I enabled the openvpn not too long ago and as I run luci-statistics, I wanted to start gathering statistics on it.
First, I had to create an entry for /etc/config/luci_statistics:
config openvpn 'collectd_openvpn'
option enable '1'
list StatusFile '/tmp/openvpn-status.log'
Unless I did that looking at the Statistics|Setup|Network Plugins|OpenVPN showed nothing between the “OpenVPN Plugin Configuration” and the “Save & Apply” … button bar.
Once set the config file, stopped /etc/init.d/luci_statistics
and /etc/init.d/collectd
then restarted them, then I saw the Configuration options.
I set the options, then hit “Save & Apply”. However, no new directory shows up in my data area and no graph link shows up either.
If I create the directory by hand, it remains empty, but I do get an OpenVPN graph page with broken images instead of graphs.
I’ve tried all the tricks I know to get this to start, but I’m feeling kind of lost at this point.
