After migration from TOS4 to TOS5 I have problem with my Debian Buster LXC running Nextcloud.
MariaDB fails to start due to cgroup problems.
I even tried to create fresh new buster container but it behaves exactly same.
Anyone can help?
Migated LXC (Nextcloud):
root@turris:~# lxc-start -n nextcloud -F
lxc-start: nextcloud: utils.c: safe_mount: 1179 No such file or directory - Failed to mount "/usr/lib/lxc/rootfs/proc/tty" onto "/usr/lib/lxc/rootfs/proc/sys/net"
systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Detected virtualization lxc.
Detected architecture arm.
Welcome to Debian GNU/Linux 10 (buster)!
Set hostname to <nextcloud>.
Failed to attach 1 to compat systemd cgroup /init.scope: No such file or directory
Couldn't move remaining userspace processes, ignoring: Input/output error
File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
/lib/systemd/system/mariadb.service:16: Failed to parse protect system value, ignoring:
/lib/systemd/system/mariadb.service:18: Failed to parse protect home value, ignoring:
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Listening on Journal Socket.
[ OK ] Created slice system-container\x2dgetty.slice.
Failed to attach 15 to compat systemd cgroup /system.slice/dev-mqueue.mount: No such file or directory
Mounting POSIX Message Queue File System...
[ OK ] Reached target Remote File Systems.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
Starting Remount Root and Kernel File Systems...
[ OK ] Listening on Journal Socket (/dev/log).
Failed to attach 17 to compat systemd cgroup /system.slice/systemd-journald.service: No such file or directory
Starting Journal Service...
[ OK ] Reached target Swap.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Paths.
Starting Helper to synchronize boot up for ifupdown...
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Create System Users...
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
[ OK ] Started Helper to synchronize boot up for ifupdown.
[ OK ] Started Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
Starting Network Service...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
Starting Raise network interfaces...
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Network Service.
Starting Wait for Network to be Configured...
Starting Network Name Resolution...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Started Clean PHP session files every 30 mins.
[ OK ] Reached target Basic System.
Starting Avahi mDNS/DNS-SD Stack...
Starting Login Service...
[ OK ] Started D-Bus System Message Bus.
Starting WPA supplicant...
[ OK ] Started Regular background program processing daemon.
Starting Modem Manager...
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
Starting Rotate log files...
Starting Clean php session files...
[ OK ] Started Login Service.
[ OK ] Started WPA supplicant.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Wait for Network to be Configured.
[ OK ] Started Modem Manager.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started Raise network interfaces.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
[ OK ] Started ClamAV virus database updater.
Starting The Apache HTTP Server...
Starting Advanced key-value store...
Starting coTURN STUN/TURN Server...
Starting Permit User Sessions...
Starting OpenBSD Secure Shell server...
Starting MariaDB 10.3.22 database server...
Starting Daily apt download activities...
[ OK ] Started Permit User Sessions.
[ OK ] Started Console Getty.
[ OK ] Started Container Getty on /dev/pts/2.
[ OK ] Started Container Getty on /dev/pts/3.
[ OK ] Started Container Getty on /dev/pts/0.
[ OK ] Started Container Getty on /dev/pts/1.
[ OK ] Reached target Login Prompts.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Started Advanced key-value store.
[ OK ] Started The Apache HTTP Server.
[ OK ] Started Clean php session files.
[ OK ] Started coTURN STUN/TURN Server.
[FAILED] Failed to start MariaDB 10.3.22 database server.
See 'systemctl status mariadb.service' for details.
Starting LSB: exim Mail Transport Agent...
Debian GNU/Linux 10 nextcloud console
nextcloud login:
new test buster LXC:
root@turris:~# lxc-start -n test -F
lxc-start: test: utils.c: safe_mount: 1179 No such file or directory - Failed to mount "/usr/lib/lxc/rootfs/proc/tty" onto "/usr/lib/lxc/rootfs/proc/sys/net"
Set hostname to <LXCNAME>.
Failed to attach 19 to compat systemd cgroup /system.slice/dev-mqueue.mount: No such file or directory
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
Starting Daily apt upgrade and clean activities...
Debian GNU/Linux 10 LXCNAME console
LXCNAME login:
