 800-900MBit.
2.) wget package not installed so installing new packages failes completely and you have to manually download and install
3.) file /etc/fw_env.config get’s removed if it was present before which kills fw_printenv, fw_setenv etc. commands must be manually recreated
Hope this errors especially downstream is (especially wget) fixed soon and I don’t know why such huge impact errors like extremly slow performance and loosing wget package have gone to hbs branch.
A post was merged into an existing topic: Migration to 5.1.4 works on emmc but fails on msata. In-depth knowledge needed for firmware loading errors
