Migrace updater na Turrisu HW verze 1.x
Opravil jsem si to rucne v /etc/config/updater, nicmene po spusteni skriptu mi to vraci 1 a ne nulu.
root@turris:~# updater.sh -n
+ [ -n = -w ]
+ WAIT_FOR_ONLINE=180
+ dirname /usr/bin/updater.sh
+ LIB_DIR=/usr/bin
+ . /usr/bin/updater-worker.sh
+ . /usr/bin/updater-utils.sh
+ PID=29452
+ PROGRAM=updater
+ FAILSAFE_MODE=false
+ TMP_DIR=/tmp/update
+ PKG_DIR=/tmp/update/packages
+ CIPHER=aes-256-cbc
+ COOLDOWN=3
+ CERT=/etc/ssl/updater.pem
+ CRL=/etc/ssl/crl.pem
+ STATE_DIR=/tmp/update-state
+ STATE_FILE=/tmp/update-state/state
+ LOG_FILE=/tmp/update-state/log2
+ PLAN_FILE=/tmp/update-state/plan
+ LOCK_DIR=/tmp/update-state/lock
+ QUEUE=
+ uci -q get updater.override.branch
+ ID=rc
+ uci -q get updater.override.revision
+ atsha204cmd hw-rev
+ REVISION=00000009
+ uci -q get updater.override.generation
+ sed -e s/\..*/\// /etc/turris-version
+ GENERATION=3/
+ uci -q get updater.override.base_url
+ echo https://api.turris.cz/updater-repo/
+ BASE_URL=https://api.turris.cz/updater-repo/
+ uci -q get updater.override.hash_url
+ echo https://api.turris.cz/hashes/
+ HASH_URL=https://api.turris.cz/hashes/
+ BASE_URL=https://api.turris.cz/updater-repo/3/00000009
+ uci -q get updater.override.list_req_url
+ echo https://api.turris.cz/getlists.cgi
+ LIST_REQ=https://api.turris.cz/getlists.cgi
+ uci -q get updater.override.disable
+ echo false
+ DISABLED=false
+ false
+ GENERIC_LIST_URL=https://api.turris.cz/updater-repo/3/00000009/lists/generic
+ SPECIFIC_LIST_URL=https://api.turris.cz/updater-repo/3/00000009/lists/rc
+ PACKAGE_URL=https://api.turris.cz/updater-repo/3/00000009/packages
+ PID_FILE=/tmp/update-state/pid
+ BACKGROUND=false
+ EXIT_CODE=1
+ BASE_PLAN_FILE=/usr/share/updater/plan
+ [ -e /tmp/offline-update-ready ]
+ [ -n = -b ]
+ echo+ sed s|^https*://\([^/]*\)/.*|\1|
+ PING_TEST_HOST=api.turris.cz
+ seq 1 180
+ ping -c 1 -w 1 api.turris.cz
+ break
+ [ -n = -r ]
+ /usr/bin/updater-wipe.sh
+ [ -d /tmp/update-state/lock ]
+ mkdir -p /tmp/update-state
+ mkdir /tmp/update-state/lock
+ echo 29452
+ echo startup
+ echo initial sleep
+ rm -f /tmp/update-state/log2 /tmp/update-state/last_error
+ touch /tmp/update-state/log2
+ false
+ STABLE_PACKAGES=/usr/share/updater/packages
+ STABLE_PLAN=/usr/share/updater/plan
+ trap rm -rf "$TMP_DIR" "$PID_FILE" "$LOCK_DIR" $STABLE_PACKAGES $STABLE_PLAN; exit "$EXIT_CODE" EXIT INT QUIT TERM ABRT
+ [ -n != -n ]
+ shift
+ get-api-crl
+ cat /tmp/opkg-update-timestamp
+ LAST_UPDATE=1487071392
+ date +%s
+ DATE_NOW=1487073336
+ [ -z 1487071392 ]
+ expr 1487073336 - 1487071392
+ [ 1944 -gt 86400 ]
+ do_journal
+ [ -f /usr/share/updater/journal ]
+ echo get list
+ uci get updater.pkglists.lists
+ get_list_pack base core honeypot netutils majordomo dvb shell-utils cacerts luci-controls nas definitions
+ echo 3/00000009
+ [ rc != unknown-id ]
+ + uci -q get updater.override.branch
my_curl -T - https://api.turris.cz/getlists.cgi -X POST -f
+ curl --compress --cacert /etc/ssl/updater.pem --crlfile /etc/ssl/crl.pem -T - https://api.turris.cz/getlists.cgi -X POST -f
+ [ -z rc ]
+ SERIAL=rc
+ echo rc
+ mkdir -p /tmp/updater-lists
+ [ base ]
+ [ -f /tmp/updater-lists/base ]
+ HASH=-
+ echo base -
+ shift
+ [ core ]
+ [ -f /tmp/updater-lists/core ]
+ HASH=-
+ echo core -
+ shift
+ [ honeypot ]
+ [ -f /tmp/updater-lists/honeypot ]
+ HASH=-
+ echo honeypot -
+ shift
+ [ netutils ]
+ [ -f /tmp/updater-lists/netutils ]
+ HASH=-
+ echo netutils -
+ shift
+ [ majordomo ]
+ [ -f /tmp/updater-lists/majordomo ]
+ HASH=-
+ echo majordomo -
+ shift
+ [ dvb ]
+ [ -f /tmp/updater-lists/dvb ]
+ HASH=-
+ echo dvb -
+ shift
+ [ shell-utils ]
+ [ -f /tmp/updater-lists/shell-utils ]
+ HASH=-
+ echo shell-utils -
+ shift
+ [ cacerts ]
+ [ -f /tmp/updater-lists/cacerts ]
+ HASH=-
+ echo cacerts -
