My Turris Omnia (version 6.2.0) is inaccessible after today’s update (January 3, 2023). A lighttpd daemon is not listening, both TCP ports 80 & 443 are not active. I can use only the SSH access to the router.
Listening ports:
netstat -lntp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:11883 0.0.0.0:* LISTEN 3319/mosquitto
tcp 0 0 0.0.0.0:853 0.0.0.0:* LISTEN 5104/kresd
tcp 0 0 127.0.0.1:9080 0.0.0.0:* LISTEN 3372/python3
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2703/sshd -D [liste
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 5104/kresd
tcp 0 0 :::2333 :::* LISTEN 4242/sentinel-minip
tcp 0 0 :::853 :::* LISTEN 5104/kresd
tcp 0 0 :::8033 :::* LISTEN 4239/sentinel-minip
tcp 0 0 ::1:11883 :::* LISTEN 3319/mosquitto
tcp 0 0 :::5873 :::* LISTEN 4241/sentinel-minip
tcp 0 0 :::22 :::* LISTEN 2703/sshd -D [liste
tcp 0 0 :::53 :::* LISTEN 5104/kresd
tcp 0 0 :::2133 :::* LISTEN 4237/sentinel-minip
I found some errors in file /var/log/lighttpd/error.log
2023-01-03 21:44:14: (../src/server.c.1588) server started (lighttpd/1.4.67)
2023-01-03 21:44:14: (../src/mod_alias.c.70) url.alias: `/.well-known/acme-challenge/' will never match as `/' matched first
2023-01-03 21:44:14: (../src/server.c.1592) Configuration of plugins failed. Going down.
I have tried to reboot the router, but problem is still the same.
The web service looks like running, but no active lighttpd
process is found.
Service status:
service lighttpd status
running
service 2>/dev/null | grep htt
/etc/init.d/lighttpd enabled stopped
Processes including http (inc. lighttpd):
ps -ef | grep http
root 4217 1 0 21:17 ? 00:00:00 /usr/bin/sentinel-minipot --ftp=2133 --http=8033 --smtp=5873 --telnet=2333
nobody 4237 4217 0 21:17 ? 00:00:00 /usr/bin/sentinel-minipot --ftp=2133 --http=8033 --smtp=5873 --telnet=2333
nobody 4239 4217 0 21:17 ? 00:00:00 /usr/bin/sentinel-minipot --ftp=2133 --http=8033 --smtp=5873 --telnet=2333
nobody 4241 4217 0 21:17 ? 00:00:01 /usr/bin/sentinel-minipot --ftp=2133 --http=8033 --smtp=5873 --telnet=2333
nobody 4242 4217 0 21:17 ? 00:00:00 /usr/bin/sentinel-minipot --ftp=2133 --http=8033 --smtp=5873 --telnet=2333
root 11856 6373 0 22:30 pts/0 00:00:00 grep http
