I’m a bit new to lxc, used Docker a bit more.
When I try to start and attach to a LXC it won’t work:
root@turris:~# lxc-start -F -n 03_borg --logfile=log.txt
Failed to mount cgroup at /sys/fs/cgroup/systemd: Operation not permitted
[!!!] Failed to mount API filesystems.
Exiting PID 1…
The logfile is empty.
I tried different kind of distributions and versions, Ubuntu and Debian. Same result.
When I run lxc-attach I get this:
root@turris:~# lxc-attach -n 03_borg
lxc-attach: 03_borg: attach.c: lxc_attach: 1095 Failed to get init pid
I found an ission on LXCs GitHub repo but to be honest I don’t really know what it means…
I used LuCIs standardconfig:
# Template used to create this container: /usr/share/lxc/templates/lxc-download # Parameters passed to the template: --dist ubuntu --release hirsute --arch armhf --server images.linuxcontainers.org --no-validate # For additional config options, please look at lxc.container.conf(5) # Uncomment the following line to support nesting containers: #lxc.include = /usr/share/lxc/config/nesting.conf # (Be aware this has security implications) # Debian workaround # Template to generate fixed MAC address # Distribution configuration lxc.include = /usr/share/lxc/config/common.conf lxc.arch = linux32 # Container specific configuration lxc.tty.max = 4 lxc.pty.max = 1024 lxc.rootfs.path = btrfs:/srv/lxc/03_borg/rootfs lxc.uts.name = 03_borg # Network configuration lxc.net.0.type = veth lxc.net.0.link = br-lan lxc.net.0.flags = up lxc.net.0.name = eth0 lxc.net.0.hwaddr = f2:d7:12:ff:80:85
Anyone here who can help me with that problem? I could even reset the whole router if someone could tell me how I keep my other settings in LuCI and my OpenVPN settings in ReForis… I don’t find a simple save-config-button.