+ shift
+ [ luci-controls ]
+ [ -f /tmp/updater-lists/luci-controls ]
+ HASH=-
+ echo luci-controls -
+ shift
+ [ nas ]
+ [ -f /tmp/updater-lists/nas ]
+ HASH=-
+ echo nas -
+ shift
+ [ definitions ]
+ [ -f /tmp/updater-lists/definitions ]
+ HASH=-
+ echo definitions -
+ shift
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
curl: (60) SSL certificate problem: unable to get certificate CRL
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
 of Certificate Authority (CA) public keys (CA certs). If the default
 bundle file isn't adequate, you can specify an alternate file
 using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
 the bundle, the certificate verification probably failed due to a
 problem with the certificate (it might be expired, or the name might
 not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
 the -k (or --insecure) option.
+ die Could not download list pack
+ echo error
+ echo Could not download list pack
+ my_logger -p daemon.err
+ + echo Could not download list pack
logger -t updater -p daemon.err
+ kill -SIGABRT 29452
+ rm -rf /tmp/update /tmp/update-state/pid /tmp/update-state/lock /usr/share/updater/packages /usr/share/updater/plan
+ exit 1
+ exit 1
root@turris:~# echo $?
1
Takze evidentne problem s chybejicimi certifikaty, jak je zmineno zde:
Po jejich stazeni/instalaci uz updater.sh -n hlasil nulu.
Spusten tedy updater-migrate.sh, ktery plus minus probehl, jen sem tam nejaky WARN:
> WARN:Branch overriden to rc
> WARN:Script revision-specific not found, but ignoring its absence as requested
> WARN:Script serial-specific not found, but ignoring its absence as requested
> WARN:Lock on //var/lock/opkg.lock released by garbage collector
> + exec pkgupdate
> WARN:Couldn’t load flags: cannot open /usr/share/updater/flags: No such file or directory
> WARN:Config file /etc/config/updater modified by the user. Backing up the new one into /etc/config/updater-opkg
> WARN:Config file /etc/config/transmission modified by the user. Backing up the new one into /etc/config/transmission-opkg
> Output from luci-app-sqm.postinst:
> uci: Parse error (invalid command) at line 157, byte 4
> uci: Parse error (invalid character in name field) at line 12, byte 24
> INFO:Executing postupdate hooks…
> root@turris:~#
Po opetovnem spusteni updater.sh pouze tyto WARN:
WARN:Multiple candidates from same repository with same version for package shairport-sync-openssl
Snad je tedy vse v poradku :slight_smile:
Tak jsem včera provedl migraci, nejsem si jistý, ale myslím si, že proběhla v pořádku, jen mám problém s tím, že před migrací jsem měl v Turrisu cca 65 MB místa a teď mám pouze 15 MB, nevíte, kde by mohl být problém? Děkuji
Než to všechno začneš řešit restartoval si Turrise?
Mělo by se to dát zjistit z logu updateru, který se nachází ve složce /usr/share/updater
Potom je důležité vědět, jestli si neměl balíček pro tiskárnu ( v návodu bylo, že se to má předtím odinstalovat)
Jinak tady je můj soubor installed-packages (bude se lišit, protože je z nightly) a když tak to zkus porovnat (třeba přes github) a zjistit, které balíčky máš navíc a odinstalovat je.
+ cat /tmp/update/user_lists/nas
+ run_plan /tmp/update-state/plan
+ . /tmp/update-state/plan
+ do_commit
+ rm /tmp/update-state/plan
+ execute_list i_agree_datacollect
+ echo get list
+ get_list i_agree_datacollect user_lists/i_agree_datacollect
+ grep  MISSING$ /tmp/updater-lists/status
+ grep -qF i_agree_datacollect
+ die Missing list i_agree_datacollect
+ echo error
+ echo Missing list i_agree_datacollect
+ logger -t updater-user -p daemon.err
+ kill -SIGABRT 1671
+ exit 1
+ exit 1
root@turris:~# i_agree_datacollectMissing list i_agree_datacollect
-ash: i_agree_datacollectMissing: not found
Poradí někdo co s tím? Nebo napsat rovnou na podporu? :smiley: Díky.
