LXC Containers - can not be installed - debootstrap write error
Hi, I have a Problem,
after installing new Omnia version 3.9.1, with Kernel 4.4.106 and install the option LXC, I can not install debian or ubuntu LXC becomme an error:
root@turris:~# lxc-create -t debian -n debian
debootstrap is /usr/sbin/debootstrap
Checking cache download in /var/cache/lxc/debian/rootfs-stretch-armhf ...
Downloading debian minimal ...
/usr/sbin/debootstrap: line 491: can't create /var/cache/lxc/debian/partial-stretch-armhf/test-dev-null: Permission denied
E: Cannot install into target '/var/cache/lxc/debian/partial-stretch-armhf' mounted with noexec or nodev
Failed to download the rootfs, aborting.
Failed to download 'debian base'
failed to install debian
lxc-create: lxccontainer.c: create_run_template: 1201 container creation template for debian failed
lxc-create: lxc_create.c: main: 274 Error creating container debian
I have should check that lxc support in the kernel by running the following command:
root@turris:~# lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
Multiple /dev/pts instances: enabled
--- Control groups ---
Cgroup: enabled
Cgroup clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup memory controller: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled
Macvlan: enabled
Vlan: enabled
Bridges: enabled
Advanced netfilter: enabled
CONFIG_NF_NAT_IPV4: enabled
CONFIG_NF_NAT_IPV6: enabled
CONFIG_IP_NF_TARGET_MASQUERADE: enabled
CONFIG_IP6_NF_TARGET_MASQUERADE: enabled
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: missing
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: missing
CONFIG_INET_DIAG: missing
CONFIG_PACKET_DIAG: missing
CONFIG_NETLINK_DIAG: missing
File capabilities: enabled
Note : Before booting a new kernel, you can check its configuration
usage : CONFIG=/path/to/config /usr/bin/lxc-checkconfig
I hope someone can give me a note for solved it
Thx Joeatx
What about trying to install Ubuntu container using LuCI? I did it some time ago without any problem, using Ubuntu Xenial template… Have a luck!
Ubuntu will also not work :frowning: I think the problem is here:
I do not know where the problem is. I flashed new version 3.9.1 from a USB stick, I have try the old version 3.7.x tested, without success
I followed the installation process via a serial cable, so I did not notice any installation errors.that
I had to wait a long time for my Turris Omna, the router and the I bought 100Mbit 4G moden was not cheap.
That with the LXC worked well before do an update, Unfortunately, I can not explain why it does not work anymore.
With this missing function, I can not even sell it.
I would like a better support with a stock OpenWRT and not so messed up.
@Turris Team:
I can apply for a replacement device for testing the issue with a second device?
I see.
The problem is in your command.
Do this
lxc-create -t download -n name
and it works! Btw we have also documentation for LXC.
But currently installing containers via LUCI doesn’t work. It’s bug. I already confirmed it in at least 2 threads.
We’re working on it.
Hello,yes you are right my mistake
root@turris:~# lxc-create -t download -n pihole
Setting up the GPG keyring
Downloading the image index
DIST	RELEASE	ARCH	VARIANT	BUILD
Turris_OS	stable	armv7l	default	2018-01-07
Turris_OS	stable	ppc	default	2018-01-07
Alpine	3.4	armv7l	default	2018-01-07
ArchLinux	latest	armv7l	default	2018-01-07
Debian	Stretch	armv7l	default	2018-01-07
Debian	Buster	armv7l	default	2018-01-07
Gentoo	stable	armv7l	default	2018-01-07
openSUSE	42.2	armv7l	default	2018-01-07
openSUSE	42.3	armv7l	default	2018-01-07
openSUSE	Tumbleweed	armv7l	default	2018-01-07
Sabayon	current	armv7l	default	2018-01-07
Ubuntu	Xenial	armv7l	default	2018-01-07
Ubuntu	Zesty	armv7l	default	2018-01-07
Ubuntu	Artful	armv7l	default	2018-01-07
Distribution: Debian
Release: Stretch
Architecture: armv7l
Flushing the cache...
Downloading the rootfs
Downloading the metadata
The image cache is now ready
Unpacking the rootfs
Distribution Debian version Stretch was just installed into your container.
Thank you for solving my mistake.
