LXC container bridge to the WAN interface
Does anyone know how to set up a bridge for LXC container interface with the turris WAN interface. I have more public IP’s from the ISP and I want to set one directly on a Debian I have in LXC container, … Thanks a lot.
Víte někdo jak nastavit LXC containeru interface tak, aby bl jako bridge k WAN interfacu na turrisu? Jde mi o to ze mam vice verejnych a chtel bych tu jednu dostat primo na debian v LXC containeru, … Diky
Maybe Firewall settings at: http://192.168.1.1/cgi-bin/luci/admin/network/firewall/zones ?
I’ve setup port forwarding for WAN → LXC container using New port forward at http://192.168.1.1/cgi-bin/luci/admin/network/firewall/forwards. Here is how it looks like on my side:
Hello Damien, thank you, but this is not what I’m looking for. I know how to use port forward. I’m searching for the way how to utilize another public IP I have available. If not possible to bridge the WAN co LXC container, than I would like to try to create a sub-interface which will obtain from ISP another IP from DHCP. But for that I need this subint to have different MAC. Anyway I have no idea how to achieve it on turris as I’m no a linux guy.
I’ve tried to create another WAN2 interface (attach it to eth1) but that was obviously wrong way :frowning:
ok man :slight_smile: Good luck.
