Metalcase with non-dualband Antennas
Thanks for your good work!
Will there be an option to skip the signal-combiners and use five singleband antennas instead of three dualband ones?
As mentioned in the post by Ondřej Filip ( http://en.blog.nic.cz/2016/01/07/metal-or-not-metal-that-is-the-question/ ) there are 1) enough antenna holes and 2) the signal combiners are atleast described as to be external to the wifi cards.
Is there something I did not consider in this case? Or could I simply wire up five antennas?
Maybe this could be made an official option for the post campaign survey?
Kind Regards,
Stephan
